Reply 57360 of 59867, by twiz11
zwrr wrote on 2025-08-22, 00:29:
Use 386: Remove the 486 CPU, set the CPU type jumper, set the FSB jumper to 66. Use 486: Install 486CPU, set CPU type jumper, se […]
mtest001 wrote on 2025-08-21, 12:48:
zwrr wrote on 2025-08-21, 02:15:
2. FOREX chipset 386 & 486 hybrid motherboard
It is a Global Computer Networks FOREX 386/486 with mediocre performance, no more performance tuning options in the BIOS, and a memory read and write speed of only 12MB/s.
Interesting, how do you switch between the 486 and the 386? Do you have to enable one or the other in the BIOS?
Use 486: Install 486CPU, set CPU type jumper, set FSB jumper to 33.
No BIOS setup is required
ah the good old days of physical jumpers, viruses couldn't infect your bios if the jumper was physically in the wrong spot.
Reply 57361 of 59867, by mtest001
Ok, and if you set the jumpers WITHOUT removing the 486 what happens?
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 57362 of 59867, by gmaverick2k
KT333A rev CD motherboard with what looks like a few bulging caps. Gotta scratch that "maximum powa" itch for 3.3v AGP (Voodoo 3 3000). Current KT266 motherboard is limited to Athlon xp 2000+
SD2IDE capped at 33Mbps but is really stable, KT333 is full 133Mbps so may use ssd again but found ssd's are generally unstable compared to sd card
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: QDI Advance 10T/Pentium iii-S 1.4 GHz/Quadro2 Pro/Vortex 2/ESS 1868f/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 57363 of 59867, by zwrr
mtest001 wrote on 2025-08-22, 09:08:
Yes, I tried that, and while installing a 486DX-33 processor, I set the jumpers to use a 386 processor, and turning on the power nothing happened, no self-test, no alarms, and no post code were displayed.
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
Reply 57364 of 59867, by PD2JK
I was looking for a proper SB16 for some time, so this CT2290 got in.
The attachment DSC_5786~2.JPG is no longer available
has all kinds of stuff
Reply 57365 of 59867, by Nunoalex
PD2JK wrote on 2025-08-22, 12:18:
Very nice score ! 😀
it has that chip that many boards lack... I dont remember what it was used for... but is a plus non the less 😀
Reply 57366 of 59867, by ODwilly
Picked up a Thermaltake case "designed by BMW"
Reply 57368 of 59867, by Masterchief79
Asus 6600GT Silent Cool - 6€
HD2900XT - 20€
Gigabyte K8NS-Ultra Bundle with CPU and cooler - 20€
Albatron 6800GT - free from a friend for repairing a motherboard.
Some finds in Germany.
Also working on a 9800 Pro 256MB GDDR2. Very rare model. Proving to be a difficult case. Just installed 8 memory chips from a Quadro FX1000 (aka FX5800) GPU. One defective chip remaining. 😁
Reply 57369 of 59867, by pan069
Nunoalex wrote on 2025-08-22, 14:58:
Very nice score ! 😀
The CT1748A is an "Advanced Signal Processor" or ASP chip. More here on Dosdays on what it is an how its used:
https://dosdays.co.uk/topics/sb16.php
Reply 57370 of 59867, by Linoleum
I thought I was scoring a decent deal with this Creative 24x CD-ROM box... but it turned out to be a hidden gem. Inside was a fully functional CR-562B dual-speed drive from 1994 (along with original manuals and disks for Sound Blaster Pro).
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 57371 of 59867, by CharlieFoxtrot
Nothing truly amazing, just got this haul of old mice:
The attachment mice.jpg is no longer available
Top left is Logitech bus mouse, then two Microsoft serial mice.
Bottom row I have Microsoft Inport bus mouse controller, a MS Bus mouse and a MS PS/2 adapter where you can plug the bus mouse and connect it to a regular PS/2 mouse port.
It was neat to find the Inport card, mouse and adapter in the same haul. Bus mice pop up relatively rarely at least where I live and when they do, it is usually just a mouse or then the controller and I have never bothered with them.
I have already tested the serial mice and MS bus mouse with PS/2 adapter and they work fine. If I have time tomorrow, I slap the controller card to my 386 box and see if that works too.
Does anyone know if the Logitech Bus mouse will work with the Inport controller, or do I need a logitech controller for it? I couldn't easily find a definitive answer. If the Inport card works, Logitech mouse should work with it, but it doesn't, then I know that there is a problem with the mouse.
Reply 57372 of 59867, by BitWrangler
Logitech bus mouse should work with an InPort. I had a Logitech working with a machine that had an integrated InPort.
Reply 57373 of 59867, by CharlieFoxtrot
BitWrangler wrote on 2025-08-23, 22:12:
Thanks mate, good to know 👍
Reply 57374 of 59867, by PD2JK
Yet another mystery box, although I could see the mainboard what triggered me.
The attachment DSC_5793.JPG is no longer available
Also a nice ATi themed GeForce Ti 4200 8x. 😉
(Creative)
The attachment DSC_5794.JPG is no longer available
Reply 57375 of 59867, by nfraser01
Kerbside find: Twinhead Netstation...
Judging by the wires coming out the back the CMOS battery has been hacked. Hopefully it's not too messy in there!
Reply 57376 of 59867, by Mandrew
After the last CRT fiasco I surprised myself with a Tulip monochrome, it's surprisingly light. At least this one had the cable included.
I'm wondering, why did some manufacturers use the 6DIN connector on their mono monitors when the IBM display adapter used the 9 pin version?
Reply 57377 of 59867, by PD2JK
Could it be that some people put their monitors in serial ports? I don't know if 9-pin serial ports existed at that time or only 25 pin serial ports.
Reply 57378 of 59867, by CharlieFoxtrot
Mandrew wrote on 2025-08-26, 07:23:
AFAIK it wasn’t that uncommon and Philips also used such connector in some of their hercules/mda models (that monitor can be a rebranded Philips tube). I also think that those monitors were usually supplied with a 9-pin adapter, but those are naturally nowadays mostly lost to time and often are missing from the monitors.
Why did they use other type of connector? Most likely those monitors were also sold for other applications, such as bundled with some terminal, sold for some micro computers etc. all of which used different connector. It was the same with Philips CM8833 series, where some models had 9-pin connector for both TTL and anolgue RGB (like my CM8833-mk2). You can directly connect your CGA or EGA card to that connector with standard 9-pin cable, but for analogue RGB you usually need to use either an adapter (often SCART in old continent) or then make a custom display cable that connects the 9-pin on the monitor to whatever the source uses as video output (often some type of din connector).
Reply 57379 of 59867, by Mandrew
This one was originally paired with the Tulip AT compact and that shipped with both the MDA and the CGA option. I've yet to see a MDA card with a 6DIN connector but this has the original 6DIN-9pin cable included.
CharlieFoxtrot wrote on 2025-08-26, 08:29:
Good explanation, the same chassis was probably sold to multiple manufacturers based on application and the 6DIN connector was cost effective.
