Hmmm. Didn't realize that it lacked a VRM. I have an old BX board that doesn't have a lot of voltage tweaks. https://theretroweb.com/motherboards/s/intel- … -mount-prospect
Probably out of luck there.
https://bitsundbolts.github.io/HAWK370_Interest/
CPU SUPPORT - THE WHOLE SOCKET 370 LINEUP, ONE BOARD
- Premium Gold Connector - Hard gold plated edge connector
- Tested FSB - 155 MHz (MSI BX Master)
- Socket ZIF - Socket 370 (new)
- Status - Final prototype in verification
- Requirements for Tualatin/VIA C3 - MB VRM 1.5V and compatible BIOS
- WARNING HAWK 370 does not have a VRM
optional: throttle control & live monitoring
HAWK 370 has reserved footprints for an ESP32-C3, so you can add software CPU throttling and live rail monitoring later.
- CPU throttle control - Adjusts effective CPU speed via STPCLK, from software
- Live rail monitoring - Real-time VCORE and VTT readouts
- Interface - Local web UI over Wi-Fi - no app or account
- Firmware - Fully open source
- Firmware status - Early - v0.1, under development
- ESP32-C3 module - Not included - solder-on footprint only
Here's a video of the throttle control-
https://www.youtube.com/watch?v=Ahcn76v27yw
