First post, by liverygone
Hi everyone,
I’m building a retro Slot 1 PC using an ABIT BE6 (non-II) motherboard, and I want to use a Pentium III-S Tualatin 1.4 GHz CPU. Since the Tualatin is Socket 370, I need an adapter to fit it into the Slot 1 board.
The vintage Slotkets are very expensive, so I’m thinking about making a custom adapter PCB. I don’t know all the intricate technical details — I mostly know:
The Tualatin CPU needs lower voltage than Coppermine Slot 1 CPUs
I need a way to safely map it to the Slot 1 connector
I want it to be stable and reliable
I’d really appreciate advice on:
Can a custom PCB adapter be made safely for Tualatin → Slot 1?
Any tips on voltage adjustment or protecting the CPU?
Examples of anyone who has done something similar (photos, pinouts, schematics)?
General advice for someone new to this, so I don’t damage my CPU or board
Thanks in advance — any help or guidance would be amazing!
— liverygone
Reply 1 of 32, by liverygone
oh also forgot to mention, i am going for high end oc.
Reply 2 of 32, by liverygone
Also i obviously don't mind soldering
Reply 3 of 32, by RetroPCCupboard
The amount of time and effort to do that would seem to make it more expensive, and risky, than just buying one. Unless you want the challenge of course.
Reply 4 of 32, by liverygone
RetroPCCupboard wrote on 2025-12-04, 20:18:
of course i do lel
Reply 5 of 32, by paradigital
I can take high-res photos and do toning out of pins on my PowerLeap iP3-T if required, but I’ve never done any reverse engineering before.
Reply 6 of 32, by myne
See sig.
I don't have a ready design, but I do have ways to convert boardviews into kicad and there are plenty of leaked boards to choose slot 1 and socket 370 from.
You'll also do well to acquaint yourself with the bx schematic, and various cpu/chipset datasheets.
One free tip : as far as I know, NONE of the slotkets ever bothered changing the main agtl voltages down to 1.25v. 1.5 was fine.
I built:
Reply 7 of 32, by myne
This might help.
slot1 (Klamath), and s370 symbols/footprints should be in there, but I haven't looked in a while.
Just remember there are 2 versions of slot1, and 3 versions of s370.
I built:
Reply 8 of 32, by H3nrik V!
myne wrote on 2025-12-05, 07:39:
Don't some of them have voltage clamps on agtl voltages?
Reply 9 of 32, by shevalier
H3nrik V! wrote on 2025-12-05, 09:01:
Thousands of motherboards have been working with Tualatin for two decades without any problems.
However, their insufficient speed causes problems - there are corresponding threads ‘works at 100 MHz, does not work at 133.’
Unnecessary entity.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 10 of 32, by PC@LIVE
So if I understand correctly, you want to use a Tualatin with a Slot1 adapter, here for me you can get a normal Slot1-370 adapter for Coppermine, and you can make a simple change to the adapter, to make the Tualatin CPUs work.
If instead you don't want to change the adapter, you can modify the CPU, personally I wouldn't do it, but it's possible to do it without cutting any PIN, just cover the PIN to isolate it.
A fairly cheap solution is the Korean PCB, which you find in the auction portal, you can start from that, and get an interposer, so you can keep the CPU without modifying it, and it should work on most 370 motherboards, and via normal adapter also on Slot1.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 11 of 32, by myne
Some signals definitely changed from 2or 3v to 1.5 iirc and they definitely have to be reduced, but the main bus is fine at 1.5.
It's a lot of fun going through datasheets playing spot the difference - but there is one datasheet that explains how to make a "universal s370"
Btw, in theory, an adapter can be made for s775 cpus. The main signals are all the same, and some early p4 laptop mobos had a 4:1234 clock divider for one of the cpu/chipset to allow p3 and p4 chips on board variants.
Yep, in theory a core 2 could function on a bx at 1/4 of its speed.
I built:
Reply 12 of 32, by shevalier
myne wrote on 2025-12-06, 01:46:
There is a 2.5V power input for Pentium 2, which is not used on Pentium 3 Coppermine/Tualatin (1.5V= Vtt).
It's just a jumper or processor PCB routing.
There is no need to shift anything in terms of level or limit anything.
Otherwise, there would be no first revision Celeron Coppermine 533A, which ran on unmodified Mendocino-only boards.
liverygone wrote on 2025-12-04, 17:14:
As far as I remember, some early revisions of these motherboards, despite supporting voltages starting at 1.25V, have problems starting up.
Most likely, there are nuances with the CPU VID`s overdrive circuits.
There are two logic chips near the monitoring IC that do this.
If you figure them out, then most likely the entire modification of the board for starting Tualatin will boil down to cutting the wire, soldering the wire,
Reply 13 of 32, by myne
There are a few that matter if the universal 370 board datasheet is to be believed. I read most of it at year or 2 ago.
Tualatins especially changed quite a few levels.
I built:
Reply 14 of 32, by shevalier
myne wrote on 2025-12-06, 06:37:
There are a few that matter if the universal 370 board datasheet is to be believed. I read most of it at year or 2 ago. […]
The author of the topic will tell us about this when he finishes reading the datasheet to the right place. 😀
The 5th harmonic of 133 (150 for OC) MHz is already half a gigahertz, which is impressive.
Here, impedance matching and line length matching are already needed.
So he will still have to read the datasheets.
Officially, yes.
But an officialy Tuallatin with 440BX should never work under any circumstances.
Slightly off-topic.
Twenty years ago, there were discussions about the VTT at 440BX. For some, reducing it to 1.3V helped ensure stable operation.
https://www.tipperlinne.com/p2b-dsvtt.htm
Then there was a thread here, not verbatim.
Dudes, it turns out that ASUS regulates the VTT voltage with a BJT transistor.
If the transistor is with low H21 gain, there is not enough output current.
The VTT starts to drop significantly under load.
But the theory that Tualatin with 1.5V VTT does not work stably has already spread, alas.
"Change Q8 from 2sd1802 to RFD3055
Best Regards,
ASUSTeK Technical Support Division"
https://www.eecis.udel.edu/~portnoi/asusreworkguide.html
Reply 15 of 32, by myne
There's more than VTT.
A bunch of the lesser signals changed at some point.
EG the 5 or so signals from the southbridge/pci bus.
I built:
Reply 16 of 32, by shevalier
myne wrote on 2025-12-06, 07:31:
P2B Pentium® II/Celeron™ Motherboard
and
search.php?keywords=p2b++Tualatin
Moreover, this has been working since the release of Tualatin.
This is an unnecessary entity
- increasing the cost of BOM
- leading to development and assembly errors
To begin with, just simply need to copy a simple, bug-free slotket.
Reply 17 of 32, by myne
MS-6905 slotket V2.3 works fine, V2 only at 100MHz
https://www.google.com/search?sca_esv=fc456dd … ih=705&dpr=2.63
You'll note ALL the major brands had a chip on their Tualatin slotkets
But ok, you know it all
I built:
Reply 18 of 32, by kaputnik
Doesn't the ABIT BE6 have the "BIOS Soft Menu"?
As long as the VRM can output the required voltage, you could probably get away with doing the classic 4 pin mod (remove AN3, AK4 and AJ3 pins and cut AK4 trace to edge connector + bridge AN11- AK4) on any cheap generic Coppermine slotket and setting Vcore from menu.
DIYing a slotket from scratch would be a quite the enterprise anyways...
Reply 19 of 32, by shevalier
kaputnik wrote on 2025-12-06, 10:16:
In order to access the Soft menu, you need to get voltage on the CPU.
But there isn't any. 😀
The first revisions of these boards did not set the CPU start-up voltage correctly at launch.
They sounded a siren and shut down after 10 seconds.
PS. They feature an advanced monitoring microchip from TI, which compares the CPU supply voltage with the VIDs.
If the difference is more than 5%, the system shutdown.
And the VIDs are overridden by some two discrete logic IC.
At startup, the VIDs and the resulting voltage do not match.
