Reply 20 of 51, by JimWest
digger wrote on 2021-11-20, 14:58:
As if the cloning and recreation of such a product wasn't awesome enough, you also clearly went through great effort to make the PCBs look so clean and elegant.
Great job!
Thank you! 😃
Reply 21 of 51, by Rawit
Does this card and the drivers allow you to work with protected mode games?
YouTube
Reply 22 of 51, by HangarAte2nds!
Never had an Action Replay. so instead I just learned how to use C++ to hack games.
Reply 23 of 51, by BitWrangler
Pffft.... C-x M-c M-butterfly 😉
https://xkcd.com/378/
Reply 26 of 51, by JimWest
Bondi wrote on 2021-12-08, 05:00:
Rawit wrote on 2021-12-07, 15:36:
Nope, real mode games only.
The Action Rewind is equipped with firmware 4.8.
From 4.0 onwards, protected mode games should be supported. At least it was advertised at the time. I haven't tested it myself yet.
See attached brochure from Datel.
Reply 27 of 51, by Rawit
The screenshots and executables seem to hint on protected mode being supported with this version (4.😎 and it's newer than the version shown in the LGR video (1.1 AFAIK).
From https://forums.bannister.org/ubbthreads.php?u … at&Number=85463
"PROT is a small memory resident program (TSR) that holds all of the Protected Mode functions that enable the Action Replay to work with Protected Mode games, such as DOOM, UFO, Theme Park etc. If this program is not loaded then the Action Replay can only be run in Real Mode (normal 640K DOS operation)."
YouTube
Reply 28 of 51, by Bondi
Rawit wrote on 2021-12-08, 07:51:
The screenshots and executables seem to hint on protected mode being supported with this version (4.8) and it's newer than the v […]
Oh, I did not know that. Sorry for misleading. Yes, I was basing on the LGR video, where he mentioned real mode games only.
Protected mode games support could be a significant selling point, at least for me.
Has anyone tried it? I wonder it works well.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 29 of 51, by keropi
cyclone3d wrote on 2021-12-08, 06:12:
I just received my card today. Looks great!
Thanks!
awesome ! thanks for the update and for the support!
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 30 of 51, by keropi
well I did a quick test with DOOM
after AREPLAY.COM is loaded you also need to run PROT.EXE - as the message says HIMEM.SYS might be in the way or not...
so I fired DOOM and the AR menu was available with the "PM" indication. I saved the screen in c:\temp\doom.pcx and it worked
so I guess for max compatibility you can make a boot item with no HIMEM.SYS and let protected mode games do their own thing with memory management since they don't really care about HIMEM...
hope this helps!
Reply 31 of 51, by pshipkov
I remember using some software for this in dos real mode.
In fact there were several of them.
If I think hard the names will come.
They worked pretty well.
What is the purpose of the hardware component ?
retro bits and bytes | DOS media library
Reply 32 of 51, by JimWest
pshipkov wrote on 2021-12-08, 15:39:
One of the features that I really like is the state saving function. This allows you to save a game at any time and restore it if necessary. 😀
For other features just take a look at the brochure I posted on this thread (or LGR's video).
Reply 33 of 51, by keropi
also a sidenote, LGR's card had an old 1.x firmware so things look different
I sent an Action Rewind and he should be getting it soon - maybe we get a blerb or something (I hope so!)
Reply 34 of 51, by AndrewK2685
awesome project guys
Reply 35 of 51, by ssdj
Is it still available ?
I just fill out the form.
Reply 36 of 51, by keropi
Yep , Action Rewind is available there is plenty of stock 😀
Reply 37 of 51, by a_h_adl
Received mine recently and finally found some time to test the card. It works like a charm! We definitely need more new products like this. Thanks Leo!
Reply 38 of 51, by keropi
a_h_adl wrote on 2022-02-10, 09:58:
thanks for the support mate!!!! enjoy teh h4xx0r life 🤣 🤣 🤣
Reply 39 of 51, by grzeszczuk
I missed the original thread and the production run.
Is there still a chance to buy one?
AB-PB4/5x86-160/32MB/S3Trio64/ZuluSCSI/CT1790+WP32McCake/Gotek/FDD3.5"/USR-Sportster-14k4
Atari 130XE/65816-Rapidus/VXBE/Ultimate1MB/FujiNet/AVG/IdePlus2.0D
