Retro OSes for retro computers
Reply 300 of 319, by Jo22
Here's another lesser known homebrew OS, Snowdrop OS.
So far, it looks very promising, tinkering with it seems fun.
Has BASIC interpreter, but programs can also be linked/compiled.
Source code is available, too.
I'll let the author speak for himself here:
"Snowdrop OS was born of my childhood curiosity around what happens when a PC is turned on,
the mysteries of bootable disks, and the hidden aspects of operating systems.
It is a 16-bit real mode operating system for the IBM PC architecture.
I designed and developed this homebrew OS from scratch, using only x86 assembly language."
Link: Homepage
PS: The author's main site is neat, too! I higly recommend browsing by.
Lots of electronics projects, some of which interface with Snowdrop OS.
Examples:
- stepper motor driver controlled by Snowdrop OS
- interfacing a Nintendo NES from Snowdrop OS
- interfacing with a 16x2 LCD via parallel port
Reply 301 of 319, by Jo22
Another one, Solar OS .
It's an experimental 64-Bit real-time OS (formerly 32-Bit).
The OS is written in ASM and has a lot of development tools, it seems.
Requirements:
Only 8Mbytes RAM (even less)
P1 class CPU at 266 or even lower
Can be setup to run with under 2Mbyte RAM with some limitations.
Homepage: http://www.oby.ro/os/
Reply 302 of 319, by Jo22
Hi again, please excuse for the double post (tripple post?) here, but there's another retro OS.
It's SerenityOS, a mix of Win95 GUI and Unix architecture.
It's especially made for friends of both Windows 9x/NT and Linux, I suppose.
https://serenityos.org/
There's a thread at Vogons, which was made by me (?) - I'm a bit surprised and confused, to be honest. 😅
Re: New Linux distribution that looks exactly like Win95
Reply 303 of 319, by MrFlibble
Jo22 wrote on 2025-06-14, 00:20:
Hi again, please excuse for the double post (tripple post?) here, but there's another retro OS. It's SerenityOS, a mix of Win95 […]
Just as I had my hopes high for an eventual Windows-looking environment to run retro games from the 90s era (if this OS would also supply tight integration of DOSEMU and Wine to run DOS/Win apps like on real Windows), I read their FAQ, and it felt largely discouraging:
Will SerenityOS support $THING? Maybe. Maybe not. There is no plan. […]
When will you implement $THING?
Maybe someday. Maybe never. If you want to see something happen, you can do it yourself!
Where are the ISO images?
There are no ISO images. This project does not cater to non-technical users.
So it feels like someone is just having fun with this and might drop development forever at any time when they lose interest or it works "well enough" for them on their own machine.
Except if maybe someone else picks this up with a more serious and goal-oriented approach.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 304 of 319, by Zilch
Not sure if this has been mentioned in the past, but I think MikeOS is always good fun!
I actually haven't tried it since version 4.5, so I have some catching up to do.
Reply 305 of 319, by dr.zeissler
I think I have to dig this thread much deeper to get new possible OS for playing around in my multiboot-setups. https://youtu.be/uylD7rDSorg?si=QpV9D_kuXYeDZ6aP
Reply 307 of 319, by dr.zeissler
For that 486/133 a bit to high (P200+) but Cloudschatze showed DR-Dos with NewDeal3 that is indeed intersting because I am still searching for an icon-based guy for dos. Testing QMIII is at first, but DR-DOS and Geos/NewDeal is second. Not a real OS for sure, but interesting to maxout the machine. Executor is also running very nice on that 486/133.
Reply 308 of 319, by lolo799
dr.zeissler wrote on 2026-01-30, 11:14:
I did try it in 86box with a 486 PCI motherboard and a dx4/100, it did work under that emulated machine.
But it's not a real one so I'm curious if you could try it on your 486. It installs as a loopback file under Win9x (like the Personal Edition of BeOS) so you can always uninstall easily.
Reply 309 of 319, by MattRocks
Jo22 wrote on 2025-01-29, 09:53:
Not an OS per se, but a fine retro GUI for DOS - MCShellGS 97 v3.1 ! Runs on 80286 minimum w/ VGA, but needs some XMS memory (2 […]
Runs on 80286 minimum w/ VGA, but needs some XMS memory (2 MB up).
Reminiscence of System 7.x..
Features: Picture Viewer (BMP/PCX), Print Manager (Epson/Laserjet/Proprinter), Virtual Memory, Calculator etc.
File Manager: Copy/Format Disk, Search Files, Copy+Paste, etc.
Desktop: Wallpapers, Patterns, Clock, Sound Effects etc.
I never knew that existed!
While also not operating systems, I spent a fair amount of time using Fusion/Basilisk II/SheepShaver to run MacOS 7/8 on my PC. I also used BeOS (later OpenBeOS, then Haiku).
And the most curious (almost an operating system) alternative I can think of, but that I can't actually remember using, is Sun Microsystems Looking Glass 3D.
https://distrowatch.com/table.php?distribution=lg3d
https://web.archive.org/web/20110223094847/ht … t/projects/lg3d
https://www.youtube.com/watch?v=c-4y0bwl6w0
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i5) → x86-64(i7) ] * lost
Reply 310 of 319, by gdjacobs
I remember this pseudo GUI which used ASCII based "Windows" with programs run via a batch file with a callback to the shell. Never been able to rediscover what it was.
Reply 311 of 319, by jal
Given the ubiquity of Borland-based text-only windowed GUIs, not sure why you scare-quote "windows". What you describe can be any of the myriad of menu-like programs. I recall my XT clone of the late 80s to come with an IBM menu system which did just what you described, but it didn't really have windows in the traditional sense.
Reply 312 of 319, by Jo22
The textmode GUIs are sometimes called TUIs, I think.
As for the design/layout of windows and drop-down menus, IBM called its own specification SAA, I vaguely remember.
Borland products used Turbo Vision and are available for use in user applications by early 90s.
https://en.wikipedia.org/wiki/Text-based_user_interface
https://en.wikipedia.org/wiki/IBM_Systems_App … on_Architecture
https://en.wikipedia.org/wiki/Turbo_Vision
Reply 313 of 319, by Jo22
RetrOS-32.
Description
A x86 32bit Hobby Operatingsystem with graphics, multitasking, editor, filesystem, networking and 32bit C-Compiler for i386 architecture.
Features
Custom Bootloader & GRUB compatible
Multi-threaded pre-emptive scheduling
Networking, TCP, UDP, DHCP
Custom C Compiler
FAT16 Filesystem
Links:
https://www.youtube.com/watch?v=ny7fXjuv6WM
https://github.com/joexbayer/RetrOS-32
https://oshub.org/projects/retros-32
Reply 314 of 319, by DaveDDS
If you'd like to experience what it was like to actually use some very old systems, you can grab some of my classic system emulators from "Daves Old Computers"
I put together a fair collection, you can run things like Appie][, TRS-80, Ti, Atari, SOL, COSMAC, PET, ZX80/81, Adam, Acorn, PDP-11, IBM370 and more.
Here are the ones I actually created for this collection, based on actual systems that I had in my position at the time:
Mil-MOD8: 1974, Intel 8008 processor.
The OS was MONITOR-8, which let you load and run "other stuff", including:
-Scelbi 8008 BASIC (1974)
Mits Altair: 1975, Intel 8080 processor, with emulated NorthStar floppy disk system.
-Can boot NorthStar DOS, and my own DMF operating system.
Vector1+ & NorthStar Horizon: 1976, Z80 Processor, with emulated NorthStar disk system.
Basically the same emulator, it just puts on a different face and rearranged IO ports.
-Can boot NorthStar DOS and CP/M
Heathkit H8: 1977, Intel 8080 processor, with emulated, H8T - Tape interface and H17 - Floppy disk system
-You can load various Heathkit tape based software as well as boot Heath HDOS.
D6809 portable: 1983, 6809 processor, with emulated NEc765 based floppy system.
This was a system I comlpetely designed from "scratch".
-Can boot my own CUBIX O.S.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 315 of 319, by aVd
Hi, guys!
While searching the internet for some old DOS CGA mode switching for VGA software I landed into some very strange Linux distro site - PsychOS. And it has a 486DX targeted version too: https://psychoslinux.gitlab.io/486
PsychOS486 code named "Wilfred" information:
  • Default username: root
  • Default password: woofwoof
  • Initial release date: 2020/11/28
  • Version: 1.6.5
  • Target: Older i486DX/i586/i686 computers with CD-ROM drives
  • Recommended RAM minimum for console-only use: 32MB (will not boot below 23MB)
  • Recommended RAM minimum for GUI desktop, but you'll hate it: 64MB
  • RAM minimum for over-all mental well-being: 128MB
  • Download Size: 687.6MB
  • Installation Size: 4.71GB on EXT2 file-system; GUI method only
  • Supports persistence: Yes
  • MD5: dc6b6841766f83621af254ac88ab98bd
  • License: It might be LGPL?
  • E-Mail: psychosgnulinux@protonmail.com
https://www.youtube.com/watch?v=EJyFunNAuNw
More PsychOS486 screenshots
BONUS:
And more weird things from the same PsychOS site - a (Free)DOS TUI environment PsychDOS ver. 1.0: https://psychoslinux.gitlab.io/DOS/INDEX.HTM
https://www.youtube.com/watch?v=wQCiZtnJekU
More PsychDOS screenshots
Just tested PsychDOS. Runs on a 386+ in DOS.
I like the quieter planets, this one became pretty noisy 😀
Reply 316 of 319, by Jo22
aazard wrote on 2024-08-15, 18:31:
UPdated Kernel for Geoworks GEOS, New Deal Office & Breadbox Ensemble: WORKS ON XT's!!!! […]
Updated Recompiled GEOS.GEO For Geoworks GEOS, New Deal Office & Breadbox Ensemble.
See images (this was on a 80286, but tests to work on an 8088)
PICTURE #14 is impressive (multi-tasking & on web, confirmed on a NEC V30 XT with 640kb)
MY REDDIT POST WITH GREATER DETAILS:
https://www.reddit.com/r/vintagecomputing/com … al_office_2000/
My Archive.org reupload:
https://archive.org/details/geos_20240815
Ethernet Driver, EtherPKT.Geo:
https://archive.org/details/etherpt-2
EMU386:
https://survpc.tripod.com/emu386/download.htm
System requirements appear to remain:
  • 8088 (NEC V20 or better, + FPU for best results. Tested on NEC V30HL + NEC D9008D FPU @ 16mhz )
  • Less than 256 kB of RAM (more = better results, 1024kb+ would be ideal. Tested on 1024kb + PicoMem 5MB EMS card)
  • Base DOS install (IBM PC-DOS 7.1 BLD134 used for testing)
  • Supports VGA true/high
  • Supports Ethernet (driver above)
TO INSTALL/USE:
  • Install GEOS, New Deal Office, Breadbox Ensemble (I suggest New Deal Office 2000 on an XT)
  • Complete setup as normal, boot into it once & reboot to DOS
  • Replace your SYSTEM\GEOS.GEO with it
  • Reboot as normal
  • I Suggest use of EMU386 if you have the memory to spare for it. Will work on NEC V20 or better with 8086-2 instruction set
Adds:
  • Still boots & works on an XT 8088/8086, NEC V20/V30 with 640kb (tested on V30)
  • SSL and HTML4 in the browser
  • JPEG viewing support (in browser at very least)
  • PDF that supports PDF 1.0-1.3 and then some.
  • See images (this was on a 80286, but tests to work on an 8088)
Notably: READ THIS 1ST ONE, ABSORB, SERIOUSLY!
"So, I re-compiled latest FreeGEOS kernel with 32-bit support off and dropped it into NewDeal Office 2000 install. It boots and it works, there is SSL and HTML4 in the browser, and there's PDF that supports PDF 1.0-1.3 and then some. It works with acceptable speed, in fact."
"Nice bonus: even if MediaViewer doesn't seem to support JPEG files, they can be opened in browser. It is a very big deal for a 286 machine"
Found at:
https://tech.lgbt/@nina_kali_nina/111653827347219206
EtherPKT.GEO Note:
EtherPKT.Geo, GeoWorks GEOS, New Deal Office & Breadbox Ensemble ethernet driver.
NC_Quite.zip is This is a custom-compiled version of mTCP's Netcat utility mentioned.
Two Ether packet drivers. The driver in the ETHER_1 folder seems to be a bit older and a bit smaller. The driver in the ETHER_2 folder is the one from Thomas' download link. Which of the two works better is unclear.
I've been successfully using ETHERPKT.GEO with a NewDeal Office 3.2a setup for the past day-or-so, per an adaptation of this configuration.
Here is a generalized procedure:
1. Place ETHERPKT.GEO in the \SYSTEM\SOCKET subdirectory of your NDO installation.​
2. Load the packet driver for your particular NIC.​
3. Configure and run "DHCP" from Mike Brutman's mTCP package, taking note of the returned IP information.​
4. Edit your GEOS.INI file to reflect the following for the [tcpip], [accpnt], and [accessPoint0001] sections. Populate the relevant IP fields with the information returned by the DHCP utility.​
Code:
[tcpip]
driver = TCP/IP Driver
driverType = 0
link = Packet Ethernet Driver
linkDomain = Packet Ethernet
port = 2
[accpnt]
prevID = 4
contents = {
00010001
[accessPoint0001]
name = LAN
netType = 1
default = 1
ipaddr = x.x.x.x
ipgate = x.x.x.x
ipmask = x.x.x.x
dns1 = x.x.x.x
5. Fire-up NDO, and go to town.​
There has been mention of the "ipaddr" field of the GEOS.INI file being dynamic if set to "0.0.0.0," but this failed to work for me. Also, it's worth noting that, in the absence of DHCP persistence in your environment, the expiration of an IP lease may require regular updating of the static IP address in that field.
The only anomalous behavior worth mentioning in all of this is that, with my particular system, some quirk of the ETHERPKT.GEO driver causes the keyboard to become unresponsive when exiting back to DOS from NDO. As a workaround, I'm just initiating "Exit > Reboot the Computer" instead.
EDIT: liiks like OG poster (Cloudschatze) of info is here, here is the link:
https://forum.vcfed.org/index.php?threads/loo … 959/post-929465
Hi, please excuse me for this quick reply! It's a positive feedback, sort of.
That's why I thought I should still mention it in this thread. I'll keep it short.
I've just tried this out on a random thin client and initially had some trouble with Breadbox Ensemble and WebMagick 3.
The thin client uses a modern RTL8100C PCI NIC and a 50 KB (!) DOS packet driver (rtspkt.com 0x60).
I've had to use a second entry (accessPoint0002) and use the bigger etherpkt.geo driver to get things going.
Maybe it's a minor difference between NDO and B. Ensemble? I basically adopted this setting here.
I've also used the new geos.geo without issues so far (old one got renamed geos.bak). 😎👍
Thanks a lot and best regards,
Jo22
Reply 317 of 319, by MattRocks
My favourite lineage is AT&T System V/386, 386BSD, FreeBSD, PC-BSD. I still have my old PC-BSD boot disk. The evolutionary tree persists today through TrueOS and GhostBSD, but I've not actually tried those more recent products.
Reply 318 of 319, by jal
TrueOS is quite dead actually. GhostBSD is for x64, so not quite retro.
JAL
Reply 319 of 319, by MattRocks
jal wrote on Yesterday, 21:25:
As open source code it lives on in other products, but I'm not quite sure what your point is.
