Reply 20 of 28, by Pr1ha
- Newbie
sdz wrote on 2026-08-21, 08:24:Next, I tweaked some internal driver parameters (SST96_FT_CLK_DEL SST96_TF0_CLK_DEL SST96_TF1_CLK_DEL SST96_TT_CLK_DEL, can now be set externally with the new driver, same as then could always be set for a Voodoo/Voodoo2 card but never on the Rush for some reason).
What you're doing is amazing!
Is it possible to modify the gamma parameter in the driver so that it can be set externally?
