First post, by Snotz
Does anyone know how to patch DOSBox to show a game rotated in 90 degrees CCW? The idea is to have Pro Pinball Timeshock played rotated and possibly stretched to fill an entire widescreen monitor, without black bars.
Thanks in advance
Reply 5 of 13, by Snotz
yes it does, but thats normal. I can always use for normal2x or 3x for scaler to get rid of the bars (draw them off the display), in windowed mode. I've tried a lot of different configs, all with the same results. DOSBox doesnt even go to fullscreen mode when the gfx card is rotated to portrait. I get a window 1920x1080 wide, even though its in portrait mode, 1080x1920. The bars are minimal when this happens, and I dont mind running it in windowed mode, except that the image pins itself to the left side and partially cut off no matter where I move the DOSBox window. If it was centered, it would be almost perfect (except the scale would be just a little off, which I could deal with)
Reply 7 of 13, by robertmo
should work nicely with
output other than surface
and your choice of windowresolution
what is your gfx card?
fullscreen won't work as you want cause of black bars (unless you you try some virtual res)
Reply 8 of 13, by Snotz
windowresolution=1600x1200
output=opengl
This is the output I get:
http://www.apexcomputersllc.com/dosbox.jpg
Even if I move the window, the table is always to the left and cut off. I have tried all the different "output" options, all the same results. I have also tried "windowresolution=original". Still the same results
My gfx card is nvidia GTX 560.
Reply 9 of 13, by robertmo
how this mode looks like?
http://www.mobygames.com/game/dos/pro-pinball … ameShotId,3388/
and how does it work in official dosbox or latest svn
and get the latest display drivers
Reply 11 of 13, by Snotz
Thanks eL_PuSHeR.
robertmo: Your link is exactly the way it looks when I am in Landscape mode. Nice and centered. Its only when I switch my desktop to portrait mode do I get the screenshot I posted.
Reply 13 of 13, by robertmo
it is funny cause even output surface is affected -> if you move dosbox window out of right border, its content moves. On other rotations: 180, 270 degrees more/other boarders are affected. Happens in both vista and 7. Nothing to do with game, it is visible on dosbox text screen.
can anyone with notnvidia card confirm?
