First post, by programmm
I have lands of Lore 2 on 4 ISO files and I mount them all in DosBox Turbo the same way I would in DosBox. In both cases I do C:\> imgmount d c:\img1.iso c:\img2.iso c:\img3.iso -t iso (or -t -cdrom nmatter) and I have mounted them. Without doing that the game would not start w/o a CD, well it starts. The problem is that when during the game later on it wants to Insert CD2, there is a hotkey combo to use Ctrl+F4, so having mounted the 4 ISOs, switching with Ctrl+F4 and pressing Retry makes the game continue...
In DosBoxTurbo played on smartphone using the exact same commands and success... yes it is correctly typed since I can enter the game there as well BUT... once you get to the point of having to use Ctrl+F4 to switch to CD2 nothing happens - there is a key combination menu in DosBoxTurbo - Ctrl to be pressed then you click F4, this has worked many times, so this key combination of DosBox Turbo generally works but with this game I am thinking it switches but it doesn't accept and Retry does nothing.. Any ideas?
And a general question How in the world do I make MS-DOS/DOSBOX/etc recognize the folder's names when shortened to ~1? For example I have 'Lands of Lore' folder and when it displays it as LANDSO~1, when I try to use commands for that folder it says 'Landso~1' directory doesn't exist.. so it's like it knows this isn't the true name of the folder but it won't recognize the DOS name of that folder as well?
Reply 1 of 2, by Jorpho
DosBoxTurbo is not an official port. If you have something that works in official DOSBox on a PC but not in DosBoxTurbo, then you should ask the DosBoxTurbo developers.
I'm not sure about the LANDSO~1 problem. Are you sure you have the name correct? You can see the short names from the Windows command prompt by using DIR /X.
Reply 2 of 2, by programmm
I think I finally solved the prob of FolderName~1 (when using that name literally) not recognizing it, I just need to put the folders in their full name with the spaces, and just use hyphens.
"NOTE 1: if the path to your target directory contains spaces, you must enclose it in hyphens, like that (Source: Abadonia.com):
MOUNT C "C:\Documents and Settings\Harvey\My Documents\Games for DOSBox"
I thought it's the same devs who did DosBox.. I ask them too (: - the game crashes a lot on the smartphone, randomly, not sure if memory issue but I've seen Professional errors happening on DOSBOX as well - well not during the game but in the beginning, though I must admit the game doesn't crash in DosBox on PC, just DosBoxTurbo on the android Will try with their devs, thanks!
From the dev of DosBox Turbo:
'Regarding switching CD's. In DosBox Turbo, you can switch CD's by going to the "Special Keys" menu and selecting Switch Disc. This should do the same thing as a CTRL-F4 in Desktop DosBox.'
Note: the key is called 'Swap Media' - and indeed swaps the ISO, while CTRL+F4 didn't do it.
I had issues switching to CD2 in DosBox Turbo using Ctrl+F4 combination, it works for DosBox PC but not for the Android version, thus I couldn't continue the game as it couldn't read CD2. 'Swap Media' did it!
