Tzk wrote on 2026-07-14, 17:01:I’m running DDR333 rated chips at up to 275Mhz. Ddr500 sticks are just rated for that frequency and I’d assume they were tested […]
I’m running DDR333 rated chips at up to 275Mhz. Ddr500 sticks are just rated for that frequency and I’d assume they were tested on either socket 478 or 939. that being said they may behave completely different on socket 462 at those speeds.
I always select the chips I want to use and then the sticks I have available. For example Winbond BH-6 (rated DDR333) will behave the same as BH-5 sold as DDR500, it’s the same chip, just with different binning. So no, you don’t „need“ ddr500 sticks.
Two exceptions though: Samsung TCCD and Crucial Ballistix are heavily binned, even the DDR400 ones. So if you try regular OEM micron 5B C/D/F/G or Samsung revision F Chips which are TCCC, don’t expect much.
Regarding 3Dmark scores: It depends. Athlon XP at higher clocks is mainly bandwidth (FSB) and latency starved. So going for tight timings at the highest FSB possible is key. Especially with gpus like 6800GT and faster you’re cpu limited.
The fastest options are:
- Winbond BH-5 at high volts and 2-2-2-5, preferably 250-260Mhz or whatever your board can handle.
- Crucial Ballistix 5B G 2.5-2-2 at about 250Mhz
- Hynix ETR 2.5-3-3-8 at 270-275Mhz
There’s other options which are still quite fast, but not top notch.
tehsiggi wrote on 2026-07-14, 16:42:
You might wanna take a look at this https://www.hardwareluxx.de/community/threads … thread.1244468/ - you can use the auto translate of your browser, it appears to do a proper job. It'll give you some idea I suppose 😀
My kits are DDR400 / DDR433 - no DDR500
Thanks for all the info. Looks like I have a lot of digging to do. I am going through my stockpile of DDR and I have found a couple that might be good ones. The rest will take some investigating.
This is going to sound like a total noob question, but I'm asking because my DDR test system is not currently ready to hook up... what is the best program to identify the chips used on memory that has glued-on heat spreaders? Is there anything better than CPU-Z for something as old as an Nforce 2 system?
I have lots of memory with head spreaders, and I really don't want to tear them apart to see what chips they use. I have 5 OCZ PC3200 "1024MB EL Dual Ch Platinum Edition 2-3-2-5", a Crucial Ballistix of some kind (looks like I wrote on it 512MB DDR400 2-2-2-6 2.8v ... not sure when I did this, 🤣) as well as various Corsair XMS, SuperTalent and Patriot memory.
Found some Samsung TCCC... one Rev E and a couple Rev F, and some UCCC. No TCCD yet.
Just found a Kingston 1GB stick with 16x Qimonda BE-5 chips. Looks like that might be worth tinkering with... too bad it's only one.
I can definitely see this being an interesting challenge, since during the DDR1 era it was still very common for even a good DDR-based system to be single-channel. So, someone may have bought good RAM, but they only needed one stick. Makes it much harder to find matching pairs of good RAM to run in a dual channel board.
EDIT: Were there any overclocking-friendly DDR chips that were in the smaller, more square-shaped (DDR2-like) BGA package? I have come across some of those as well, but they have minimal markings. On one "AMPO PC3200/1GB" module the chips are mostly blank except for a tiny little bullseye symbol and "DDR DXT".
