First post, by bakemono
I run Windows 2000 on newer AMD boards so I needed a program to handle CPU power management, overclocking, and whatnot. So I made one.
edit:
Tested OS: Windows 2000 with extended kernel, and Windows 7 64-bit.
Tested CPU: Athlon X4 760K (Richland), Athlon II X2 280 (Regor), FX-770K (Kaveri), Ryzen 1500X, Ryzen 3500X, Ryzen 5800X
The usual disclaimers apply: there is NO warranty, overclocking can make your PC burst into flames, etc.
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 2 of 2, by bakemono
Update with Ryzen support (except voltage adjustment). Can now be minimized to the system tray.
