Reply 20 of 36, by moflihmoflih
ROM bios header pointer PLL pointer PLL table Crystal freq offset (value)
53008 0048h -> 10Ah(+30) ---> 13Ah 984h(+E) ---------> 992h (0B30)
57403 0048h -> 110h(+30) ---> 140h 930h(+E) ---------> 93Eh (0B86)
51804 0048h -> 108h(+30) ---> 138h 902h(+E) ---------> 910h (0B86)
51805 0048h -> 10Ah(+30) ---> 13Ah 988h(+E) ---------> 996h (0B86)
52910 0048h -> 112h(+30) ---> 142h 9A8h(+E) ---------> 9B6h (0B86)
are you sure this was a MAC board because the ROM you posted is a PC ROM!
these are all the roms of rage 128 i could find 3 of them are for AGP and 2 for PCI
RAGE128 GL 1999-02-03 PN 113-51804-1 01 AGP BK1-0-11-VR001-001-001-011 (32KB) 29.5MHz
RAGE128 GL 1999-03-19 PN 113-51805-1 01 AGP BK1-0-11-VR001-001-001-011 (64KB) 16MB 29.5MHz Xpert128 (TVout)
RAGE128 GL 1999-04-07 PN 113-52910-2 01 AGP BK1-0-14-VR001-001-001-014 (64KB) 32MB 29.5MHz AIW (tv tuner)
RAGE128 GL 1999-06-21 PN 113-57403-1 02 PCI BK1-0-13-VR001-001-001-013 (36KB) 32MB 29.5MHz
RAGE128 GL 1999-04-07 PN 113-53008-1 00 PCI BK1-0-12-VR001-001-001-012 (64KB) 16MB 28.6MHz AIW (tv tuner)
any way the rom you posted is 57403 this rom does not show any post screen if used with MAC board
the only one that works but has the clock issue is 53008 and it belongs to All-in-wonder card (so you get all the unwanted
tv stuff devices when using its ROM), by modding the the dot clock frequency it must be good to go.
which ATI rage 128 do you have, can you post a picture of the board and the flashing process
did the flash process went without any issues!
