First post, by feipoa
- l33t++
Does anyone have one of these 1993 updated Evergreen 486 SuperChips?  The previous 286-to-486 Evergreen SuperChip I worked on was an earlier version from 1992. It came with DIP switches, shown here:
download/file.php?id=129731&mode=view
download/file.php?id=125621&mode=view
In that other thread, I also added a Cyrix Cx87SLC-33QP and the FPU worked just fine.
As with my 1992 edition, on the 1993 edition, I also swapped the TX486SLC-33 in favour of the Cx486SLC2-50MP. Unfortunately, the FPU is not functioning on the 1993 version. Landmark Speed test shows 0. For the photos below, I had already removed the 87SLC-33, so that I may solder on another chip:
The DIP switches on the previous 1992 version did not control the FPU in any way, so I figured the same would be true of the 1993 model. Does anyone see anything in the photos which may control/enable the FPU?
Some observations:
1) R22, R32, and R31 are not populated. Could they enable FPU? Do I need to remove other resistors as well? There's also resistors under the PLCC connector. However, on the 1992 version, there weren't any unpopulated resistor pads.
2) J1 on the PCB is not populated. Presumable it connects to a jumper? Or for debugging?
3) I traced out the J1 pins. The left-most pin traces to 87SLC pin 23, or BUSY#. The right-most pin traces to 87SLC pin 20, or ERROR#. Anyone have the 87SLC datasheet?
4) R22 pads: one pad goes to 87SLC pin 20 (ERROR#), the other pad goes to Cx486SLC pin 36 (ERROR#)
5) R32 pads: one pad goes to GND, the other pad goes to the QFP chip with the D3-10 0.008 sticker (bottom pin, 3rd over from the right edge)
6) R31 pads: one pad goes to Vcc, the other pad goes to the QFP chip with the D3-10 0.008 sticker (bottom pin, 3rd over from the right edge)
7) There are SMD components under the PLCC socket. Maybe there are some FPU enable pad under it.
Any ideas? Thanks!
