Reply 120 of 123, by DustyShinigami
- Oldbie
asdf53 wrote on Yesterday, 19:21:Those are Windows drivers, not BIOS files. The HPT BIOS is a single binary file with a size of around 25 kb. It's a bit confusin […]
Those are Windows drivers, not BIOS files. The HPT BIOS is a single binary file with a size of around 25 kb. It's a bit confusing because the drivers share the same version numbers with the BIOS.
You mentioned that your controller BIOS says 1.25 at boot, so even if your motherboard BIOS is up to date, the controller's isn't so far.
Regarding the sound card, I'd suggest trying it with the HPT controller disabled in BIOS and your drives connected to IDE1 and IDE2. If that doesn't help, test the card in your other motherboard if possible, to determine if it's damaged or if it's just a driver issue.
You don't even have to reinstall Windows 98. Just use the same hard drive on your other board, boot into Windows, delete device manager using registry, re-detect hardware. Later, transfer the hard drive back to the Abit board and repeat the process.
Ahh, okay. I take it I need to download a version of Awdflash? Or is that part of the BIOS/CBROM?
And I wouldn't worry about reinstalling 98, I've set up an entirely fresh test build, so I have 98 installed on a spare hard drive. 😀
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
