First post, by Baoran
This picture is from manual for a soyo SS7 motherboard I managed to find recently.
184.75 KiB
Does anyone has any idea if there are any undocumented voltage settings that would be best used with a cpu that would require lower voltages? Somehow I don't think the jumper settings in the manual include all possible voltage values.
Reply 1 of 12, by PARKE
That looks similar to a Jetway S7 board that I have here.
If so the 4 jumpers add, when shorted, the following voltages to base value 2.0 volt:
1-2 = +0.1 v
3-4 = +0.2 v
5-6 = +0.4 v
7-8 = +0.8 v
For example:
[close][open][open][open] produces 2.1 volt.
Reply 2 of 12, by Baoran
PARKE wrote on 2020-03-29, 02:56:
That looks similar to a Jetway S7 board that I have here. If so the 4 jumpers add, when shorted, the following voltages to base […]
1-2 = +0.1 v
3-4 = +0.2 v
5-6 = +0.4 v
7-8 = +0.8 v
For example:
So all 4 jumpers open would mean I would get 2.0V and that would be the lowest?
Is there any spot on the motherboard where I could measure the cpu voltage with a multimeter without cpu installed to be sure?
Reply 4 of 12, by PARKE
PS Found documented settings for another Jetway board that I once had or researched.
45.46 KiB
Would appreciate it to know if/when you succeed.
Reply 5 of 12, by ibmapc
I have an SS7 board with that same jumper layout. I managed to cook a K-6 III+ because I miss interpreted the jumper settings silkscreen on the board. I set it for 3.6v instead of 2.0v. Silkscreen specified O for short and X for open!! I got it backwards and shorted all pins!! Hit the power and killed the processor instantly. Stupid silkscreen! O should ALWAYS be "open" or 0 (zero) for off.
Reply 6 of 12, by Williwinner
Solved - Hidden voltage options on soyo 5ema+ 1.1? K6-iii+ 500 ANZ 1.8V and some overclocking results
I had the same issue. If you have the same voltage regulator, there are many more options. Check my topic about that.
Reply 7 of 12, by Williwinner
1.62 MiB
This is for the voltage regulator on my soyo 5EMA+ that has a HIP6004BCB controller. The right side is from the controller manual. The left side is mirrored for the actual jumper settings. Make sure, that applies to your board as well!
Reply 8 of 12, by PARKE
@Williwinner
The boards discussed earlier in this thread have 2x4 jumpers and are limited to 16 selection combinations.
The layout you posted does not apply because it is for the SOYO 5EMA+ which has 2x5 jumpers and therefore 32 selection combinations.
Reply 9 of 12, by Williwinner
True. I thought the layout mentioned in this threat was only used for 5EMA (non+) but his SY-5EMA+ is indeed very different to my SY-5EMA+ (v1.1).
Thank you for making that clear!
@Baoran: Is your board without a version number?
Reply 10 of 12, by PARKE
The type of VRM chip is an important aspect but the way how motherboards are designed is equally important. One of my SS7 Jetway boards had an even more limited layout
58.88 KiB
I don't know what type of chip this one carried, I don't have the board anymore.
Reply 11 of 12, by Intel486dx33
Here is my build using the same motherboard.
I used an AMD K6-3+ 450 over clocked to 500mhz.
I used the 2.0v setting.
There was NO need to up the voltages.
AMD K6-lll+@500mhz., Voodoo 3000 (desktop)
Reply 12 of 12, by shamino
Baoran wrote on 2020-03-29, 03:26:
I guess this was a few months ago, but usually you can measure Vcore on the metal tab of a MOSFET near the CPU socket. You can also get Vcore on one of the legs of an inductor (looks like a copper coil). If you're worried about shorting anything then wrap the probe with tape so only the tip is exposed.
Failing all that, you could clamp a piece of wire into the CPU socket on one of the appropriate pins, but that's the hard way.
Put the negative probe against the PSU casing.
Experiment a bit to make sure what you're measuring really is the Vcore (reacting to your jumper changes in an expected way). Then try to find the jumper combo for the voltage you want.
