Reply 80 of 122, by Disruptor
- Oldbie
hydraphone wrote on 2025-12-02, 15:41:... AGP has it's own "lane" that is separate from the PCI.
It is not clear to me whether all PCI slots share the single 32-bit 33MHz interface or not, but if they do, that makes it clear that I need an AGP card for this build.
Again: AGP is another kind of parallel PCI bus, so we do not talk about serial lanes from PCIe. AGP bus and PCI bus are bridged by 440LX chipset. That means a PCI TV card can write into video memory of an AGP card without blocking the CPU for transfers.
Yes, all PCI slots use parallel address and data lines. However, some wires like the controls for INTA, INTB, INTC and INTD or the enumeration for PCI slots are different.
To not slow down the PCI bus and to achieve a faster transfer rate AGP bus had been invented. The Intel i740 graphics card also demonstrates how to deal with textures remaining in main memory due to insufficient amount of graphics RAM. Texture loading would have been a pain on PCI.
