Proprietary 3D API's
Reply 120 of 134, by marxveix
Gona wrote on 2023-12-04, 17:33:
BEEN_Nath_58 wrote on 2023-12-04, 17:04:
Gona wrote on 2023-12-04, 14:03:
I have added. Thanks!
Hi Gona. There seems to be some trouble with the site. It used to work earlier for me. I have to use the Internet Archive to access old versions. Isitdownrightnown says that the site is down.
I tried 3 different ISPs and they have the same result.
Hi, my site provider has blocked full country related IP domains. Write me your country in private and I will try to remove it from blocklist.
Now this site is down for me also, 2-3 days back it was ok. Still i know most of the latest working drivers by name and i have 3dcif files stored.
Edit: Server was not working probably, now site works again for me.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 121 of 134, by Gona
marxveix wrote on 2023-12-07, 02:58:
Nowadays the site is well available, but sometimes can problems occur.
It seems to me that my provider goes from blocking "black list" to enable "white list".
If someone can't access my page, write your country here or in PM.
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 122 of 134, by marxveix
I share 3dcif working ati2drab files or driver soon, still the winme or any other Rage XL PCI compbatible drv is missing from the final puzzle at the moment (faulty colored picture in the game with them).Re: Compaq (HP) original drivers are broken?
Edit1:
Here is one of the Spadina driver , 3DCIF works for Rage XL AGP, just downgrade ATI3DCIF.DL_ to (2692), tested with Assault Rigs and clean Windows. All M6.00.xx and Spadina drivers are working if correct ATID32AB.DL_ (5031.2) is used with downgraded ATI3DCIF.DL_ to 2692, ATID32AB.DL_ 5034 also works, even with ATi Rage XL AGP.
I am miss more recent Ati2drab.dr_ from 4.11.1xxx line and newer ATID32AB.DL_ (5036), latest 4.11.1xxx ati2drab.dr_ i have is 4.11.1027 and sp11141.exe (M6.00.11) ATID32AB.DL_ (5036) file is broken.
Spadina driver (ati2drab.dr_) spb94ej.exe:
https://prius.hitachi.co.jp/support/verup/tool/310ldisp.htm
https://prius.hitachi.co.jp/support/verup/dat/spb94ej.exe
Reply 123 of 134, by marxveix
Newer than 5.38 was available for 5.3x release, i see 5.39 driver, but i cant download it, 5.40 also here.
https://web.archive.org/web/20010406110446/ht … orea/driver.htm
https://web.archive.org/web/20010603090633/ht … /korea/home.htm
https://web.archive.org/web/20010406110446/ht … sk/5391b10e.zip
https://web.archive.org/web/20010406110446/ht … isk/540b01q.zip
Anybody has ATi 5.39 driver?
Reply 124 of 134, by Hoping
marxveix wrote on 2024-10-03, 17:32:
Newer than 5.38 was available for 5.3x release, i see 5.39 driver, but i cant download it, 5.40 also here. https://web.archive.o […]
What is the latest version you already have? For the Rage 2 PRO TURBO AGP I found Fujitsu version 5.35, the newest I know.
https://support.ts.fujitsu.com/indexdownload. … 80-89d9e5a4d4b0
There are already so many versions mentioned in the thread that I get lost.
Reply 125 of 134, by marxveix
Hoping wrote on 2024-10-03, 17:58:
What is the latest version you already have? For the Rage 2 PRO TURBO AGP I found Fujitsu version 5.35, the newest I know. https […]
From latest 5.38.x MACXW4 driver i have 5.38.2 / 5.38.3 / 5.38.6 , as i remember.
I tought that 5.38.x variations where latest MACXW4, now i think 5.39 is latest, just nobody has it. I was looking for Rage XL PCI (4752) / Rage XC (4753) 3DIF driver again.
3D TURBO ACE,3D MULTI EYE, 3D POP (Direct 6.0지원) Version 5391b10e (00/02/14)
https://web.archive.org/web/20000422165828/ht … rea/support.htm
Driver date 14 februrary 2000 - 5391b10e.zip(6,388KB)
https://web.archive.org/web/20000613150221/ht … orea/driver.htm
Reply 126 of 134, by dr.zeissler
There are lot's and lot's of different ATI drivers for my ragePro-PCI but I found 82440 to be the best.
It works in games, works with ATI-DVD 3.10 player and can be used with suitable opengl.dll.
Reply 127 of 134, by marxveix
dr.zeissler wrote on 2024-10-03, 20:02:
I am using MMC 6.30 with XLAGP, it works with RagePro/Rage128P cards @ Win9x, it has ATi DVD 6.2. If someone uses it with AMC connector or AIW Rage Pro then even better.
Most of the sites have ATi Video Player 5.2 / 5.3 available, found ATi Video Player 5.35, possible to use with MMC 6.30 also, some files conflicts @ mmc if both regulary installed.
Just unpacked AVP 5.35 or overwritten with 6.30 again and works for me. MMC6.30 and AVP5.35 need DirectX6.0 or newer + worked with my latest 4.11.2582 dx6 3dcif dirvers.
ATi Multimedia Center 6.30 Win9x
https://hingetee.ee/ftp/?dir=library/Software … Ti/Win9x/MMC630
ATi Video Player 5.35 Win9x
https://hingetee.ee/ftp/?dir=library/Software … /VideoPlayer535
Reply 128 of 134, by marxveix
Working Macxw4 4.11.2611 CIF driver for RageXL AGP, maybe for Mobility AGP as well, Rage2 to Rage3 compatible.
Tomb Raider 3DCIF + Croc 1.0 3DCIF tested@clean Windows 98 SE and Directx 6.1 @ Rage XL AGP and Rage2C AGP.
I share here also my Rage2/Rage3 new beta driver, thats modded 4.11.2611 driver works@RageXLAGP.
Someone with Rage Mobility (Rage3 based) could also test it. Rage XL PCI i have less hopes, this driver
got R3DVD playback imported also from Ati2ddad and 2611 is compatible with Rage2 Direct3D / 3DCIF.
RageXL has 3DCIF/Direct3D/OpenGL/ATiDVD, maybe Brenders and ATi Video Player should also work.
3Dfx emulator added from XGL200 and some more, MPEG1 gamma @menu maybe, d3d 8bit pallete.
OpenGL 8bit palleted textures over D3D->OGL wrapper only, but that also should work if @D3D work.
Macxw4.inf has readme inside, this is not my ideal rage2/rage3 final driver, but its more closer there.
bat file shoul be executed after or before install even with or without 3dfx emulator. Thank you all!
Some testing and tips would be helpful, 90% sure that with more hexedit no need to downgrade R2.
5043 Macxdd32 needs atid3d.dll correcty inputed, made some name changes inside ati2ddad files.
Reply 129 of 134, by marxveix
Anybody can get 3dcif working with RageXL PCI 4752 with errors, even knight demo. Most 3dcif demos should work ok, but not 3dcif games and knight demo. One testing build uploaded here: Re: Chinese Rage XL PCI mods, improved compatibility and looking for a good overclock.
Demos visible here: https://www.youtube.com/watch?v=Mnahhue0VWs
New Win9x 3DCIF 5.40.3 dirver for Rage2C up to RageXL AGP + Software bundle.
Re: ATi RagePro drivers and software
Reply 130 of 134, by Kahenraz
marxveix wrote on 2021-02-12, 02:27:
RageIIc does not support OpenGL, but it is possible to use OpenGL wrapper, it should work. RagePro Tweaker versions are mostly f […]
RageIIc does not support OpenGL, but it is possible to use OpenGL wrapper, it should work. RagePro Tweaker versions are mostly for RagePro.
RagePro Tweaker version 1.0 to 1.2 has readme with this info , under rage2.
This release of the Rage Pro Tweaker does not detect what type of card you have. Some of the 3D options will work, and the overclocker should work - except for the reset to defaults option. The opengl drivers do not work on the Rage II or II+ so the opengl options will not work.
Use also Rage2-Tweaker, but it may need some extra files for windows. I have more experience with RagePro, my first graphics card. I have tested Rage2c with Direct3D and 3DCiF just little, it works, but i would like to get more fps, at least without overclocking and tweaking. Rage Pro has PCI and AGP option, it is possible to disable integrated graphics and use some available free slot for faster graphics card.
I have not used 4.10 dx5 drivers now, dx7a setup file seems not that big ,compared to dx6.1 and dx5.0
http://falconfly.3dfx.pl/directx.htm
I uploaded all three RagePro-Tweaker versions and one Rage2-Tweaker here to download.
https://www.upload.ee/files/12871985/rage2-ra … weaker.zip.html
Good that we have RageXL working 3DCIF driver, Thin clients and server motherboards have RageXL integrated graphics, also rage2c and rage pro on older motherboards.
I have HP t5000 series thin client - t5300 with transmeta crusoe tm5600 cpu and ati xl graphics, this would be nice dos and win9x machine, it just need bigger ide 44-pin dom and then i am ready to start. Usb 1.1 is bit slow, but for mouse and keyboard it is good and even for usb stick, it is sometimes ok.
https://www.parkytowers.me.uk/thin/hp/t5300/
Does anyone have a backup copy of rage2-ragepro_tweaker.zip?
Reply 131 of 134, by dr.zeissler
http://aptiva243.web.fc2.com/aptiva-5.html
RageProTweaker seems to have a rageII switch?
Don't know if this helps, I took a look on my NAS for Rage utilities.
Reply 132 of 134, by dr.zeissler
Part2
Reply 133 of 134, by marxveix
Kahenraz wrote on Yesterday, 01:25:
Its probably my old file name and there was rage2tweaker and ragepro tweakers,but it was with missing files at rage2tweaker,like all others.
After that i found missing files from the internet and uploaded them with bundle, ATi3DRageProSoftwarebundle.7z. Hope it will be helpfull.
Also most of my drivers have it, just not 3xRageTweakers (1.0,1.1,1.2), 1 for RagePro and other for Rage2 and also RageDev.exe (all available).
1 post to this ATi3DRageProSoftwarebundle.7z : ATi RagePro drivers and software
ATi3DRageProSoftwarebundle download links:
https://hingetee.ee/library/ATi3DRageProSoftwarebundle.7z
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … re%20bundle?w=1
Added Rage2 Rage3 Tweaker and Development All Working.7z from ATi3DRageProSoftwarebundle.7z here (attachment)
Reply 134 of 134, by Kahenraz
Thank you. I have been trying different driver versions and tools to see if there is any way to disable the annoying ordered dither pattern on the RageXL but haven't had any luck.
