First post, by reale00
So for SNES and PS1 games I’ve set up CRT Royale to have chunky scan lines as they should be, at a thickness of 9 on a 2160p display. What I’m wondering though is if should I be disabling scanlines completely for gamecube and ps2 games since they used the full 480p or 480i resolution for a faithful representation of a CRT? Or do I still want to have thinner scanlines at around 4 thickness?
Reply 1 of 5, by leileilol
You'd still have scanlines there. 480i is pretty much 240 lines swapping rapidly, and Gamecube and PS2 games have variable methods to de-flicker (with buffer effects) to smoothen this out on the software side (though not all of them - early PS2 games are notorious for flickering).
I personally just use a NTSC shader and live with that. It could have a CRT shader over it (crt twitter going into shaders often forget the signal part) but i'm on 1080p and i'd rather keep the 'tv capture card experience'.
Debian's fucked
Reply 2 of 5, by theelf
I have yet to see a consumer CRT in sizes 14-21" (the most common ones) that is easy to appreciate scanlines in progressive content
Reply 4 of 5, by CRTARTBooks
There might be scanlines in theory but in practice your eye won't register them. So it's up to you whether you'd like the 240p look on 480i games. Some shader would be recommended anyway, since CRTs are not just about scanlines but many other things like dithering, glow, etc.
On that note, the modern "chunky" (and isolated) scanline look is hugely overrated, since in real life these mostly appear on >600TVL PVMs and nobody used them back in the day to play games. Depending on a type of your TV or even monitor you'd get some, sure, but they would be much subtler and also be inseparable from shadow/slot masks.
Beyond Nostalgia - retro news & views presented in CRT-vision
CRT ART Books - retro gaming books with authentic CRT photos
Reply 5 of 5, by Trypticon
I don't see scanlines on my TVs when displaying 480i content. They appear on my multisync monitor, but that's a very untypical display.
480p capable consumer TVs that take component I've only seen from screenshots, and scanlines appear to be subtle at best.
Connected to a late, large VGA PC monitor via converter, scanlines should be way more notable.
