First post, by KiasuKing
I have had a heart breaking few weeks.
My 100Mhz IBM Aptiva started playing up. I put a post on Vogons about it (in the WRONG forum - I was brand new and didn't know how to move it but it's here IBM Aptiva Pentium 100 troubleshooting) Initially nothing on the riser card was being detected (Voodoo 1 and a Sound card) then intermittent start up. I thought it was the on off switch, then the riser card, then the Motherboard, then the PSU. I have no clue. I purchased several trouble shooting tools which I have minimal skill at using but they are totaling up to more than buying a claimed to be working Socket 7 off ebay and building a new system.
I found someone selling new old stock of na M571 Socket 7 in my city. It seems to be a surprisingly common and well documented Mother board with lots of files and the original manuals easily found online. I picked it up on 3 days ago, brought it home and set it up using a brand new old school Antec AT PSU which I did test of the PSU to ensure it was within spec. Despite very carefully setting all of the jumpers, using PCI S3 trio i know is working, and setting the RAM voltage correctly it would not start up. I could see the fan on the CPU starting but nothing on screen. Then yesterday I realised the RAM should have been in the other 2 banks and just before lunch it booted! i could see the 100MHZ Pentium was correctly identified on screen.
"O frabjous day! Callooh! Callay!” Time for lunch.
After lunch I changed the CR2032 battery as it had shown it was low in the initial boot prior. Then booted with the expectation of heading into CMOS and having a great day of running various tests before putting into a case. BUT there was no display again. Played a bit with the RAM again as it seemed the earlier issue was there. Still no joy.
Then ... a crackle!!!!!! Power off immediately and a smell near the RAM where there are 2 capacitors. There are no burn marks there on the MB or the capacitors but it was enough to freak me out. I am using 2 sticks HP1818-6838 which are rated as 5V and the board jumpers are set to that.
But it now appears to be dead.
I LOATHE throwing old hardware away but lack the knowledge on how to troubleshoot. Looking at the number of items I have purchased from Aliexpress and Amazon to troubleshoot - without factoring in the cost of a future electronics degree so I know how to use them I want to ask:
What do other people here do when something you love has a problem that no one can fix? Throwing away a complete IBM Aptiva, as well as a new old stock Socket 7 motherboard just makes me die inside. Its a bit like a funeral and I am in mourning 🙁 I threw away my original Ensoniq Soundscape 2000 many years ago when it stopped working and was able to replace it with another before prices went into the stratosphere, but I have never really forgiven myself for tossing a semi rare card which might have been repairable.
What would you do?
Throw away and buy another off ebay?
