First post, by DustyShinigami
- Oldbie
Hey.
I was advised to start a new thread on the grounds that there's the possibility of some kind of system instability with my rig. Whilst trying to follow the step-by-step instructions in this thread - Guide: Installing Windows 9x and DOS drivers on Audigy cards (version 3.1) - I can't seem to get any further than installing DirectX 9. With my test rig, I recall having some weird issues with DirectX 9, but on my current setup, it doesn't appear to like it at all. I'm not sure if there's some incompatibility quirkiness going on, or something more serious. Basically, after installing DirectX 9, everything appears fine, but then whilst I'm running the Sound Blaster Audigy 2 VXD driver installer, the system locks up. I understand Windows 98 SE supports DirectX 9, so it is a bit odd it would cause the whole system to lock up like this.
Someone suggested it could be related to my HPT IDE controller, but I've tried disabling that in the BIOS and the issue still happens. The BIOS, and HPT BIOS, have been updated to the latest version. I believe it's 1.28 for the BIOS and then I have 1.25 in Windows. Or 1.24.
I've also encountered some other weird issues. The other day, whilst copying and pasting the contents of my pre-made CD-RW, it kept complaining that the disc had been removed or was dirty via a BSOD. Since then, it hasn't happened. But one weird issue that has cropped up recently, and I can't figure out why, though could be due to something changed in the BIOS, is that during boot, the system stays on the Windows 98 splash screen for a long time. Longer than it used to. I timed it and it stays that way for just under 1 minute. There are times where I'll boot the machine up and it loads up as normal. And then will go back to taking too long. The HDD LED just stops blinking during that time. And then it decides to carry on after nearly a minute. At first, I figured it was because of the CDSlow utility I'd installed, but I've tried removing it and reverting back to a custom-made image of the HDD, from after it had been reformatted with a fresh install, but it still does it. Also, just the other day, I did a complete re-install of Windows, thinking that would fix it, but it's still the same. On one occasion, if I enabled the boot-menu screen, it prevented it from hanging for too long. But since the last time I tried, it still does it anyway.
I have disabled both COM ports and LPT port to free up resources, and set IRQ to Legacy for the ISA sound card, so I'm not sure if they're responsible...? Though I don't know why they would be. Also, at the moment, I have no USB devices attached, save the one in my Gotek Flash Floppy drive and I've already tried removing that.
Thanks
EDIT: Left the system on the desktop whilst typing this, moved the mouse, and the system had locked up again.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
