Reply 1260 of 1265, by theelf
ViTi95 wrote on 2026-04-19, 22:16:
I'll take a look, I'm sure I introduced a bug when I made changes to how the executable's texts are stored 😅
Hi!! how are you? do you think is possible to keep sprites in high resolution while use low mode?
Reply 1261 of 1265, by ViTi95
Hi! It's definitely possible to have different detail levels for sprites and world rendering, but it all comes down to having spare time to develop it, which sadly I don't have right now. Also, keep in mind that some walls are actually rendered as sprites, so this might cause some unexpected behavior.
https://www.youtube.com/@viti95
Reply 1262 of 1265, by ViTi95
New release, FastDoom 1.3.0
Changelog:
- Improved frame interpolation in uncapped framerate modes for smoother rendering
- Fixed frame skipping in uncapped framerate modes when FPS drops below 35
- Added integer scaling support (up to 5×) for backbuffered VESA modes, enabling any VESA resolution in FastDoom
https://github.com/viti95/FastDoom/releases/d … tDoom_1.3.0.zip
Reply 1263 of 1265, by AncapDude
"Removed network gaming support" 😥
Reply 1264 of 1265, by schlang
maybe performance related?
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 1265 of 1265, by appiah4
schlang wrote on Yesterday, 16:37:
I believe the doom netcode basically relies on the 25fps cap, I can see how that would cause issues with fastdoom..
