Reply 31940 of 31953, by Alesia
Wiped the drivers on my partner's XP PC (Pentium 4 2.something ghz) and reinstalled them, this fixed Neverwinter Diamond and Baldur's Gate being unable to start, but CCC still isn't able to start, so I have no idea what is going on there. We are planning to get a new power supply and upgrade that PC to a Geforce 6800/ATIsomething anyways to preserve my 9700 Pro, so it's good enough until we wipe the XP install during that upgrade to play it safe. Upgrading from a 9550 to the 9700 Pro broke something that wiping drivers alone just doesn't seem able to fix.
Spent some time eyeing Geforce 9800s for my own XP PC as it has a 9600GT and there is room to upgrade (not that it needs it at all) but we'll see, beyond running oblivion/new vegas/fallout 3 better there's not much point. If GoG had Skyrim Legendary Edition I would definitely consider fudging my build a bit and look at a "2007 but upgraded their GPU to play skyrim" build and get an HD 4xxx series card, or a GT 2xx series card. Sadly skyrim had no true legacy versions openly available.
Reply 31941 of 31953, by Trashbytes
CCC as in ATI/AMD Catalyst Control Center ..not starting you say ...causes errors you say ...this is not uncommon with that steaming pile of shite.
I remember back in the day nearly always having issues with it which got worse the more horrible web components they added to it. Even after AMD took them over it never got better, it was always hit or miss if any particular version of it would work correctly or require several clean uninstalls and reinstalls to fix it. The individual drivers are fine its the horrible web component UI/Interface they went with for CCC that breaks a lot and is just generally trash.
Your best bet is to find the 3rd party drivers (Omega etc) for your GPU and use them over the shit ATI/AMD ones.
Reply 31942 of 31953, by BitWrangler
Due to components of the catalyst driver installs and CCC hanging around like a bad smell and screwing up subsequent installations, there have been several utilities around for scrubbing all trace of catalyst off a system, to enable true fresh starts.
Reply 31943 of 31953, by Trashbytes
BitWrangler wrote on Today, 11:27:
Even then ...YMMV, if so much as one registry entry got missed or one folder/DLL/INF is still present because Windows prevented its removal then yeah CCC will likely break itself again, ask me how I know.
3rd party drivers all the way, especially now with how easy they are to find, there is zero reason to use AMD/ATI CCC drivers on a retro system.
Reply 31944 of 31953, by Alesia
Trashbytes wrote on Today, 11:24:
It doesn't cause errors, it just doesn't start on boot or on command. The drivers themselves never actually were unstable, most games worked without issues outside of those three bioware games for whatever reason. This probably wasn't actually the ATI stuff at all, I found some Nvidia driver DLLs hiding from when this PC had an MX400 very temporarily. Windows XP must have dug something up because I never installed Nvidia drivers myself and the motherboard doesn't have a Nvidia chipset. The issue was probably lurking well before the 9700 Pro was installed and we tried to run BG/NW/BGII.
Reply 31945 of 31953, by Trashbytes
Alesia wrote on Today, 12:36:
That's actually an error with CCC and its web based backend, it cant display it because the web front end cant load but if you check task manager you'll find all the associated CCC junk is loaded. Its a common issue with CCC and likely has nothing at all to do with the NVidia DLLs since that issue can and did happen with a fresh install.
Track down the Omega drivers and you'll find they not only run with out problems they will also perform better than the ATI/AMD ones do as they don't include CCC. (At least I don't remember them ever having it)
Reply 31946 of 31953, by MattRocks
I found Omega drivers do strange things if you swap GPUs, reusing settings intended for your previous device and imposing them on your current device - so I stopped using Omega.
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i7) ] * lost
Reply 31947 of 31953, by BitWrangler
Am I remembering right that "AmigaMerlin" of voodoo driver fame also did a catalyst cleanup util?
Reply 31948 of 31953, by Trashbytes
MattRocks wrote on Today, 13:21:
That's why its best to use a clean up util to remove the previous drivers or use them on a fresh install of windows, this advice goes for all drivers if you are switching GPU vendors or even GPU families from the same vendor.
Reply 31949 of 31953, by gmaverick2k
Took out the quadro2 pro, put in a ti4200. tried shadow warrior, was a bit juddery. put the quadro2 back in, butter smooth. quadro2 pro stays in. cant find geforce 3 for a decent price
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: QDI Advance 10T/Pentium iii-S 1.4 GHz/Quadro2 Pro/Vortex 2/ESS 1868f/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 31950 of 31953, by Trashbytes
gmaverick2k wrote on 47 minutes ago:
I doubt you will either, all 3 models go for absurd amounts in working condition .. just like the 256 DDR does.
Geforce 2 cards however are like Cockroaches.
Reply 31951 of 31953, by RetroLizard
MattRocks wrote on Today, 07:59:
RetroLizard wrote on Today, 02:54:
Does software/web design count as retro? That's what I spent the morning doing.
Depends what version of HTML/VML/JS/CSS you used? 😉
I'm a big fan of the sites that are JS-light (just the touch needed for functionality) before the web became JS-heavy (libraries on libraries of dependencies to do the same thing but slower).
I'm using pure HTML 1 right now. No JS or anything else yet.
Reply 31952 of 31953, by BitWrangler
<h1><blink> Pure HTML 1 si t3h awesum!!! </blink></h1>
Reply 31953 of 31953, by RetroLizard
BitWrangler wrote on 15 minutes ago:
Unironically (okay, maybe a little ironically), thanks for giving me an idea to use with the top of the page.
