First post, by Choppo51
I'm busy getting to the bottom of an issue I have with my PC not booting up.
I purchased an AMD K6-III/333 CPU 2 months back and just started building my pc to the spec I had back in the day this weekend.
Prior to this weekend, I had tested the motherboard last year September (Gigabyte GA-5AA Rev 2.2) with an AMD-K6/233 CPU I had spare just to confirm the motherboard was working correctly as I purchased it off eBay.
It all worked correctly, was able to POST and boot into DOS.
Today I built the entire PC as the last bits I needed had arrived. I set the motherboard jumpers correctly for the AMD K6-III/333 CPU and triple checked all jumpers and connectors before powering on.
I powered on the PC and it ran for 3 seconds before powering off. It would not power on after that. If I pulled the power cord, waited for 5 seconds and plugged it back in, the PC would power on for 3 seconds then turn off again.
I thought the CPU was maybe DOA as this was the first time I was able to test it since buying it off eBay. I then went to put in the same AMD-K6/233 CPU I previously successfully tested the board with and it does the same thing now...
Powers on for 3 seconds then powers off.
When it the PC powers on, there is no display as it turns off after 3 seconds. There are no POST beeps or noises. I can confirm the motherboard was on the F6 BIOS revision which was the last official BIOS revision ( besides the beta release I believe??) I have tried swapping DIMM modules with known working ones, have swapped out video cards as well, including trying both AGP and PCI video cards.
So yeah, is it possible the AMD K6-III/333 CPU was faulty and has fried my motherboard?
Thanks in advance.
