Possible system instability...?
First post, by DustyShinigami
Hey.
I was advised to start a new thread on the grounds that there's the possibility of some kind of system instability with my rig. Whilst trying to follow the step-by-step instructions in this thread - Guide: Installing Windows 9x and DOS drivers on Audigy cards (version 3.1) - I can't seem to get any further than installing DirectX 9. With my test rig, I recall having some weird issues with DirectX 9, but on my current setup, it doesn't appear to like it at all. I'm not sure if there's some incompatibility quirkiness going on, or something more serious. Basically, after installing DirectX 9, everything appears fine, but then whilst I'm running the Sound Blaster Audigy 2 VXD driver installer, the system locks up. I understand Windows 98 SE supports DirectX 9, so it is a bit odd it would cause the whole system to lock up like this.
Someone suggested it could be related to my HPT IDE controller, but I've tried disabling that in the BIOS and the issue still happens. The BIOS, and HPT BIOS, have been updated to the latest version. I believe it's 1.28 for the BIOS and then I have 1.25 in Windows. Or 1.24.
I've also encountered some other weird issues. The other day, whilst copying and pasting the contents of my pre-made CD-RW, it kept complaining that the disc had been removed or was dirty via a BSOD. Since then, it hasn't happened. But one weird issue that has cropped up recently, and I can't figure out why, though could be due to something changed in the BIOS, is that during boot, the system stays on the Windows 98 splash screen for a long time. Longer than it used to. I timed it and it stays that way for just under 1 minute. There are times where I'll boot the machine up and it loads up as normal. And then will go back to taking too long. The HDD LED just stops blinking during that time. And then it decides to carry on after nearly a minute. At first, I figured it was because of the CDSlow utility I'd installed, but I've tried removing it and reverting back to a custom-made image of the HDD, from after it had been reformatted with a fresh install, but it still does it. Also, just the other day, I did a complete re-install of Windows, thinking that would fix it, but it's still the same. On one occasion, if I enabled the boot-menu screen, it prevented it from hanging for too long. But since the last time I tried, it still does it anyway.
I have disabled both COM ports and LPT port to free up resources, and set IRQ to Legacy for the ISA sound card, so I'm not sure if they're responsible...? Though I don't know why they would be. Also, at the moment, I have no USB devices attached, save the one in my Gotek Flash Floppy drive and I've already tried removing that.
Thanks
EDIT: Left the system on the desktop whilst typing this, moved the mouse, and the system had locked up again.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 38, by cyclone3d
I would reseat everything absolutely everything.
If that doesn't fix it, I would clean the CPU and RAM edge connectors. Electronics cleaner or a rubber eraser works fine.
I've also had to clean the CPU slot before. Folded up printer paper works fine for this as long as there is a bit of resistance so the paper can clean the oxidation off the contacts.
What brand / model of power supply and how old is it?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 38, by DustyShinigami
cyclone3d wrote on 2025-11-24, 22:54:
I would reseat everything absolutely everything. […]
Hmm. Okay. I have some isopropyl that's 99.9%. I should be fine using a soft toothbrush, right?
OS: Windows 98 SE
Reply 4 of 38, by DustyShinigami
cyclone3d wrote on 2025-11-24, 23:27:
Yeah, or a paper towel. I'm not convinced that isopropyl will remove oxidation though. I generally always just use a rubber eraser.
I'm not sure how much oxidation there is, if any. I don't recall seeing any and I'm sure I would have noticed. I think it'll mostly be dusty. The CPU, mobo, and RAM were owned by someone who's a retro PC enthusiast, so I imagine they took care of the components. 😀
OS: Windows 98 SE
Reply 5 of 38, by NeoG_
Have you done a min spec install where only the hdd, gpu, 1x ram, cpu and audigy card installed? (minimum required to install the sound card). If it freezes then with the BIOS at defaults in every PCI slot, it's going to be a low level issue
Reply 6 of 38, by asdf53
Does the freezing when installing the Audigy drivers happen randomly or always? If yes, it could be a separate issue.
As suggested above, keep connected hardware to the bare minimum. Keep the HPT controller disabled and unplugged. Run your HDD at minimum speed (disable UDMA in BIOS). Remove the Audigy card and use your ISA card, you seem to have had less problems with that. Change RAM sticks to different ones. Make sure your board isn't overclocked (you ran it at 133 MHz FSB before), make sure your PCI clock is set correctly in the BIOS. Use another PSU if you have. With all that, run your system for a couple of days and see if the problems persist. If yes, the motherboard is likely faulty. The problems you're having (HDD/CD-ROM issues, system not waking from sleep, random freezes with zero load, problems with PCI cards) would all tend to happen with a faulty chipset.
I have a board that randomly freezes and locks up, the mouse pointer movement is choppy, the HDD sometimes does not respond (takes 30 seconds to open a folder in explorer), random bluescreens with PCI cards installed. I have the same board twice, but none of that happens with the second board, using the same HDD with the same Windows installation.
Reply 7 of 38, by shevalier
What could go wrong with a 440BX + 133MHz FSB combination?
Anything.
Start by testing the memory.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 8 of 38, by DustyShinigami
NeoG_ wrote on 2025-11-25, 04:34:
No, but I can try that. The freezing only seems to happen after installing DirectX 9. However, I should point out, the DirectX version supplied with the modified audio drivers is DirectX 9.0a. I think on my previous build, I had 9.0c installed and never had any freezing issues. So I'm going to try that first and see if it freezes. Maybe there's an issue with 9.0a...?
Failing that, I'll try with just the bare minimum installed.
OS: Windows 98 SE
Reply 9 of 38, by DustyShinigami
asdf53 wrote on 2025-11-25, 06:22:
Only after DirectX 9.0a is installed. I've been able to install them no problem before. I always skipped the install of DirectX 9 out as I don't really want it, but as it was suggested I follow the guide exactly, it locks the system up at random. But always during the setup.
Doing a quick check, I have briefly seen others mention to stay away from DirectX 9.0a and b as they're only revised versions. Some have also reported freezes. They suggested regular 9.0 and 9.0c. So I'm going to try the latter first and see what happens. 😀
OS: Windows 98 SE
Reply 10 of 38, by Joseph_Joestar
DustyShinigami wrote on 2025-11-25, 11:43:
Just to clarify, DirectX 9.0a shipped on the official Audigy 2 ZS installation CD. This is why I included it in my guide, as the drivers presumably require that version at a minimum.
But as mentioned in step 3.2 of the guide, it's fine to use a newer version instead (e.g. DirectX 9.0c). Just don't go below 9.0a.
Reply 11 of 38, by DustyShinigami
Just tried DirectX 9.0c and the same thing happens. 🙁
EDIT: I've been reading mixed reports about DirectX 9 and Windows 98. Some saying they've had no issues, others saying the opposite. Personally, I'm inclined to give DirectX 9 a wide berth. Maybe some of my components are just too old to be supported by it...?
OS: Windows 98 SE
Reply 12 of 38, by DustyShinigami
Plot twist. I suspected this was going to happen. ^^; So even after installing DirectX 8.2, the same issue happens. So maybe it isn't DirectX 9 that's to blame after all. So there is something else a miss.
Will try the bare minimum components next.
OS: Windows 98 SE
Reply 13 of 38, by DustyShinigami
Results aren't promising so far. I've unplugged all extras. There's just the C drive connected to IDE 1, there's only one stick of RAM, CPU is connected, PSU connected, SB sound card, Geforce 4 Ti 4200, CD-ROM drive... No floppy drive, Gotec or USBs. I've reset the BIOS to defaults, though it asked for the 98 disc to reinstall the COM and printer port drivers. With that setup - it still froze. Tried again but with the HPT controller disabled and also reverted back to the first image I made, which was right after doing a clean install of Windows. Initially, it came up with this error:
The attachment IMG_5112.JPG is no longer available
Though after rebooting it was fine. Reinstalled DirectX 9 and ran through the installer again and it still locked up. 🙁
OS: Windows 98 SE
Reply 14 of 38, by asdf53
What happens when you try to install the drivers with the card removed? Or does it refuse to run then?
At this point, I'd connect all cards, PSU, and hard drive to another board and try again. If it doesn't happen there, it's the board.
Also, try moving the card to a different PCI slot if you haven't already in case it's a resource problem.
Reply 15 of 38, by DustyShinigami
asdf53 wrote on 2025-11-25, 19:29:
I imagine it would refuse, but I can certainly try. I'll try another PCI slot after. I think, looking at the manual, it's currently in slot 2...? I'll try each of them and then failing that, I'll revert to the test build.
I really hope the motherboard isn't failing though. Thankfully I have seen another that's pretty cheap. I might have to get it as a backup, just in case.
OS: Windows 98 SE
Reply 16 of 38, by DustyShinigami
Okay. Interesting. Progress. Took the sound card out, re-installed DirectX 9.0a, ran the driver setup, and it actually installed the drivers. 😮 No freezes or crashes. So, it could either be the sound card that's to blame or it could be the PCI slot.
OS: Windows 98 SE
Reply 17 of 38, by DustyShinigami
I will try re-installing the sound card a bit later and try one of the other PCI slots. However, I want to make doubly sure I'm fine to put it in one of the others. Checking the manual for my mobo, it does say this about the slots:
The attachment Acrobat_sZSyfhIiVm.png is no longer available
It mentions slot 2, which the card was in, shares IRQ signals with slot 5. Could that be the cause of these freezes...?
OS: Windows 98 SE
Reply 18 of 38, by DustyShinigami
Put the card back into PCI slot 2, reinstalled DirectX 9, ran the driver setup, it got to the end where it asks for you to restart - locked up again.
Will try putting it back to it's fresh install point and then try doing it again, but this time, skip the System Information utility. I remember the first time I installed that, it didn't work and kept giving me an Illegal Operation error until after the drivers were installed. Maybe that's causing it to bug-out.
After that, another PCI slot.
OS: Windows 98 SE
Reply 19 of 38, by DustyShinigami
It looks like my hunch was right. It's the Creative Information Utility. Just installed DirectX 9, skipped installing the utility and then installed the drivers. No crash.
EDIT: Spoke too soon. Got back to the desktop after restarting and it's locked up. Baffling.
EDIT 2: Frankly, I'm debating on selling this sound card and getting something a bit more period appropriate. This Sound Blaster has been nothing but a headache since I got it.
OS: Windows 98 SE
