Reply 30520 of 31039, by RetroBus
sunkindly wrote on 2025-12-04, 03:11:
RetroBus wrote on 2025-12-04, 02:01:
Installed the first OS's I used on my 486 days, DOS 6.22 and Windows 3.11 on my Pentium 166 MMX marketplace find 😀
https://www.youtube.com/watch?v=hTqsrdVkqdA
The hot glue thing is wild to me. Is it only superficial at this point or is it actually still preventing you from disconnecting the cables?
It is only superficial, the plugs did come out without much issue, feels like they used it more like a warranty seal sticker. The Keyboard was made for Australia by Honeywell, so I wonder if that's why the configuration was a little different.
https://www.youtube.com/@ComputerRetroBus Computer Retro Bus - My Youtube Chanel
Reply 30521 of 31039, by sunkindly
Upgraded the RAM to 384MB for the Indigo2, which was the max supported for the R4000/4400 variants.
These machines are supposedly super picky about compatibility and it wasn't cheap so anxiety was high, but all is well so far.
The attachment IMG_8151.jpg is no longer available
The attachment IMG_8157.jpg is no longer available
The attachment IMG_8189.jpg is no longer available
SUN85: NEC PC-8801mkIIMR
SUN92: Northgate Elegance | 386DX-25 | Orchid Fahrenheit 1280 | SB 1.0
SUN97: QDI Titanium IE | Pentium MMX 200MHz | Tseng ET6000 | SB 16
SUN00: ABIT BF6 | Pentium III 1.1GHz | 3dfx Voodoo3 3000 | AU8830
Reply 30522 of 31039, by Aui
Today I started looking at an old Compaq590. Naturally I was expecting to find a Socket 5 Pentium 90. What I found instead was quite amazing:
The attachment K6-2 333.jpg is no longer available
A K6-2 333 on a Socket 5 Board. This is quite a speed upgrade to the original - nice.
Reply 30523 of 31039, by marxveix
Upgraded ct-6esa2 matx (440ex) cpu to Celeron 533 with slot1 to socket370 converter.
https://theretroweb.com/motherboards/s/chaintech-ct-6esa2
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 30524 of 31039, by H3nrik V!
sunkindly wrote on 2025-12-04, 22:11:
Upgraded the RAM to 384MB for the Indigo2, which was the max supported for the R4000/4400 variants. […]
That picture of all that RAM installed is close to wallpaper worthy!
Reply 30525 of 31039, by H3nrik V!
PcBytes wrote on 2025-12-04, 00:00:
Tried getting a V2 12MB to work. […]
Can tell 3d works fine... but I only get a very dark blue-ish polarized image using my NEC Multisync monitor.
I'm stumped... is this a RAMDAC, or a FBI issue?
Photo below. Supposed to be the NFS5 Porsche Unleashed main menu, as I have set the game to use the Voodoo 2 instead of the main GPU (ed Prophet II GTS Pro 64MB.
file.php?mode=view&id=232134
Only things I have not done:
- reflow FBI pins (it's the only chip I haven't touched)
- reflow all RAM chips (which I've done on a 4MB original Voodoo, which I unfortunately suspect of bad RAM on FBI - at least I know where to find donors 🤣 (S3 Trio, Rage IIC, any old cards using PCI.)
I guess making a new thread would yield a lot more info - it tends to "drown" in this thread.
Reply 30526 of 31039, by MattRocks
Aui wrote on 2025-12-05, 08:31:
That is amazing. I was tempted to start a competition thread: Take any motherboard (any era), what is the most recent game you make playable on it?
Score = (game_release_year - motherboard_release_year) * democratic_vote.
Your Compaq would be in a good place!
Reply 30527 of 31039, by GigAHerZ
GigAHerZ wrote on 2025-10-31, 09:44:
Printed some RAM holders for my SDR/DDRx and So-DIMM memories. Used this one: https://www.thingiverse.com/thing:4847265/files […]
Used this one:
For top piece, i just used slicer to set an area that has no walls and no infill. Result is cut off poles for the top piece.
Now i need to desing similar thing on my own for 72pin and 30pin ram sticks...
And I've learned the tools and designed similar frames to 30pin and 72pin ram sticks.
I did use OpenSCAD for this, but it became extremely slow so i have built the same thing using JS-based ManifoldCAD in VSCode: https://marketplace.visualstudio.com/items?it … scode-extension
They came out so well that i probably want to use my design for the SO-DIMM/SDRAM organization and print those to replace the current ones...
Reply 30528 of 31039, by PcBytes
H3nrik V! wrote on 2025-12-05, 08:59:
I did fix that issue - R25 was broken. Now I just need to figure out where it's slightly artefacting from.
Reply 30529 of 31039, by PC@LIVE
Very nice 😍 congratulations
I don't know if you can change the VCORE, if you can the maximum would be a K6-2+, with the multi 2X it would automatically go to 400, and the integrated cache L2 at the same frequency, should give a nice increase in performance, however, it must be said that the FSB should be raised to 66 MHz from the 60 of the P90, because otherwise 😅 it would go to 360 MHz instead of 400.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 30530 of 31039, by Dan386DX
My latest socket 462 motherboard arrived, the seller just happened to not mention that about half the caps are like this…
I’ve not seen leakage this colour before, normally the plague is kind of a dark, crusty brown.
At first I thought this might just be dried flux or something.
But actually, these are kinda domed and probably need changing anyway 😫
90s PC: IBM 6x86 120Mhz. 128MB/6GB. ATI Rage Pro 3D.
Boring modern PC: R9 3900X, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
Reply 30531 of 31039, by zuldan
GigAHerZ wrote on 2025-12-05, 14:19:
And I've learned the tools and designed similar frames to 30pin and 72pin ram sticks. […]
Used this one:
Those look great. Where can I download your 30pin and 72pin version for printing?
Reply 30532 of 31039, by PcBytes
Dan386DX wrote on 2025-12-05, 20:38:
My latest socket 462 motherboard arrived, the seller just happened to not mention that about half the caps are like this… […]
I've seen Chemicon KZGs bulge and barf and their colour is spot on to how you've described. They're to be replaced anyways.
Reply 30533 of 31039, by GigAHerZ
zuldan wrote on 2025-12-05, 20:51:
Used this one:
I'm currently working on getting them up into thingiverse. Just made an account and it seems i have to wait 24h before i can publish anything.
Reply 30534 of 31039, by Ozzuneoj
This has been over the past few weeks, but I have been on a roll when it comes to getting weird old devices working. These have all been set aside for repair, some for up to seven years.
In order of when I worked on them:
1. Yuan JRS-3DS100 - Nvidia NV1 2MB PCI - Reflowed all chips, fixed several broken SMD components (replaced all electrolytics a few years ago) - Result = 100% working card!
2. CyberRex 128 VR - Avance Logic ALG25128 4MB PCI - Reflowed all chips, replaced soldered memory chips, replaced some SMD components - Result = 80% working card! (artifacts at very high refresh rates and resolutions, but totally fine otherwise)
3. Aristo\Bannsan BS-5 - Alliance AT3D 4MB PCI - Replaced all electrolytic caps years ago; Found broken solder joints with microscope and reflowed them two days ago; installed least buggy driver version - Result = 100% working card! ... well 100% as far as what an AT3D can do. It is still buggy in games but overall works great!
4. Britec Viewtop BP-S3Ax - S3 Trio64v+ 4MB PCI (All Socketed)
- Uncommon card that is good for testing memory chips since all are socketed; replaced a bad memory chip and discovered a compatibility issue with my 440BX tester PC (not sure if software or hardware yet) - Result = 100% working card! (In a different PC...)
5. & 6. Artist Graphics Artist 2000\Netvision 2000 - Artist Graphics 3GA 2MB PCI - Two identical cards; one needed a broken SMD component replaced; Neither worked properly in Windows with any drivers I tried... until I tried the latest "Netvision" drivers that apparently work perfectly! Result = 2 x 100% working cards!
Here is a random assortment of things I have learned over the past few weeks:
Buy a binocular microscope! It is worth it. So is a hot air station. Build proficiency with those tools. Learn to use flux and solder paste.
When inspecting cards: always always check for bent or shorted pins\legs on chips before powering the device on.
If there is a problem, check for damaged components (look for scratches or scuffs and then follow their path); test for loose chip legs with a microscope (5x power) and a sewing needle; check for broken solder joints even on SMD components like SOJ memory (the gap may be visible from the side).
Visual artifacts that pop up and go away when touching a chip or PCB may be a loose\floating leg on a memory chip. Don't assume that tiny SMD components are okay. Capacitors and resistors can be physically broken or cracked in a way that breaks a circuit even if both ends of the component are still attached to the PCB.
Don't forget to clean flux from card edge connectors before testing them. Flux likes to get everywhere and leave a nasty coating, especially after you've tried cleaning it up with alcohol. This will prevent a card from getting good contact in the slot, which may lead you to believe it is the same or worse off than before you repaired it.
... there are many many other things, but that's a good start. I'm not sure which card is next on the list, but I know I have more that have been on the "need repaired" list for years.
Reply 30535 of 31039, by fosterwj03
You could call me a bit of a masochist, but while installing various Operating Systems to test the functionality of my first 386DX build with only 8MB of RAM currently installed, I got Windows NT 3.51 running on the system with almost no effort. I was shocked that the NT installer didn’t complain that the system didn’t meet the minimum memory requirement for NT 3.51 (12MB). It happily copied the files to the hard drive from the CD-ROM and booted right into the GUI portion of setup.
Ultimately, I want to use a Cyrix 486DLC, 87DLC coprocessor, and 32MB of RAM on this motherboard for my project, but I’m having a lot of fun already just putting the AMD 386DX-40 though its paces. Here are the current specs of the build (runs pretty well):
- Biostar MB-1333AEA-Q
-- AMD 386DX-40
-- 8MB of FPM RAM (70ns)
-- 256KB Cache (20ns)
- Generic ISA Winbond Super I/O controller for Serial, Floppy, and Primary IDE
-- Western Digital 80GB IDE Hard Drive (temporary)
-- GOTEK Floppy Emulator
- Future Domain IDE-16011 for Secondary IDE
-- Hitachi 16x CD-ROM Drive (temporary)
- Diamond Speedstar Pro ISA (CL-GD5429)
- MediaVision Pro Audio Spectrum 16 (PAS16-SL)
- DTC1181 Option ROM Card (for drives up to 8GB)
- Voltage Blaster
Reply 30536 of 31039, by myne
Crazy how fast it runs, isn't it?
I played around years ago but with 16mb.
Microsoft could learn a few tricks.
I built:
Reply 30537 of 31039, by fosterwj03
I like NT 3.51 for its stability and the retro Windows interface. I didn't use NT as my daily driver OS until NT 4.0, though. I've learned to appreciate NT 3.51 in later years.
I will say that the GUI is reasonably snappy on the 386 even with 8MB of RAM (I'm not editing huge spreadsheets or hundred-page PowerPoint slides). Apps load in a second or two. I would say that the ISA bus is really holding the system back. It takes about 2 minutes to boot from power-on to the usable desktop on a modern IDE hard drive, and the ISA video card (even a relatively fast 2D accelerator) takes a bit of time to redraw the screen at 1024x768, 256 colors.
Reply 30538 of 31039, by GigAHerZ
Used this one:
Behold, it has been published!
https://www.thingiverse.com/thing:7223953
Reply 30539 of 31039, by zuldan
GigAHerZ wrote on 2025-12-06, 23:46:
That's great. They will be really handy for storing my stock. Thank you for your time with this. I've grabbed a copy.
