First post, by Choppo51
I'm busy getting to the bottom of an issue I have with my PC not booting up.
I purchased an AMD K6-III/333 CPU 2 months back and just started building my pc to the spec I had back in the day this weekend.
Prior to this weekend, I had tested the motherboard last year September (Gigabyte GA-5AA Rev 2.2) with an AMD-K6/233 CPU I had spare just to confirm the motherboard was working correctly as I purchased it off eBay.
It all worked correctly, was able to POST and boot into DOS.
Today I built the entire PC as the last bits I needed had arrived. I set the motherboard jumpers correctly for the AMD K6-III/333 CPU and triple checked all jumpers and connectors before powering on.
I powered on the PC and it ran for 3 seconds before powering off. It would not power on after that. If I pulled the power cord, waited for 5 seconds and plugged it back in, the PC would power on for 3 seconds then turn off again.
I thought the CPU was maybe DOA as this was the first time I was able to test it since buying it off eBay. I then went to put in the same AMD-K6/233 CPU I previously successfully tested the board with and it does the same thing now...
Powers on for 3 seconds then powers off.
When it the PC powers on, there is no display as it turns off after 3 seconds. There are no POST beeps or noises. I can confirm the motherboard was on the F6 BIOS revision which was the last official BIOS revision ( besides the beta release I believe??) I have tried swapping DIMM modules with known working ones, have swapped out video cards as well, including trying both AGP and PCI video cards.
So yeah, is it possible the AMD K6-III/333 CPU was faulty and has fried my motherboard?
Thanks in advance.
Reply 2 of 11, by wbahnassi
That time feels like if the ATX power switch is stuck shorted.. It would power on then force a power off after a few secs.. I'd try a different PSU or momentarilly shorting the power header with a jumper and releasing it quickly.
Also, does the same happen without any CPU installed?
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 4 of 11, by Choppo51
wbahnassi wrote on 2026-02-28, 14:58:
Hiya, I tried 3 different PSU's. All confirmed working units.
Same symptoms without the CPU installed.
Cheers,
Reply 5 of 11, by wbahnassi
Does it turn on the moment the ATX PSU's hard switch is turned on? Is there continuity between the two pins of the power header on the front panel connectors block?
Reply 6 of 11, by Choppo51
wbahnassi wrote on 2026-03-01, 05:26:
No, I have to push the power button on the case to power the system on. No continuity between the two pins of the power switch header on the motherboard.
Cheers,
Reply 7 of 11, by CharlieFoxtrot
In general I find it unlikely that a CPU can cause MB failure, especially when it is a correct CPU for the platform. Your case just sounds a coincidence.
Your problem sounds like a power delivery issue, like perhaps a regulator is failed. It also just may be that the new CPU has higher power consumpition and it pushed the already failing component over the edge.
Reply 9 of 11, by Beerfloat
CharlieFoxtrot wrote on 2026-03-01, 06:44:
This.
It would be good to test the CPU on another board but you gotta work with what you have.
Even if the K6-III/333 isn't faulty it is still one of the more power hungry socket 7 CPUs.
I'd be checking the power delivery on the board, particularly the 5 big caps next to the CPU socket. They're from the era of limited lifetime caps.
Reply 10 of 11, by MikeSG
Take the motherboard out, check for shorts on the bottom, check all metal standoffs are in the right place...
Reply 11 of 11, by rasz_pl
1 Congrats on a CPU that officially doesnt exist according to AMD 😀 its the year 2000 Fry's Electronics Black Friday special. Afaik available only there and then for cool $29.
2 diagram for GIGABYTE GA-5AA rev3.2 Re: 430VX or 580VPX schematics and post describing 2.2 vs 3.2 differences Gigabyte GA-5AA revision 1.1, 2.2 and 3.2 differences
on Ver2.2 CPU Vcore is generated by non stnchronous DC/DC converter. U11 controller + q8 mosfer + D10 diode + L10 coil.
You can check if everything is working by measuring voltage on L10 coil and on pin2 of U11.
Personally I would start by recapping this board. Dont fret too much about special brands, any cheapest lowesr caps with more or less similar parameters will do. Even the crappiest caps wont see hard load here and will deliver thousands of hours of continued use, more than you and your children would ever use this board 😀
TC23 _non_ lowesr 330uF 6.3V, pretty much any random cap
TC24 TC39 TC40 C114 and 5 ones along CPU socket all lowesr 1000-1500uF 6.3V
but shutting down after 3 seconds I suspect might be due to shorting to something inside the case, maybe one of the motherboard metal studs didnt line up with hole? try with mobo out of the case
