First post, by kanecvr
- Oldbie
"J98MF-002" is the key number here.
Vital MF002BR 8-bit sound card
Who knows what type of soundcard this is?
Re: Vital MF002BR 8-bit sound card
do the Fandango!" - Queen
Stiletto
wrote:"J98MF-002" is the key number here. […]
Whoa that was fast! Driver works perfectly - you ROCK mate!
wrote:Whoa that was fast! Driver works perfectly - you ROCK mate!
You're welcome! 😀
Stiletto
Just tried one of these WITHOUT drivers and it sounded surprisingly good - pity it is speaker out only with no line-out jumper, but could not really fault it otherwise.
k6-3+ 400 / s3 virge DX+voodoo1 / awe32(32mb)
via c3 866 / s3 savage4+voodoo2 sli / audigy1+awe64(8mb)
athlon xp 3200+ / voodoo5 5500 / diamond mx300
pentium4 3400 / geforce fx5950U / audigy2 ZS
core2duo E8500 / radeon HD5850 / x-fi titanium
Crazy... that thing has sockets for CMS chips! That was certainly a very determined effort at cloning the SB 2.0. I'd be curious to know if you can drop in a programmed GAL and a couple SAA-1099s and actually get fully functional CMS out of that thing.
wrote:Crazy... that thing has sockets for CMS chips! That was certainly a very determined effort at cloning the SB 2.0. I'd be curious to know if you can drop in a programmed GAL and a couple SAA-1099s and actually get fully functional CMS out of that thing.
Mine was a smaller card with no sockets. The FM had a kind of punch to it I don't hear often...then again it could have been overgain from feeding the speaker out into amplified speakers 😒
kanecvr wrote on 2016-04-08, 15:50:wrote:"J98MF-002" is the key number here. […]
Re: Vital MF002BR 8-bit sound cardWhoa that was fast! Driver works perfectly - you ROCK mate!
hi, i search for this driver and i cant download it from your links... can u help me please
Stiletto wrote on 2016-04-08, 15:47:"J98MF-002" is the key number here. […]
hi, iam searching for some drivers for the same sound card but i cant download anywhere.... can u maybe help me too, i cant find a usable driver on this links anymore.... please tnxx
freako666 wrote on 2020-03-30, 20:18:Stiletto wrote on 2016-04-08, 15:47:"J98MF-002" is the key number here. […]
Re: Vital MF002BR 8-bit sound cardhi, iam searching for some drivers for the same sound card but i cant download anywhere.... can u maybe help me too, i cant find a usable driver on this links anymore.... please tnxx
It looks like DriverGuide may have deleted j98mf-002.zip off of their website (who knows why)
Anchor Electronics MF-002 (J98MF-002)... aka the Media Concept 2.0 (and many other names, such as Master Boomer...)... it's a Sound Blaster 2.0 clone!
You may want to try this (actual Media Concept drivers): http://mpolibbs.steptail.com/hardware/SOUND/O … ER/LD_MEDC2.ZIP
or this (should be the same thing, different publisher): http://vogonsdrivers.com/getfile.php?fileid=821&menustate=0
Brostenen may still have the original j98mf-002.zip file somewhere: Re: Drivers for Sound Blaster 2.0 Clone?
brostenen wrote on 2015-12-15, 13:31:Took a leap of faith, and downloaded the j98mf-002.zip file, though it has some issues. (it's the right installer) It is missing […]
It is missing a file called mf.cfg and it asks for the disk being labeled "DISK1 " (yeah... blank spaces, sort off)
When I copy the files to a specific folder, it asks for this mf.cfg file.
Tried to see if an empty file would do the trick. Hmmm.... Did not work as it is asking for some information.
Found the product name, by the way...
It is called: "Anchor Media Concept 2.0"
But as you've already seen, the other Media Concept 2.0 drivers should be the same.
Later on, brostenen is legit able to get it working with the Sound Blaster 2.0 installation media: Re: Drivers for Sound Blaster 2.0 Clone?
such as you may find here (scroll down): http://vogonsdrivers.com/index.php?catid=7
showing that it's a Sound Blaster 2.0 clone.
That's all I can help with, I don't own this card.
Stiletto
Stiletto wrote on 2020-03-31, 08:39:Hi, […]
or this (should be the same thing, different publisher): http://vogonsdrivers.com/getfile.php?fileid=821&menustate=0Brostenen may still have the original j98mf-002.zip file somewhere: Re: Drivers for Sound Blaster 2.0 Clone?
It is called: "Anchor Media Concept 2.0"But as you've already seen, the other Media Concept 2.0 drivers should be the same.
showing that it's a Sound Blaster 2.0 clone.That's all I can help with, I don't own this card.
Hi, tnx for your help. I will try the drivers.
Yes... That card is my old card. Kanecvr have it now. However, getting in touch with him, is perhaps a bit impossible.
I lost contact with him for about two years ago, and I have no idea were he went.
There are one single clue to were he might be now, as someone on another forum have reported that he might have died
in a motorcycle accident. He has not been responding to any of my email, that I have send him for the last 1,5/2 years.
What happened. I dont know. However, that card in the picture, are my old card.
