Help with a 440LX build
Reply 80 of 138, by Disruptor
hydraphone wrote on 2025-12-02, 15:41:
... AGP has it's own "lane" that is separate from the PCI.
It is not clear to me whether all PCI slots share the single 32-bit 33MHz interface or not, but if they do, that makes it clear that I need an AGP card for this build.
Again: AGP is another kind of parallel PCI bus, so we do not talk about serial lanes from PCIe. AGP bus and PCI bus are bridged by 440LX chipset. That means a PCI TV card can write into video memory of an AGP card without blocking the CPU for transfers.
Yes, all PCI slots use parallel address and data lines. However, some wires like the controls for INTA, INTB, INTC and INTD or the enumeration for PCI slots are different.
To not slow down the PCI bus and to achieve a faster transfer rate AGP bus had been invented. The Intel i740 graphics card also demonstrates how to deal with textures remaining in main memory due to insufficient amount of graphics RAM. Texture loading would have been a pain on PCI.
Reply 81 of 138, by hydraphone
Disruptor, no need to be patronizing --I already put the word lane in quotes after seeing pages #2 and #10 of https://bitsavers.org/components/intel/_dataS … 43LX_199801.pdf from my previous post.
Yes, I know why AGP was introduced, I'm not GenZ, I was also there.
The reason I bought the PCI version of the card was because I was initially planning on using the upcoming version of ITX LLama which will have 1 PCI slot. But it got delayed, and I ended up buying 6ALX instead as a thanksgiving weekend project.
Reply 82 of 138, by Disruptor
I have looked into that datasheet too and i did not even found the word "lane". 😀
I know the problem with you buying the PCI version because I had a Mini-ITX system too in early 2000's. It was a SV25 / FV25 from Shuttle.
It had a single PCI slot where I used a TV card in. And the chipset has bridged it to its internal AGP bus with its internal chipset graphics.
btw. I'm early GenY.
Reply 83 of 138, by hydraphone
MattRocks, I did disable parallel and serial ports from the BIOS.
Unfortunately, disabling the FireWire device in the manager did not solve the problem in each case.
I will try the FireWire patches, thanks a lot for digging them up.
I wouldn't rule out a hardware fault on the Audigy card, the problem might be localized to FireWire circuitry with audio still present.
Reply 84 of 138, by hydraphone
Disruptor wrote on 2025-12-02, 17:24:
Yes, hence the quote-and-quote.
So far, I haven't seen any evidence that sound issues are caused by a bogged down PCI bus, especially given the fact that they continue happening at 640x480 16 color.
Reply 85 of 138, by MattRocks
The 32bit PCI slots:
  • share one bus and 100MB/s-133MB/s bandwidth, managed by the chipset.
  • are assigned different IRQs, by the PnP OS or BIOS (maybe influenced by chipset).
Your combined cards will be using between 2MB/s (likely) and 40MB/s (max load) of the PCI bandwidth, so the first bullet point is a non-issue.
Milestones [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i5) → x86-64(i7) ] * original lost
Reply 86 of 138, by douglar
When I have a system that appears stable in DOS but has various fleeting I/O issues in Windows 98 that come and go, it's often a RAM issue. Run https://www.memtest.org/ overnight. Sometimes memtest+ doesn't find the errors until it runs for 12+ hours.
Reply 87 of 138, by hydraphone
MattRocks, thanks a lot for this information!
That could be limiting down the road if I add a PCI SATA card into the mixture, and on top the potential IRQ issues, I think it will still be useful for me to get an AGP card to rule out potential hardware issues (PCI slots themselves/Audigy card).
Thanks douglar, I have also been thinking about that as well because the RAM sticks I have are also used. I need to figure out how to run memtest (since I have no FDD or CD-ROM), I will probably use the 86Box .img trick again.
Reply 88 of 138, by MattRocks
hydraphone wrote on 2025-12-02, 17:29:
MattRocks, I did disable parallel and serial ports from the BIOS. Unfortunately, disabling the FireWire device in the manager di […]
https://forums.anandtech.com/threads/acpi-vs- … tandard.285122/
The above adds weight to my recollections that Creative made crackly sound cards. My sincere honest view is that a little crackle is a positive sign because it proves the hardware DSP is activated (and operating within historically observed and reported parameters - even if some don't believe it). If you start from the positive crackly baseline, then give your DSP isolated IRQ and reduce its driver burdens to find a sweet spot with clearer audio then I'd say you win!
There is more to disable in the manager such as Creative SB16 Emulation - it's just layers of complexity and increases odds of IRQ conflicts. You may need to plod through each device in the manager to find IRQs, but you want Audigy DSP to have its own dedicated IRQ. Apparently PCI SLOT#3 is isolated on LX chipset, and you might find IRQ settings for PCI slots in the BIOS.
Reply 89 of 138, by MattRocks
hydraphone wrote on 2025-12-02, 18:50:
The IDE bus has its own dedicated 66-133MB/s bandwidth (depending on chipset) and I don't want to waste that. I did read warnings about bad IDE-SATA adapters, but I don't think that's universally true so I'm going to try IDE-SATA. Nothing to report yet because I'm still watching and lining my ducks up 😉
Reply 90 of 138, by hydraphone
MattRocks, I am actually more bothered by Windows randomly replaying previously played sounds, like the startup sound or menu right-click sounds or any previously played music.
I'm also looking forward to testing disk throughput once I get sound working normally and get an AGP card!
Reply 91 of 138, by hydraphone
Some more info from Linux
cat /proc/interrupts
CPU0
0: 316285 XT-PIC timer
1: 2358 XT-PIC i8042
2: 0 XT-PIC cascade
8: 0 XT-PIC rtc0
10: 0 XT-PIC firewire_ohci
11: 200000 XT-PIC uhci_hcd:usb1, snd_emu10k1
12: 167 XT-PIC i8042
14: 5441 XT-PIC ata_piix
15: 0 XT-PIC ata_piix
NMI: 0 Non-maskable interrupts
LOC: 0 Local timer interrupts
SPU: 0 Spurious interrupts
PMI: 0 Performance monitoring interrupts
IWI: 0 IRQ work interrupts
RTR: 0 APIC ICR read retries
RES: 0 Rescheduling interrupts
CAL: 0 Function call interrupts
TLB: 0 TLB shootdowns
TRM: 0 Thermal event interrupts
THR: 0 Threshold APIC interrupts
DFR: 0 Deferred Error APIC interrupts
MCE: 0 Machine check exceptions
MCP: 3 Machine check polls
ERR: 709
MIS: 0
PIN: 0 Posted-interrupt notification event
NPI: 0 Nested posted-interrupt event
PIW: 0 Posted-interrupt wakeup event
some highlights from dmesg
[   83.875060] PCI: setting IRQ 10 as level-triggered
[ 83.875110] firewire_ohci 0000:00:0a.2: found PCI INT B -> IRQ 10
[ 83.875110] firewire_ohci 0000:00:0a.2: sharing IRQ 10 with 0000:00:08.0
[ 83.932853] firewire_ohci 0000:00:0a.2: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2
[ 84.652560] irq 11: nobody cared (try booting with the "irqpoll" option)
[ 84.652710] CPU: 0 PID: 9 Comm: kworker/0:1 Not tainted 6.9.7-arch1-1.2 #1 00f4d872e619c93a2fd3dfaa7198b1045c00f8c9
[ 84.652753] Workqueue: 0x0 (firewire)
[ 84.652805] Call Trace:
[ 84.652825] <IRQ>
[ 84.652846] dump_stack_lvl+0x41/0x60
[ 84.652909] dump_stack+0xd/0x12
[ 84.652939] __report_bad_irq+0x38/0xa4
[ 84.652996] note_interrupt.cold+0xc/0x57
[ 84.653032] handle_irq_event+0x69/0x70
[ 84.653035] ? __irq_disable+0xa0/0xa0
[ 84.653035] handle_level_irq+0x7a/0x160
[ 84.653035] __handle_irq+0x52/0x90
[ 84.653035] </IRQ>
[ 84.653035] <SOFTIRQ>
[ 84.653035] __common_interrupt+0x36/0xb0
[ 84.653035] common_interrupt+0x2a/0x50
[ 84.653035] asm_common_interrupt+0x102/0x140
[ 84.653035] EIP: handle_softirqs+0x6e/0x250
[ 84.653035] Code: 64 a1 00 2a 3e d0 ba 00 01 00 00 e8 dc 3c 05 00 c7 45 e0 0a 00 00 00 89 75 e4 89 5d dc 31 c0 64 66 a3 14 2a 3e d0 fb 0f bc cf <75> 05 b9 ff ff ff ff 89 cb b8 80 70 15 d0 83 c3 01 74 78 89 c6 89
[ 84.653035] EAX: 00000000 EBX: 04208160 ECX: 00000001 EDX: 00000000
[ 84.653035] ESI: fffcb1e9 EDI: 00000002 EBP: c1113ff0 ESP: c1113fcc
[ 84.653035] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 EFLAGS: 00000206
[ 84.653035] ? handle_softirqs+0x6e/0x250
[ 84.653035] ? __lock_text_end+0x3/0x3
[ 84.653035] __do_softirq+0xf/0x13
[ 84.653035] do_softirq_own_stack+0x26/0x70
[ 84.653035] </SOFTIRQ>
[ 84.653035] irq_exit_rcu+0x72/0xb0
[ 84.653035] common_interrupt+0x2f/0x50
[ 84.653035] EIP: preempt_schedule_irq+0x29/0x60
[ 84.653035] Code: 00 3e 8d 74 26 00 64 f7 05 04 2a 3e d0 ff ff ff 7f 75 3e 9c 58 f6 c4 02 75 37 55 89 e5 64 ff 05 04 2a 3e d0 fb b8 01 00 00 00 <e8> 32 e5 ff ff fa 64 a1 00 2a 3e d0 64 ff 0d 04 2a 3e d0 8b 00 a8
[ 84.653035] EAX: 00000001 EBX: c116def0 ECX: 00000003 EDX: 00000000
[ 84.653035] ESI: 00000030 EDI: 00000000 EBP: c116dec4 ESP: c116dec4
[ 84.653035] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 EFLAGS: 00000202
[ 84.653035] ? preempt_schedule_irq+0x29/0x60
[ 84.653035] raw_irqentry_exit_cond_resched+0x30/0x40
[ 84.653035] irqentry_exit+0x1d/0x50
[ 84.653035] common_interrupt+0x38/0x50
[ 84.653035] EIP: _raw_spin_unlock_irq+0x16/0x30
[ 84.653035] Code: c3 8d 76 00 e8 33 12 00 00 5d 31 c0 31 d2 c3 2e 8d 74 26 00 3e 8d 74 26 00 55 89 e5 c6 00 00 8d 76 00 fb 64 ff 0d 04 2a 3e d0 <74> 08 5d 31 c0 31 d2 c3 66 90 e8 03 12 00 00 5d 31 c0 31 d2 c3 cc
[ 84.653035] EAX: dc9a9bc0 EBX: c110f200 ECX: 00000000 EDX: 00000000
[ 84.653035] ESI: dc9a9bc0 EDI: c110f228 EBP: c116df4c ESP: c116df4c
[ 84.653035] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 EFLAGS: 00000286
[ 84.653035] ? _raw_spin_unlock_irq+0x16/0x30
[ 84.653035] worker_thread+0x181/0x350
[ 84.653035] kthread+0xdb/0x110
[ 84.653035] ? rescuer_thread+0x3d0/0x3d0
[ 84.653035] ? kthread_complete_and_exit+0x20/0x20
[ 84.653035] ret_from_fork+0x38/0x60
[ 84.653035] ret_from_fork_asm+0x12/0x20
[ 84.653035] entry_INT80_32+0xf0/0xf0
[ 84.653035] handlers:
Show last 120 lines
[   84.653035] [<9bffe353>] usb_hcd_irq
[ 84.653035] Disabling IRQ #11
[ 134.756250] nvidiafb 0000:00:08.0: found PCI INT A -> IRQ 10
[ 134.760295] nvidiafb 0000:00:08.0: sharing IRQ 10 with 0000:00:0a.2
[ 134.769064] nvidiafb: Device ID: 10de0322
[ 134.770610] nvidiafb 0000:00:08.0: vgaarb: deactivate vga console
[ 134.775386] Console: switching to colour dummy device 80x25
[ 134.799241] nvidiafb: CRTC0 analog found
[ 134.806482] nvidiafb: CRTC1 analog not found
[ 135.363385] nvidiafb: EDID found from BUS1
[ 135.471423] i2c i2c-2: unable to read EDID block.
[ 135.628349] i2c i2c-2: unable to read EDID block.
[ 135.799098] i2c i2c-2: unable to read EDID block.
[ 135.849555] nvidiafb: CRTC 0 appears to have a CRT attached
[ 135.849616] nvidiafb: Using CRT on CRTC 0
[ 135.868065] fbcon: NV32 (fb0) is primary device
[ 136.060117] Console: switching to colour frame buffer device 240x67
[ 136.095408] nvidiafb: PCI nVidia NV32 framebuffer (64MB @ 0xD0000000)
[ 139.298974] snd_emu10k1 0000:00:0a.0: found PCI INT A -> IRQ 11
[ 139.299076] snd_emu10k1 0000:00:0a.0: sharing IRQ 11 with 0000:00:07.2
[ 140.099050] irq 11: nobody cared (try booting with the "irqpoll" option)
[ 140.099050] CPU: 0 PID: 265 Comm: (udev-worker) Not tainted 6.9.7-arch1-1.2 #1 00f4d872e619c93a2fd3dfaa7198b1045c00f8c9
[ 140.099050] Call Trace:
[ 140.099050] <IRQ>
[ 140.099050] dump_stack_lvl+0x41/0x60
[ 140.099050] dump_stack+0xd/0x12
[ 140.099050] __report_bad_irq+0x38/0xa4
[ 140.099050] note_interrupt.cold+0xc/0x57
[ 140.099050] handle_irq_event+0x69/0x70
[ 140.099050] ? __irq_disable+0xa0/0xa0
[ 140.099050] handle_level_irq+0x7a/0x160
[ 140.099050] __handle_irq+0x52/0x90
[ 140.099050] </IRQ>
[ 140.099050] <SOFTIRQ>
[ 140.099050] __common_interrupt+0x36/0xb0
[ 140.099050] common_interrupt+0x2a/0x50
[ 140.099050] asm_common_interrupt+0x102/0x140
[ 140.099050] EIP: handle_softirqs+0x6e/0x250
[ 140.099050] Code: 64 a1 00 2a 3e d0 ba 00 01 00 00 e8 dc 3c 05 00 c7 45 e0 0a 00 00 00 89 75 e4 89 5d dc 31 c0 64 66 a3 14 2a 3e d0 fb 0f bc cf <75> 05 b9 ff ff ff ff 89 cb b8 80 70 15 d0 83 c3 01 74 78 89 c6 89
[ 140.099050] EAX: 00000000 EBX: 00400140 ECX: 00000001 EDX: 00000000
[ 140.099050] ESI: fffd8a3a EDI: 00000002 EBP: c1113ff0 ESP: c1113fcc
[ 140.099050] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 EFLAGS: 00000206
[ 140.099050] ? __irq_alloc_descs+0x2db/0x320
[ 140.099050] ? handle_softirqs+0x6e/0x250
[ 140.099050] ? __lock_text_end+0x3/0x3
[ 140.099050] __do_softirq+0xf/0x13
[ 140.099050] do_softirq_own_stack+0x26/0x70
[ 140.099050] </SOFTIRQ>
[ 140.099050] irq_exit_rcu+0x72/0xb0
[ 140.099050] common_interrupt+0x2f/0x50
[ 140.099050] EIP: preempt_schedule_irq+0x29/0x60
[ 140.099050] Code: 00 3e 8d 74 26 00 64 f7 05 04 2a 3e d0 ff ff ff 7f 75 3e 9c 58 f6 c4 02 75 37 55 89 e5 64 ff 05 04 2a 3e d0 fb b8 01 00 00 00 <e8> 32 e5 ff ff fa 64 a1 00 2a 3e d0 64 ff 0d 04 2a 3e d0 8b 00 a8
[ 140.099050] EAX: 00000001 EBX: c2d7fad8 ECX: 00000003 EDX: 00000000
[ 140.099050] ESI: 00000030 EDI: 00000000 EBP: c2d7faac ESP: c2d7faac
[ 140.099050] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 EFLAGS: 00000202
[ 140.099050] ? preempt_schedule_irq+0x29/0x60
[ 140.099050] raw_irqentry_exit_cond_resched+0x30/0x40
[ 140.099050] irqentry_exit+0x1d/0x50
[ 140.099050] common_interrupt+0x38/0x50
[ 140.099050] EIP: _raw_spin_unlock_irqrestore+0x1d/0x40
[ 140.099050] Code: e8 b0 18 00 00 31 c0 5d 31 d2 31 c9 c3 3e 8d 74 26 00 55 89 d1 89 e5 c6 00 00 8d 76 00 80 e5 02 74 01 fb 64 ff 0d 04 2a 3e d0 <74> 11 5d 31 c0 31 d2 31 c9 c3 2e 8d b4 26 00 00 00 00 90 e8 73 18
[ 140.099050] EAX: c110ee70 EBX: c110ee00 ECX: 00000282 EDX: 00000282
[ 140.099050] ESI: c3ecd5c0 EDI: c3e05040 EBP: c2d7fb34 ESP: c2d7fb34
[ 140.099050] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 EFLAGS: 00000286
[ 140.099050] ? _raw_spin_unlock_irqrestore+0x1d/0x40
[ 140.099050] __setup_irq+0x2f5/0x5f0
[ 140.099050] request_threaded_irq+0xc1/0x190
[ 140.099050] devm_request_threaded_irq+0x54/0xb0
[ 140.099050] ? snd_emu10k1_resume_regs+0xe0/0xe0 [snd_emu10k1 3249cfd8d98bb8ec94b1471be92d0cf61aa675c9]
[ 140.099050] snd_emu10k1_create+0x429/0x720 [snd_emu10k1 3249cfd8d98bb8ec94b1471be92d0cf61aa675c9]
[ 140.099050] snd_card_emu10k1_probe+0xd1/0x3c0 [snd_emu10k1 3249cfd8d98bb8ec94b1471be92d0cf61aa675c9]
[ 140.099050] pci_device_probe+0xa3/0x190
[ 140.099050] really_probe+0xc2/0x310
[ 140.099050] ? pm_runtime_barrier+0x51/0x90
[ 140.099050] __driver_probe_device+0x71/0x140
[ 140.099050] driver_probe_device+0x1f/0xb0
[ 140.099050] __driver_attach+0xb7/0x1c0
[ 140.099050] ? __device_attach_driver+0x110/0x110
[ 140.099050] bus_for_each_dev+0x62/0xb0
[ 140.099050] driver_attach+0x19/0x20
[ 140.099050] bus_add_driver+0xe6/0x1c0
[ 140.099050] ? pci_bus_num_vf+0x20/0x20
[ 140.099050] driver_register+0x6d/0xd0
[ 140.099050] __pci_register_driver+0x41/0x50
[ 140.099050] ? 0xe0dd2000
[ 140.099050] emu10k1_driver_init+0x1c/0x1000 [snd_emu10k1 3249cfd8d98bb8ec94b1471be92d0cf61aa675c9]
[ 140.099050] do_one_initcall+0x40/0x2b0
[ 140.099050] ? kfence_guarded_free+0x125/0x200
[ 140.099050] ? kmalloc_trace+0xfe/0x2f0
[ 140.099050] ? do_init_module+0x21/0x1f0
[ 140.099050] do_init_module+0x55/0x1f0
[ 140.099050] load_module+0x17da/0x19e0
[ 140.099050] init_module_from_file+0x71/0xb0
[ 140.099050] __ia32_sys_finit_module+0x11b/0x280
[ 140.099050] ia32_sys_call+0x1b63/0x21d0
[ 140.099050] do_int80_syscall_32+0x52/0x90
[ 140.099050] ? get_stack_info+0x140/0x140
[ 140.099050] ? enable_8259A_irq+0x5c/0x70
[ 140.099050] ? handle_level_irq+0xa2/0x160
[ 140.099050] ? irqentry_exit_to_user_mode+0x63/0x180
[ 140.099050] ? irqentry_exit+0x45/0x50
[ 140.099050] ? common_interrupt+0x38/0x50
[ 140.099050] entry_INT80_32+0xf0/0xf0
[ 140.099050] EIP: 0xaf4d65d2
[ 140.099050] Code: f0 ff c3 66 90 66 90 90 55 57 56 53 8b 6c 24 2c 8b 7c 24 28 8b 74 24 24 8b 54 24 20 8b 4c 24 1c 8b 5c 24 18 8b 44 24 14 cd 80 <5b> 5e 5f 5d 3d 01 f0 ff ff 0f 83 1f d0 f0 ff c3 66 90 66 90 66 90
[ 140.099050] EAX: ffffffda EBX: 00000022 ECX: af5de3f4 EDX: 00000004
[ 140.099050] ESI: 113bc810 EDI: 113b3c70 EBP: bf9f5f28 ESP: bf9f5ecc
[ 140.099050] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 007b EFLAGS: 00000292
[ 140.099050] handlers:
[ 140.099050] [<9bffe353>] usb_hcd_irq
[ 140.099050] [<09cb4f32>] snd_emu10k1_interrupt [snd_emu10k1]
[ 140.099050] Disabling IRQ #11
[ 140.109981] snd_emu10k1 0000:00:0a.0: Installing spdif_bug patch: SB Audigy 2 ZS [SB0350]
Reply 92 of 138, by hydraphone
So far, I haven't been able to reproduce any of the sound issues on Linux.
No X11 yet, so far. nouveau refuses to load, because it depends on wmi, which claims no device, might be related to ACPI issues.
[    0.058175] ACPI: Early table checksum verification disabled
[ 0.066161] ACPI BIOS Error (bug): A valid RSDP was not found (20230628/tbxfroot-222)
nvidiafb thinks it's connected to a CRT. LCD doesn't like the signal by vesa (with nomodeset) or fbdev with automatically detected settings by X11. Might try to figure out the correct modeline info for it, but it's probably not worth it. Planning to buy an actual CRT soon, should work with it automatically.
Reply 93 of 138, by hydraphone
MattRocks wrote on 2025-12-02, 11:25:
Using Archive.org I was able to download "something" from the URL that claims to combine all the Win98SE Firewire+USB patches.
There are a few captures to explore: https://web.archive.org/web/20170904074655/ht … om/spx/NUSB.EXE
Attached whatever landed in my Downloads folder. Use at your own risk: I cannot promise this works. I haven't used it myself - and I haven't even tried to extract it so to check this isn't just a HTML broken link error!
Tried it, and re-enabled the FireWire device. Unfortunately, it freezes at Windows splash screen as usual.
Reply 94 of 138, by MattRocks
hydraphone wrote on 2025-12-02, 20:59:
That screams of IRQ sharing. Win98 assumes ACPI (virtual and shared IRQs) is safe. ACPI solved one problem where devices fight over IRQs (infamous Win95 IRQ conflicts), and ACPI creates the problem of denying devices an isolated IRQ when they need one. Your Audigy definitely needs its own IRQ.
Here's the cleanest ACPI next step I found, with a foretelling of what to expect immediately afterwards..
Re: Windows 98se reboots on shutdown
Reply 95 of 138, by hydraphone
That sounds promising, I gave it a try, but it didn't seem to have any effect. I tried rebooting, but none of the devices were removed. I manually removed the Audigy components + USB + NVIDIA, followed by reboots, and the devices got added with their old configuration. The PCI to USB Universal Host Controller and the Creative Audigy Audio Processor still both use IRQ 11 for example.
I also tried to add ACPIOption as string but no luck. Did I miss doing something?
Reply 96 of 138, by hydraphone
I noticed that in the device manager, under System devices, I see "Advanced Power Management Support" and no mention of ACPI, so it appears I never had ACPI on in the first place?
I don't see it in the BIOS or the motherboard's manual either, so it appears this is an APM only PC.
Reply 97 of 138, by hydraphone
Put Audigy in PCI slot #1 (and skipping over FireWire detection), and NVDIA in #2: sound works flawlessly, NVIDIA is again stuck at 640x480 at 16 colors, any changes results in reboot/locks...
Adding FireWire results in immediate reboot/lockup.
Reply 98 of 138, by hydraphone
Minor progress.
After an hour of mindless fiddling around with the BIOS options and PCI slot arrangements (at some point, I manually disabled some IRQs and manually assigned IRQs to slots from BIOS, and then reverted the settings), both sound and video (1280x720@32bpp) worked fine... until Windows froze after playing music for about a minute. Reboot and same thing happening again.
NVIDIA at PCI slot #1, Audigy at #4. Windows assigned IRQ #10 to both NVIDIA and Audigy, and USB Universal Host Controller got #11.
Switched the resolution to 1024x768@16bpp, still locking up in a minute or so.
Tried disabling the USB Universal Host Controller from the device manager, 5 minutes of music and no lock ups so far. I lost the USB inputs now, but well, that's so far the longest I enjoyed this PC!
Reply 99 of 138, by shevalier
hydraphone wrote on 2025-12-03, 04:57:
Congratulations!
Before starting a long gaming session (especially in games without auto-save), I would check the stability.
It seems that 3DMark 2003 does not require SSE instructions.
Run the looped test for an hour with GPU+CPU+60 sounds.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
