Reply 20 of 23, by ReCat
wrote:wrote:Alright, If I boot up the mobo without a floppy controller or with the floppy drive disconnected from the controller I get this same error:[..]
Hmm. Ok, seems the board is behaving normal so far. If you can, try another floppy cable. A modern, non-twisted type (for a single drive) for example.
OK. I've now connected the motherboard to the PSU of my known-working P1, and the drive controller to the known-working floppy cable connected to two known working floppy drives. Exactly the same behaviour as before even after configuring the two FDD's in the BIOS.
Curiously, I've noticed it's successfully passing floppy diagnostic tests in the BIOS (edit: Even with the original FDD drive and cable it came with). So it's not like it can't read the FDD. It just makes no attempt to boot from it. (not even trying to read a bootloader)
If the HDD is connected though, the diagnostics screen freezes as soon as i try to open it.
For context, here is my HDD config:
And here is my HDD:
