Reply 460 of 465, by zuldan
- Oldbie
supercordo wrote on 2026-07-07, 01:44:NM they are EK Quantum Torque black nickel.
Thanks for that!
Tzk wrote on 2026-07-10, 04:58:Yes, you can use SPDTool and disable the second rank on 512mb TCCD sticks. Also yes, the board will detect it as 256mb stick afterwards. I tried this with Corsair XL sticks (0538 and 0542), worked but i didn't gain any additional FSB. I never tested why this was the case, two reasons came to mind: a) the disabled rank still causes load on the dram controller in the chipset and the vdimm power stage or b) the sticks just had avarage chips on both sides and maybe the weakest chip on the first rank.
Thanks for that. I decided not to do it and just wait for the PCB's to arrive.
Tzk wrote on 2026-07-10, 04:58:Going for 250Mhz 2.5-3-3 with 512mb Hynix DT-D43 or or 2.5-4-4 with Hynix 256mb BT-D43 is waaaay easier and those are also a lot cheaper with good availability. Still king of NF2 is the mighty Hynix ETR, >275MHz 2.5-3-3 works. Or Winbond at 255-260MHz 2-2-2-5.
I found some super cheap Hynix 256mb BT-D43's so I'm going to play with those as well.
Going to do this mod with a simple POT to get the voltage up to 3.2v for my Winbond sticks https://warp9-systems.proboards.com/thread/7/nf7-rev-2-mods
