First post, by 32kofdata
Hey all... I've been using softmpu with a ROLAND MT32 hooked up to a SoundBlaster Pro 2.0 (CT1600) quite successfully. /OUTPUT:SBMIDI at address 330. Most of the games I've used this setup with work well always under pure DOS.
Recently I got my hands on a ROLAND SC-88 in order to play later DOS games but unfortunately I don't have much success.
For example Doom and Duke Nukem 3D report MPU-401 not detected regardless if I choose General Midi or Sound Canvas. What could I be doing wrong with games that support General Midi or Sound Canvas?
The SC-88 is working properly, I've tried older games with it like Budokan, Sam n Max, Prince of Persia, etc and even though the compatibility is not perfect (CM64mode/SC55map) at least I get the software to communicate with the device.
Reply 2 of 6, by 32kofdata
Bondi wrote on 2021-05-06, 09:15:
SoftMPU works with real mode games only, and also with games that use Miles Sound System drivers (HOMM2, for instance).
Makes sense... so I'm guessing there are no software options for what I'm trying to do - need to go to a hardware solution?
Reply 3 of 6, by keropi
Well you can always use a SB16 or similar card that has a normal UART MPU-401 interface so that the SC-88 will work fine with GM/GS games and use softmpu for mt-32 gaming like you do now.
Reply 4 of 6, by 32kofdata
keropi wrote on 2021-05-06, 09:57:
Is the Soundblaster Pro 2.0 any different from an SB16 in that respect? (normal UART MPU-401 interface?)
Reply 5 of 6, by Oetker
32kofdata wrote on 2021-05-06, 10:11:
It has a MPU401 compatible, but buggy, interface. I would recommend a clone card such as an Aztech, Opti, ESS. Many topics can be found on that - matching your SBPro's features is easy.
Reply 6 of 6, by 32kofdata
Did some more testing with the SoundBlaster Pro 2.0 (CT1600) . In intelligent mode SC88 works just fine but whenever a game requires UART nothing. Will not detect MPU-401. I guess I'm stuck.
