Reply 60 of 223, by BEEN_Nath_58
- l33t
new entry:
Heavy Gear
new entry:
Heavy Gear
Discrete_BOB_058 wrote on 2020-08-29, 06:10:New update:
A lot of useless data are removed
Don't you think it would be preferable to maybe keep updating the first post without bumping this thread every day?
Jorpho wrote on 2020-08-30, 20:13:Discrete_BOB_058 wrote on 2020-08-29, 06:10:New update:
A lot of useless data are removedDon't you think it would be preferable to maybe keep updating the first post without bumping this thread every day?
Ok,
I shall bump ocassionally 😉
New:
Final Fantasy VIII
Return to Castle Wolfenstein Platinum Edition
Instructions for a lot of games have been updated.
New:
System Shock 2
Wolfenstein Enemy Territory
Maui Mallard in Cold Shadow
South Park (not Rally) does not work at all on anything later than WinXP. Using XP fix on Win7 you'll be able to get to the menus but not past that.
◦Grand Theft Auto: If game lags in DirectDraw mode, increase resolution in game. Couln't figure out how to run the game in Glide.
Glide version is for DOS only. 3rd party DOSBox builds and a Glide wrapper is needed.
filipetolhuizen wrote on 2020-09-09, 00:01:◦Grand Theft Auto: If game lags in DirectDraw mode, increase resolution in game. Couln't figure out how to run the game in Glide.
SO there was no Glide version available for Windows. Only DirectDraw
Discrete_BOB_058 wrote on 2020-09-09, 16:05:filipetolhuizen wrote on 2020-09-09, 00:01:◦Grand Theft Auto: If game lags in DirectDraw mode, increase resolution in game. Couln't figure out how to run the game in Glide.
Exactly. If you download the free version from Rockstar released in the 2000's, there's only the Windows version and it's DDraw only like the Windows version from the original release (except the free version added 1024x768 resolution). The original release was split in 3 different folders (8-bit colours DOS version, 16/24/32-bit colours DOS version which included the 3dfx version, and 16/24/32-bit colours Windows version).
filipetolhuizen wrote on 2020-09-11, 22:35:Discrete_BOB_058 wrote on 2020-09-09, 16:05:filipetolhuizen wrote on 2020-09-09, 00:01:Glide version is for DOS only. 3rd party DOSBox builds and a Glide wrapper is needed.
The game also used some middleware on top, something like MGL, from SciTECh
filipetolhuizen wrote on 2020-09-08, 23:58:South Park (not Rally) does not work at all on anything later than WinXP. Using XP fix on Win7 you'll be able to get to the menus but not past that.
What's the fix, I never tried, I just installed to see the game not run.
eDIT: Someone got it to work https://youtu.be/H9p-Uliib5U
South Park seems playable with a .sdb patch
I already tried the .sdb but it didn't work for me.
filipetolhuizen wrote on 2020-09-17, 20:33:I already tried the .sdb but it didn't work for me.
It would work, if you only rename the exe to SouthPark3
Yeah and I needed nGlide.
Also I needed a lot of patience to keep opening the files. You might not be able to open the game on first double click
Discrete_BOB_058 wrote on 2020-09-18, 04:53:It would work, if you only rename the exe to SouthPark3 Yeah and I needed nGlide. Also I needed a lot of patience to keep openin […]
I followed every step, renaming the .exe didn't work either. Only the XP fix I found on some dxwnd related forum was able to take me to the device selection screen and main menu but stopped responding after I started a new game.
filipetolhuizen wrote on 2020-09-18, 22:17:Discrete_BOB_058 wrote on 2020-09-18, 04:53:It would work, if you only rename the exe to SouthPark3 Yeah and I needed nGlide. Also I needed a lot of patience to keep openin […]
Also I needed a lot of patience to keep opening the files. You might not be able to open the game on first double clickI followed every step, renaming the .exe didn't work either. Only the XP fix I found on some dxwnd related forum was able to take me to the device selection screen and main menu but stopped responding after I started a new game.
Did you see if the sdb file is registered, you can check that in Control Panel, it will have a name 3DFX South Park Patch or something similar. Game doesn't work without the .sdb.
I installed it with CMD instead of a bat file and yeah, I kept opening the file continuously. About 20 times I double clicked and then it ran
Discrete_BOB_058 wrote on 2020-09-19, 04:38:filipetolhuizen wrote on 2020-09-18, 22:17:Discrete_BOB_058 wrote on 2020-09-18, 04:53:It would work, if you only rename the exe to SouthPark3
Yes, the .cdb is installed, I double checked in ACT 6.x. Even after 30 continuous attempts it still refuses to run.
New-
MechWarrior 3
Grim Fandango
New-
Quake 2
Quake 3 Arena
Quake 3 Team Arena
Quake 2 and 3 both work. Might need GL extension limit on some cards, but should need nothing more than that.
