Reply 3340 of 3432, by Gona
- Member
Here it is.
sharangad wrote on 2026-04-22, 06:59:Once more unto the breach Gona, [EDIT] Use this link https://nirvtek.com/downloads/3DBVLB.20260422.002.7z MD5: 96ad0f7e216253127 […]
MD5: 96ad0f7e216253127de502e4279d68b4
[/EDIT]
https://nirvtek.com/downloads/3DBVLB.20260422.001.7z
MD5: 541789a296a8d224aa5af6a268f3e05fThis one works on with my ISA soundcard. I don't know whether the device id is right here. If this works on your machine, it should list both the soundcard and the 3DB.
It might to be a good idea to run it several time to see if the device IDs are the same each time, though this might be an issue with Dosbox-Rendition.
