PCMCIA Sound Cards
Reply 220 of 752, by Bondi
lolo799 wrote on 2020-04-14, 21:03:
I imagine the test program works fine with digital audio too, right?
Frankly, I'm not sure. The test file itself (i mean if the record played on modern computer) is more like some noise. And the test program plays it multiple times. Maybe that's the way it should be... maybe not. Anyways I'm satisfied for now that sound in Doom works.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 222 of 752, by Bondi
lolo799 wrote on 2020-04-15, 20:03:
Have you tried any other games?
Yes. I don't have many games on this machine. Here is what worked with both digital and FM sound:
- Doom 1/2
- Prince of Persia
- Heroes 1 (no music, but maybe it's my version)
- Wolf3D
- Heretic
- ROTT
The latter two did work with digital sound, although in the help file it's written that it was not supported.
Some games did not start: TIM, Raptor, Tyrian, Vikings. Not sure why. Maybe it's not connected with sound. I did not experiment furhter.
EWJ2 - worked, but there was no sound.
Reply 223 of 752, by Bondi
Just came to my mind - there are WSS compatible PCMCIA sound cards and there is wssxlat.exe, which is a WSS-SB emulation driver for DOS. Is there a chance that it works with a PCMCIA card?
I understand wssxlat.exe works with realmode games only.
Reply 224 of 752, by lolo799
Both cards by NewMedia support WSS SB emulation, you still have the Wavjammer?
Reply 225 of 752, by Bondi
lolo799 wrote on 2020-06-08, 17:27:
Yes, I have it. I meant to make the cards with WSS support work in DOS for digital sound.
wssxlat.exe adds SB support in dos for WSS-only ISA cards. So is there a chance that it will work with pcmcia card?
Reply 226 of 752, by lolo799
You'd have to try to find about, but you'll need the Wavjammer's drivers loaded before wssxlat.exe, not sure how that will work out...
Reply 227 of 752, by Bondi
Bought this card recently. As mentioned above in this topic, this a Windows 3.11 card, but can work in W95 as well.
The attachment Turtle Beach AA.jpg is no longer available
The attachment Turtle Beach CP.jpg is no longer available
It can play WAV and MIDI files. Midi synthesis is done by software (V-synth). I attach a couple of samples. There are some errors in the playback, but overall it sounds not too bad, actually. Volume is a bit low in the beginning of first track, sorry for that.
The attachment e1m1 1.mp3 is no longer available
The attachment map5.mp3 is no longer available
Reply 229 of 752, by cyclone3d
MAZter wrote on 2020-07-03, 21:36:
Sony PRD-155SB Discman w/Sound had built-in SB and Adlib support card.
Very cool. I actually just found a copy of the pcmcia card and sound module on eBay. Looks like it might do Sound Blaster sound in DOS according to that doc.
The Readme.txt for the Windows 95 drivers say that it uses a DSP Solutions setup... which is the same company that made the Altec Lansing AMC2000 setup so this is promising
Unable to find the DOS/Win3.1 drivers for this specific device.... but the drivers for the Altec Lansing AMC2000 look like they may just work as the DSP Solutions driver file names seems to be the same model number... MWAHAHAHAHA.
Now to wait for the thing to get here to test it out.
Found a place to download the full manual for free:
The attachment Sony PRD155SB User Manual.pdf is no longer available
And the manual for just the SB-DM155 (the sound module):
The attachment Sony SBDM155 User Manual.pdf is no longer available
Manual for just the PRD-150 CD-ROM drive:
The attachment Sony PRD150 User Manual.pdf is no longer available
I really hope that the Altec Lancing driver set works for this card in DOS / Windows 3.1 as the DOS / Windows 3.1 drivers for it were never available online from what I am finding.
@Bondi (below) - Those are the Japanese Win95 drivers. Here are the English Win95 drivers:
The attachment prd-150.zip is no longer available
The attachment prd-155.zip is no longer available
Note: When using the sound module, you must use the PRD-155 drivers.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 230 of 752, by Bondi
MAZter, cyclone3d, what a great find!
Hope the drivers fit. Please keep us posted.
Could you upload the Altec Lansing AMC2000 DOS drivers here?
I've seen W95 drives for SB-DM155, guess you have found them already.
Anyways I attach them here as well
Reply 231 of 752, by cyclone3d
Bondi wrote on 2020-07-04, 12:22:
MAZter, cyclone3d, what a great find! Hope the drivers fit. Please keep us posted. Could you upload the Altec Lansing AMC2000 […]
Here is the Altec Lansing AMC2000 disk image... had to skip a few unreadable sectors but it should make a valid disk as it is at the very end of the disk and I can copy all the files off sucessfully:
The attachment Altec_Lansing_AMC2000_disk_image.zip is no longer available
And the files copied off the disk:
The attachment Altec_Lansing_AMC_2000_disk_files.zip is no longer available
The attachment Altec_Lansing_AMC2000_disk_1080.jpg is no longer available
I haven't scanned the manual yet. Once I get that done, I will upload to vogonsdrivers.
YMF7x4 Guide
Reply 232 of 752, by MAZter
cyclone3d wrote on 2020-07-04, 01:40:
Great!
From instructions at Toshiba website:
CONFIG.SYS:
DEVICEHIGH=C:\SONYSB\DS430MGR.SYS C:\SONYSB\SNDBX.INI
unfortunately DSP Solution website files is lost
Reply 233 of 752, by Bondi
Speaking of PCMCIA CD-ROM drives with built-in sound - IBM had two models with ESS1688 sound chip.
8X-20X PCMCIA Stereo CD-ROM Drive 1969011
4X PCMCIA Stereo CD-ROM Drive 1969009
They support 16-bit stereo audio for SoundBlaster-compatible applications, FM music synthesizer and a joystick/MIDI port in Windows 95. Sound is not supported in a DOS application within Windows 95.
http://ps-2.kev009.com/pcpartnerinfo/ctstips/47a6.htm
Reply 234 of 752, by Bondi
nest_and_art wrote on 2017-11-07, 23:57:
Hi!
what is the card?
what is "multimedia" mean?
This one took long to answer. It is the interface card for Zenith Z-player - external double speed CD-ROM unit with two built in stereo speakers and ESS based 16-bit sound card (W311 and W95)
http://alsplace.os9al.com/zplayer.html
The attachment zenith z player.jpg is no longer available
Reply 235 of 752, by cyclone3d
Bondi wrote on 2020-07-27, 18:41:
This one took long to answer. It is the interface card for Zenith Z-player - external double speed CD-ROM unit with two built i […]
Hi!
what is the card?
I just got one of these Zenith units.. but without the interface card 🙁
YMF7x4 Guide
Reply 236 of 752, by Bondi
cyclone3d wrote on 2020-07-27, 21:02:
I think I saw one for sale recently, but cannot find it now... neither within sold items.
Did you get the Sony Sound Box working?
Reply 237 of 752, by cyclone3d
Bondi wrote on 2020-07-27, 22:01:
Only the CD drive itself has arrived. Still waiting on the other parts to get here from Canada... Yay for slow shipping.
Edit. I see that one of the Zenith units including the card sold in May and a card with cable sold on July 22.
Guess I just have to keep an eye out.
YMF7x4 Guide
Reply 238 of 752, by Bondi
lolo799 wrote on 2012-01-01, 19:04:
-Apex Data Audio Express
This is another clone of IBM 16-it Audio adapter.
Found the drivers here https://web.archive.org/web/19970213221422/ht … es/filelist.htm
And many files seem to be the same.
The attachment audiow95.exe is no longer available
Reply 239 of 752, by Bondi
I asked myself wheter there were MIDI/Game port adapters that would work in Win 2000 or even XP.
Google suggested that there was some Yakumo PCMCIA GAME/MIDI Card and it had W2K drivers. Yakumo was a german OEM company. It's not around anymore. I could not find anything about this card, except for the file names of the drivers. That in turn brought me to another card - Argosy PCMCIA GM-101. Luckily I found the drivers for it. The card looked very familiar and reminded me of EXP GAME/MIDI card.
The attachment Argosy (EXP) 150-picture-gm101.JPG is no longer available
So I decided to compare the drivers, and they turned out to be the same.
EXP even suggested drivers for Win XP, but I could not download them https://web.archive.org/web/20021101082347/ht … nt=30&Expand=10
But there are good chances that the w2K driver will work in XP.
Here are the drivers I managed to download during my trail. I load them as is, some files are duplicated.
