Quake III Arena Benchmark Thread
Reply 120 of 203, by Fusion
agent_x007 wrote:
One of few games that isn't a slide show on this CPU :
🤣 a 1080 with a 2Ghz Celeron.
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 207/207 - SB Live! 5.1 - Windows ME
Reply 121 of 203, by agent_x007
GPU core (after small OC), can be clocked higher than stock CPU 😁
Reply 122 of 203, by Fusion
Switch it up to 16bit. xD
Reply 123 of 203, by agent_x007
You mean Texture Quality, Color Depth or... OS (DOS) ? 😜
Reply 124 of 203, by cxm717
I ran Q3 1.11 on a 1GHz P3 on my intel d815eea board with 512MB SDRAM and a Radeon 8500:
The attachment q3_p31g_8500_xp.png is no longer available
I also tried it on my OR840 with a P3 933, 512MB of RDRAM and a Radeon 8500:
The attachment q3_p3933_8500_xp.png is no longer available
Reply 125 of 203, by cxm717
Wow, that 2GHz Celeron was slower than my P3@933MHz
Reply 126 of 203, by agent_x007
What OS did you use ?
Because my Celeron did that score with Windows 7 x86 😉
Reply 127 of 203, by misterjones
ok, just stood up a 2.8GHz P4 (period correct northwood core, non-HT) with a very much non-period correct Geforce 8400GS and wanted to run timedemos but for some reason I can't. I have the Linux version of Q3 (can't find my case with the key on it right now) and the way I've always installed it was to get the final update for Windows, install it, then copy over PAK0.pak from the CD to base3q. The game runs but no timedemos on it. Where can I get 'em?
Reply 128 of 203, by misterjones
Got the timedemo thing sorted out.
2.8GHz Pentium 4 Northwood (Non-HT)
2GB RAM
512MB Geforce 8400GS (standard PCI)
Windows XP SP3
Running at 800x600x32 with everything turned up.
Reply 129 of 203, by Phreeze
70,6fps
CPU: Athlon 1200 @ 10x133=1333Mhz
2x256MB Apacer CL2 Ram
GPU: Voodoo5500 AGP 64MB - last official beta driver
ArGUS Parts list: http://bit.ly/2Ddf89V
Reply 130 of 203, by Phreeze
41,8fps
CPU: 2 x Tualatin PIII 1.4Ghz
2x512MB PC133 RAM
GPU: Geforce FX5500 PCI256MB forceware 45.xx
PCI seems to limit like hell
Reply 131 of 203, by misterjones
Phreeze wrote:
41,8fps CPU: 2 x Tualatin PIII 1.4Ghz 2x512MB PC133 RAM GPU: Geforce FX5500 PCI256MB forceware 45.xx […]
41,8fps
2x512MB PC133 RAM
Nah, it's just the FX5500 gpu. I got 177fps with a standard PCI 8400GS.
Reply 132 of 203, by GL1zdA
cxm717 wrote:
I ran Q3 1.11 on a 1GHz P3 on my intel d815eea board with 512MB SDRAM and a Radeon 8500: […]
Q3 loves the bandwidth of the i840.
getquake.gif | InfoWorld/PC Magazine Indices
Reply 133 of 203, by oohms
It gets a bit silly with modern hardware
i7 2600K @ stock speeds
GTX780 Ti @ stock speeds
Windows 7
801.7 fps
3840x2160 resolution 😉
The attachment q3demo.jpg is no longer available
DOS/w3.11/w98 | K6-III+ 400ATZ @ 550 | FIC PA2013 | 128mb SDram | Voodoo 3 3000 | Avancelogic ALS100 | Roland SC-55ST
DOS/w98/XP | Core 2 Duo E4600 | Asus P5PE-VM | 512mb DDR400 | Ti4800SE | ForteMedia FM801
Reply 134 of 203, by Standard Def Steve
Core i7-4790 (non-K version)
Integrated HD4600 graphics
Lenovo motherboard with Q87 chipset
16GB DDR3-1600
Win7 Pro SP1
1024x768, all settings maxed = 567.5 FPS
"A little sign-in here, a touch of WiFi there..."
Reply 135 of 203, by Fusion
Ployer7w Win10 Tablet
Intel Bay Trail Z3735G Quad Core @ 1.33Ghz
1GB DDR3
16GB Internal Storage
Intel HD Graphics
1024x600, max settings: 122fps
Reply 136 of 203, by agent_x007
Xeon E5-1680 v2 @ 4,3GHz
GTX Titan Black @ 1020MHz/1V (skyn3t vBIOS [modified])
Sabertooth X79
16GB DDR3-1868 CL8.9.8.24 CR2T @ 1,62V
WinXP Pro SP3
1024x768, all settings maxed (ie. Trilinear Filtering) = 996.3 FPS
The attachment Quake III Arena (1024x768 + Window mode + TF) mini.png is no longer available
Reply 137 of 203, by SPBHM
using the OP settings, Trilinear drops performance maybe around 15FPS from what I can remember;
in any case, GMA 950 is pretty decent for something at least!
The attachment q3gma950v.JPG is no longer available
Reply 138 of 203, by Standard Def Steve
My recently upgraded HTPC:
Haswell i5-4670, locked at its turbo frequency (3.8GHz on all cores)
8GB DDR3-1600 CL9-9-9-24
Asus H87 motherboard
GTX 1050Ti 4GB (new; previously had a GTX 750, but Netflix in 4K requires a Pascal GPU w/ at least 3GB of VRAM. Bastards.)
Win 10
1024x768, all settings maxed = 984.6 fps
Reply 139 of 203, by lost77
Seems there is a 1000 fps limit.
Only getting 868.4 fps at 2160p 16x AF 8x AA though 😵
Time for an upgrade I guess...
I7-2700K @ 5Ghz
16GB DDR3-1866 CL9
1080 Ti
