RReady (Rendition Verite wrapper) Test Build (Alpha 1)
Reply 3340 of 3358, by Gona
Here it is.
sharangad wrote on 2026-04-22, 06:59:
Once more unto the breach Gona, [EDIT] Use this link https://nirvtek.com/downloads/3DBVLB.20260422.002.7z MD5: 96ad0f7e216253127 […]
MD5: 96ad0f7e216253127de502e4279d68b4
[/EDIT]
https://nirvtek.com/downloads/3DBVLB.20260422.001.7z
MD5: 541789a296a8d224aa5af6a268f3e05f
This one works on with my ISA soundcard. I don't know whether the device id is right here. If this works on your machine, it should list both the soundcard and the 3DB.
It might to be a good idea to run it several time to see if the device IDs are the same each time, though this might be an issue with Dosbox-Rendition.
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 3341 of 3358, by sharangad
Gona wrote on 2026-04-22, 20:08:
Here it is.
[/EDIT]
Thanks Gona, but I think you've run the wrong version. The last version displays a count of the number of cards detected, the isa pnp ids, as well as all the other junk.
Here it is again.
This version does detect my Opti 931.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3342 of 3358, by Gona
I have run the correct version, but I have mixed up my temp directories, and I have attached an older one...
sharangad wrote on 2026-04-23, 00:37:
Thanks Gona, but I think you've run the wrong version. The last version displays a count of the number of cards detected, the is […]
Here it is again.
Reply 3343 of 3358, by sharangad
Gona wrote on 2026-04-24, 13:33:
Here it is again.
Thanks Gona. It's produced some sort of result. Need to test it in Dosbox.
Reply 3344 of 3358, by sharangad
As it turns out it misread all the 0s in the device ids and dropped them from the ID.
Once again, if you don't mind Gona:
https://nirvtek.com/downloads/3DBVLB.20260425.001.7z
MD5: b786b5f390a8f2250884c9dc88637975
There's no rush for this BTW.
Reply 3345 of 3358, by Gona
Here it is.
sharangad wrote on 2026-04-24, 19:24:
As it turns out it misread all the 0s in the device ids and dropped them from the ID. […]
Reply 3346 of 3358, by sharangad
Gona wrote on 2026-04-24, 20:04:
Here it is.
Thanks Gona! That Id looks to be from your soundcard. There's something strange going on with this.
Reply 3348 of 3358, by sharangad
Gona wrote on 2026-04-25, 05:35:
Soundcard (GUS MAX) removed.
sharangad wrote on 2026-04-25, 04:32:
The other two spurious pnp queries now fail, returning 0xff.
It's still picking up the same fully detected card. This almost certainly is the pnp id of the vlb, unless you have other isa/vlb cards. I've added it to dosbox, but I still get a 3d blaster not found. So it's probably at the next step now.
Using the device Id from your query in dosbox , the config app has some extra stuff it does. Need to see what that is. I didn't get any further with the cgl driver today either.
I'll try and put some more time into it tonight. Got icr2 stuff to deal with right now.
Reply 3349 of 3358, by Gona
I have switched the ISA Cirrus CL-GD5428 to a PCI CL-GD5430 but the result txt bitwise identical. Than swap to an S3 and I have disabled IDE, serial etc. everything is bios except floppy controller. Again bitwise identical. If I remove 3D Blaster VLB "0 card found". Finally still without 3D Blaster VLB but with Vibra 16VX PnP. Different. I have attached this one.
sharangad wrote on 2026-04-25, 07:27:
The other two spurious pnp queries now fail, returning 0xff. […]
Reply 3350 of 3358, by sharangad
Gona wrote on 2026-04-25, 10:07:
Update: 0x1163 for Creative PCI/Rendition.
Thanks, that's a massive amount of testing!
I guess 0x38, 0x18 identifies Creative isa/vlb pnp cards. Pci ids for the 3dbpci uses something similar., not sure if it's the same.
Once again thanks Gona!
Reply 3352 of 3358, by sharangad
Success Gona!
Bit 0 is wrong and there's another bit at the end. The missing bit in this case needed to be 1. I've fixed my test app, but there's no need to retest it. The apps detect the card. The VLB config app then proceeds to get stuck in a loop querying the resource, which currently doesn't work in DosboxR.
The ID for the VLB is
Card #1: 70 31 08 A0 1B DE 00 00 A7
I'll have another test app to query resources tomorrow, when I get back to CGL.
After querying the IDS for card #0 across the entire port range, it then repeats the process for card # 0-FF. Here the ID needs to be returned again. After that the resource query begins.
Reply 3353 of 3358, by sharangad
and again .. (no rush at all. I have other things to work on)
https://nirvtek.com/downloads/3DBVLB.20260426.001.7z
MD5: d09d9ddade156d29f3778626b565f326
Run this with a parameter. 3dbvlb a
Running it without a parameter (command line argument) will cause it to list all available cards and then stop. If a parameter is specified it'll query cards until it find the VLB and then try to query resources.
Reply 3354 of 3358, by Gona
I have run it with a parameter.
sharangad wrote on 2026-04-25, 18:34:
and again .. (no rush at all. I have other things to work on) […]
Reply 3355 of 3358, by sharangad
Gona wrote on 2026-04-25, 19:23:
I have rud it with a parameter.
Thanks Gona! That didn't quite work out. I'll do some work on it in a few hours.
Reply 3356 of 3358, by sharangad
This should do something. The AI might've gotten it wrong though. It produces a stream of 0xFFs for the soundcard.
https://nirvtek.com/downloads/3DBVLB.20260426.002.7z
MD5: 40a1e5daedea2810e8e06b1956bdd493
To run it use:
3dbvlb 1 > out.txt
(The first parameter is the card number to query. When multiple card are detected, the resources can be queried separately, by card number, starting from 1.)
The new block doesn't redirect to a file so output.txt is what's needed.
Thanks again Gona! Good night!
Reply 3357 of 3358, by Gona
Here it is.
sharangad wrote on Yesterday, 18:05:
This should do something. The AI might've gotten it wrong though. It produces a stream of 0xFFs for the soundcard. […]
To run it use:
3dbvlb 1 > out.txt
Reply 3358 of 3358, by sharangad
Gona wrote on Yesterday, 18:13:
Here it is.
To run it use:
3dbvlb 1 > out.txt
Thanks!
The Ai code is definitely broken.
