Reply 80 of 98, by robertmo3
i uploaded it again as previous was not from a cold boot
Reply 81 of 98, by ubertrout
robertmo3 wrote on 2026-11-15, 01:13:
Fantastic. It's still very early, but it's working. Screenshots below. I have one on order myself.
I didn't realize there was this much interest in this but it should be much simpler than PowerVR to finish.
Reply 82 of 98, by robertmo3
sento and creep clash work too.
you can move the sword with tab.
check the .ini file in game if game has access to all the folders
Reply 83 of 98, by robertmo3
and check my pm
Reply 84 of 98, by ubertrout
Thanks, got it. I'm going to want to get a physical card to continue the project, even though it seems to be working fairly good already. Hopefully arriving this week.
Code is here for now, it's very rough but will hopefully work better soon. The VLB card works better in emulation so far, and it needs a BIOS to work in the video/matrox folder of roms: https://github.com/z2k-retro/86Box/tree/mga-impression-plus
Reply 85 of 98, by starlord
@ubertrout
Incredibly cool. Thank you very much.
Great to see Icehawk working again.
Reply 86 of 98, by matze79
Here are the files from PowerVR PCX1 Card.
I used Slackware 14.2 running on my Pentium 180Mhz MMX, Apocalypse 3D PCX1 and Diamond Viper TNT1 PCI.
The third test, hangs the machine.
Reply 87 of 98, by ubertrout
matze79 wrote on 2026-11-16, 20:57:
Thanks, the dumps were really useful. They’re written up in Appendix I of the tools repo, including that the fog and divider tables are RAM on the PCX1 and that IEEEFP, BILINEAR and FASTFOG don’t exist.
If you’re willing to try one more run: the texture test now does the driver’s full start-up sequence first, which is the likely difference from what hung last time. Please update and rebuild, then run only the texture test:
cd powervr-pcx2-tools && git pull && make
sudo bin/pcx2dump --texmem
Type yes at the prompt. It may still hang the machine. It can’t harm the card, and everything up to that point is saved to disk first. Either way, please send the new pcx2dump-… folder. Even after a hang, its report.txt will show whether the tables loaded correctly.
Reply 88 of 98, by matze79
Here you go!
Reply 89 of 98, by ubertrout
matze79 wrote on 2026-11-17, 19:49:
Here you go!
Thanks for running it again! Unfortunately the texture test was skipped both times: the tool only continues if you type the whole word yes at the warning. Could you try once more? This version skips the question, so there’s nothing to type:
sudo bin/pcx2dump --texmem --yes
The first line of the new report should begin with pcx2dump 292225e or a later version. It may hang the machine again. That’s fine, since the report is saved first. Please send the folder either way.
Reply 90 of 98, by fla56
hi buddy @ubertrout thanks for this, amazing
i too am a (previous) PCX2 owner...have built a working Vulkan shader version of the chip including the usual enhancements, AA, ansio, texture packs -would this be something to also incorporate from a speed / upscaling PoV?
please see attached for more info
and yes, of course, credit where it's due could not have done it without Opus 5.5...
Reply 91 of 98, by matze79
ubertrout wrote on 2026-11-18, 03:55:
Thanks for running it again! Unfortunately the texture test was skipped both times: the tool only continues if you type the whol […]
Here you go!
Ah, Sorry.
Seems the keyboard language was switched and i tipped zes or so
i will run it again soon.
Reply 92 of 98, by ubertrout
fla56 wrote on 2026-11-18, 12:52:
hi buddy @ubertrout thanks for this, amazing […]
Glad you enjoyed and cool to see this being built on! I didn't run into too many speed issues with the wrapper I made (also with Opus) but making real 3d acceleration work with it sounds even better and opens more doors!
Reply 93 of 98, by xabarax
Hi everyone!
I'd like to share two videos showing some of my latest experiments with the legendary **PowerVR PCX2 (1997)** running on real hardware under Windows 98!
**1. Quake III Arena – New OpenGL ICD**
Quake III Arena running on a real PowerVR PCX2 using my newly developed OpenGL ICD!
The driver is still under active development, but the results are already promising. I'm working on improving compatibility, fixing rendering issues and pushing this classic graphics accelerator beyond its original software support.
**2. GLChasm – Chasm: The Rift OpenGL Port for Windows 98**
Back in 1998, Chasm: The Rift never had an OpenGL port for Windows 98.
Now, in 2026, I've decided to develop one!
GLChasm is a new OpenGL port designed for the PowerVR PCX2 and other graphics accelerators from the late 1990s.
The goal is to bring hardware-accelerated OpenGL rendering to this classic FPS while maintaining compatibility with period-correct hardware.
**Both projects are running on real PCX2 hardware — no emulation!**
There's still plenty of work to do, but I'm making progress.
**Enjoy the videos! I'll soon be opening separate threads here on VOGONS to document these projects, share technical details, development progress, compatibility tests and more experiments on real PowerVR PCX2 hardware.**
Stay tuned! 😎
https://www.youtube.com/watch?v=AKit3t1jwvc
https://www.youtube.com/watch?v=7J88BYBQCaE
Reply 94 of 98, by ubertrout
Really cool project!
I have experimental emulated overclocking in a fork of this project; I should return to it and get it working. That should enable PowerVR PCX2 to go even farther with Quake 3 games. Some people apparently have done this on real hardware but most of us are understandably wary of messing with something that rare: Overclocking the Videologic PowerVR PCX2?
Reply 98 of 98, by robertmo3
i suggest starting a separate thread for impression, so people not interested in powervr can find it
or at least updating topic and first post about it
