First post, by Nonstopmaximum
I've had this X800 XT in the GPU bin for a while without using it until recently. Other than a noisy fan it works great but only through VGA. No matter what this thing refuses display out through DVI and I'm scratching my head over what's preventing it from switching.
Reply 2 of 12, by ott
I encountered similar issue on the FX5500.
DVI worked fine on older monitor with CCFL backlight, but it refused to work with modern monitor via DVI-HDMI adapter.
Reply 3 of 12, by Nonstopmaximum
tehsiggi wrote on 2026-05-07, 13:31:
Can you show us a detailed picture of the backside of the card, preferably from the DVI connector area?
Sure thing.
The attachment ATI2.jpg is no longer available
The attachment ATI3.jpg is no longer available
ott wrote on 2026-05-07, 13:34:
This is on a 2004 NEC LCD so compatibility isn't an issue.
Reply 4 of 12, by Grem Five
If you are using a DVI-D cable I would suggest trying a DVI-I cable instead or try a passive DVI to vga connector just to see if the port works.
Reply 5 of 12, by Grem Five
You are missing a component at B22.
Reply 6 of 12, by tehsiggi
Yep, B22 is missing entirely, meaning that the GPU is not getting VDDC_CT which powers parts of the GPUs I/O section. It might be the reason your DVI interface is not working at all.
The attachment vddc_ct_r480.png is no longer available
For testing, you might just bridge B22 with a piece of wire and see if things work then. After that you can look for a replacement.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 7 of 12, by Nonstopmaximum
Thanks guys bridging that area with some wire brought the DVI port back to life! What's the correct part I need for that area?
Reply 8 of 12, by shevalier
Nonstopmaximum wrote on 2026-05-08, 10:37:
If you can’t find a ferrite bead (which is what you’ll be advised to use) or a 0-ohm SMD resistor, it’s actually quite simple to make a neat one yourself.
Tap the tinned wire (for example, 0.32 mm CAT5 Ethernet cable) three or four times with a hammer, then cut it with a craft knife.
It will be fairly inconspicuous and won’t stand out.
This sort of decision is typical over-engineering from ATI, who did everything exactly by the book.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 9 of 12, by tehsiggi
You'll need a ferrite bead with an impedance of 60Ohms at 100MHz. Size of 1206 should fit very well. Current rating around half an amp should fit (the R300 specs VDDC_CT at 450mA, wouldn't expect it to be higher for the R400 series).
Something like this https://www.mouser.de/ProductDetail/Vishay-Da … OBDFwQ5Og%3D%3D
Reply 10 of 12, by bjrnx
Sorry for hijacking this thread but the problem is similar. So I have an ATi X850 XT with issues on the dvi connector too. Seems to have no signal when attached via a dvi cable but using a dvi>d-sub/vga adapter it works on analog monitor input.
Having a closer look on the cards backside after reading this thread I noticed a missing transistor(?) on Q14 that may be the reason (the layout seems identical to the X800 in this area). Looking at pictures it seems that Q14 is the same part as Q15 nearby and this one has a designation WK 3 53 (the last numbers are written vertically), but I am not able to find a spare part based on that info. Can someone please give me a hint, what specific part this is? Thanks a lot.
The attachment x850xt_Q14_missing.jpg is no longer available
Reply 11 of 12, by shevalier
bjrnx wrote on 2026-05-16, 14:05:
bsn20
BS170FTA
Or any 2N7002 from any manufacturer.
These are level-shifting transistors that convert 5V to 3.3V for reading the DDC from the monitor.
There are no specific requirements or design parameters.
You can use whatever is available.
Reply 12 of 12, by bjrnx
Great! Thanks a lot!
