Reply 3500 of 3552, by sharangad
I think these should be ok. IRQ 5 is sometimes needed for SB emulation, though dosbox defaults to 9.
The address ranges need to be different from Rendition. Some Speedy3D apps have weird hardcoded addresses and completely ignore what the PCI device query registers return. I have no idea why. I think for any additional video devices being emulated, a different address range should be used.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3503 of 3552, by sharangad
Got everything spaced correctly and some polygonal content is being rendered as a series of Quads. Texturing is still broken.
https://youtu.be/6bWNNzq4Jls
Also on Patreon:https://www.patreon.com/Rready/posts/3d-blast … ntent=join_link
Reply 3504 of 3552, by sharangad
Nascar 1 runs in slow mo with corrupted graphics:
https://youtu.be/JWabvVo_73o
Also on my Patreon:
Rebel Moon (1995/VLB) runs with a black screen and menu sounds (no video).
Reply 3505 of 3552, by sharangad
A bit better now, though the 3D section has stopped working.
(Updated image with one without font corruption)
Reply 3506 of 3552, by RaVeN-05
Tested
Scorched Planet no regression
Some tiny lines could be spotted on HUD
And variety of fps.
Quake II
No regression
Notes:
Underwater resolution should be higher than actual resolution, otherwise it will have distortion.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 3507 of 3552, by sharangad
RaVeN-05 wrote on 2026-10-29, 11:20:
Tested Scorched Planet no regression Some tiny lines could be spotted on HUD And variety of fps. […]
Tested
And variety of fps.
Quake II
No regression
Notes:
Thanks Raven!
Edit
One thing to note is that the 3db vlb's internal texture formats are the same as the CGL texture constants from the header file. They're different to rredline /Speedy3D. I guess the microcode interprets the formats.
Reply 3508 of 3552, by sharangad
Nascar colours fixed, Rebel Moon splash screen works and Test3D now has a working 3D section without z-buffering:
Youtube upload doesn't seem to be saving. I'll update this with the right link:
Youtube link: https://youtu.be/99iaNxIu1_4
Patreon:
Reply 3509 of 3552, by sharangad
Test3D 3D sections (seemingly) fully functional with z-buffering and (so far) everything:
https://youtu.be/IDO_dGzIO24
Also available on my Patreon:
It looks like the 3DB VLB is a quad renderer.
Reply 3510 of 3552, by sharangad
Rebel Moon, looking a better. It's possible to move about, in slow motion. Chroma keying isn't working (yet) and it's very slow, probably due to direct mem writes.
https://youtu.be/DRrPwe6-0L8
Reply 3512 of 3552, by sharangad
Got lighting working maybe. I don't know whether this is right. Maybe someone else can comment. Is the photo of a CRT darker or is the lighting off with RReady.
Reply 3513 of 3552, by sharangad
The slowdown seems to be the games' CGL driver sleeping after reading some combination of virtual registers per polgyon.
The actual render speed is very high, RReady spends most of its time idling. Dosbox isn't idling at a lower priority either, so it's probably spinning with a timing delay. These games ran on 486s, so this shouldn't really be happening.
Reply 3514 of 3552, by sharangad
Rebel Moon running at a semi-decent framerate with interrupt driven v-sync. It still doesn't work properly:
https://youtu.be/uT8idthNG8E
(https://www.patreon.com/Rready/posts/3d-blast … ntent=join_link)
Flight Unlimited BGR swapped menu(?)
https://youtu.be/vO-K8qoxgY8
The 3D section of Test3d.ex ramping up to 60 fps:
https://youtu.be/7BWlde9GFOY
Reply 3515 of 3552, by sharangad
Rebel Moon at a (near) solid 60 fps with working menus:
https://youtu.be/W1UMnOTwuC0
Extremely alpha build:
https://nirvtek.com/downloads/RReady.Alpha.20 … 3DBlasterVLB.7z
MD5: 3b312c40dbd899f62da159744e3d09b3
Supports Test3d.exe and RebelMoon (1995).
Also available on my Patreon at
Reply 3516 of 3552, by sharangad
Nascar looking a better at a higher framerate. There's an RGB<->BGR problem with this along with heaps of palette corruption:
https://youtu.be/4bSGPAT1LnU
also on my Patreon:
Reply 3518 of 3552, by robertmo3
What it's supposed to look like. - you need to press "r" 😀
