Reply 380 of 499, by matze79
Have you unpacked the Prince.exe before hexedit ?
matze79 wrote on 2020-03-04, 21:58:Have you unpacked the Prince.exe before hexedit ?
I didn't. Are you sure it's packed? At the address there was a matching byte. Hence I would assume it was fine.
its packed.
matze79 wrote on 2020-03-05, 12:52:its packed.
Ok, now please tell me with what packer so I can try to unpack. 😁
But I wonder why it has the correct byte at the same offset...? I have little hopes the unpacking will help. But am welcoming suggestions! Or maybe someone has a working binary?
Didn't yet get around to investigate Prince, but tried Arkanoid 2:
Here is a Preview on Almost-Release Canidate R1.3,
Full reroute, with some optimizations by dreamblaster in KiCad to allow machine assembly, and better hand assembly.
I tried Paku Paku on my sound devices. MT32, CMS and Adlib as well as PC Speaker (via TNDY) works fine. But I don't get anything on the /tandySound option.
Any ideas what I need to do for that?
on modified version run /sn76489
That did the trick:
Good! 😀
Hi @matze79 awesome work on this Tandy ISA soundcard, any plans for releasing the PCB designs as open source in the future maybe?
Is there a sound off sys file somewhere out of curiosity or a way to load the sndoff program file in config.sys?
https://www.retroianer.de/wordpress/index.php … ndy-soundkarte/
just add this tool to your Autoexec.bat!
@ JohnGrobler
Not yet, at some point later.
but there is some investment going on to make them avaible soon!
Professional assembled boards!
so you may be able to purchase at Serdashop.com soon! including Metal Slot Cover.
extended my Tandy Prototype Card with Covox DAC,
its highly configurable so i can almost choose any IO Adress i want.
This is Setting the ISA DAC to LPT1:
debug.exe:
d 40:8
e 40:8 78 03
q
78 03 -> 378
So programs asking BIOS for LPT will use the Card.
This program switchs LPT1 to LPT2 :
Fantastic matze79!!
So basically a Tandy DAC?
Don`t be confused, its just plain DAC on ISA Bus.
i bascily have no idea now howto make DMA driven DAC.
As i also own no Tandy (yet)
And Dosbox Code did not really help me yet.
Small Steps 😀
Cool. Already have 2 sound cards with Covox Speech Things and Disney Sound Source on Aztech Sound Galaxy NC NX Pro cards (1 is non-16, and the other is 16 with Windows Sound System and WaveTable header).
Something weird is going on 😳
