First post, by oeuvre
Hey all,
Usually I'm pretty good with MS-DOS memory optimization but this one is bugging me. I'm only getting 540K free conventional. It's MS-DOS 6.22, WfW 3.11. It's the PCMCIA drivers and the Xircom ethernet card eating it up. If I set it up without those I get 605K free but no internet on WfW 3.11. Memmaker makes it worse at 528K
Here is the AUTOEXEC.BAT
@ECHO OFF
PROMPT $p$g
PATH C:\WINDOWS;C:\DOS
SET TEMP=C:\DOS
SET PATH=%PATH%;C:\CDROM
SET MTCPCFG=C:\NET\TCP.CFG
SET BLASTER=A220 I5 D1 T4
LH /L:0;2,272 /S C:\DOS\ENVIMAX N+
LH /L:0;1,16400 /S C:\DOS\SMARTDRV.EXE /X
LH C:\CRYSTAL\CWDMIX /C=13 /L=13
LH /L:1,6144 DOSKEY
LH /L:0;1,3328 /S MOUSE
LH /L:0;3,42432 /S C:\WINDOWS\net start
LH /L:0;3,6352 /S C:\CDROM\SHCDX33F.COM /D:MSCD000
SET PS2MSG=C:\THINKPAD\PS2.MSG
SET PATH=C:\CRYSTAL;C:\THINKPAD;%PATH%;C:\CARDWIZ
CONFIG.SYS
SWITCHES /F
DEVICE=C:\DOS\HIMEM.SYS /Q /TESTMEM:OFF /NUMHANDLES=128
DEVICE=C:\DOS\EMM386.EXE RAM I=B000-B7FF X=D000-D7FF AUTO NOTR
DOS=HIGH,UMB
BUFFERS=11,0
FILES=50
LASTDRIVE=G
FCBS=1,0
STACKS=0,0
DEVICEHIGH /L:0;2,8112 /S =C:\DOS\POWER.EXE
DEVICEHIGH=C:\CRYSTAL\CWDINIT.EXE
DEVICEHIGH /L:1,12048 =C:\DOS\SETVER.EXE
DEVICEHIGH /L:2,11264 =C:\CDROM\VIDE-CDD.SYS /D:MSCD000
DEVICEHIGH /L:2,4560 =C:\WINDOWS\IFSHLP.SYS
rem SystemSoft CardSoft/16(TM) PCMCIA Drivers
devicehigh=C:\CARDWIZ\CARDXTND.SYS
devicehigh=C:\CARDWIZ\SSCBTI.SYS /NUMADA:2 /ADA1SKTS:1 /ADA2SKTS:1
devicehigh=C:\CARDWIZ\CS.SYS /POLL:1
devicehigh=C:\CARDWIZ\CSALLOC.EXE
devicehigh=C:\CARDWIZ\CARDID.SYS
install=C:\CARDWIZ\CS_APM.EXE
and output of mem /c
Modules using memory below 1 MB:
Name Total = Conventional + Upper Memory
MSDOS 14,125 (14K) 14,125 (14K) 0 (0K)
HIMEM 1,120 (1K) 1,120 (1K) 0 (0K)
EMM386 3,120 (3K) 3,120 (3K) 0 (0K)
POWER 80 (0K) 80 (0K) 0 (0K)
CARDXTND 24,928 (24K) 24,928 (24K) 0 (0K)
CS 12,544 (12K) 12,544 (12K) 0 (0K)
CARDID 2,480 (2K) 2,480 (2K) 0 (0K)
CS_APM 1,888 (2K) 1,888 (2K) 0 (0K)
COMMAND 2,928 (3K) 2,656 (3K) 272 (0K)
SMARTDRV 29,040 (28K) 12,640 (12K) 16,400 (16K)
PROTMAN 400 (0K) 400 (0K) 0 (0K)
XCEMNDIS 22,480 (22K) 22,480 (22K) 0 (0K)
NDISHLP 1,440 (1K) 1,440 (1K) 0 (0K)
SETVER 448 (0K) 0 (0K) 448 (0K)
-------- 80 (0K) 0 (0K) 80 (0K
DOSKEY 3,968 (4K) 0 (0K) 3,968 (4K)
MOUSE 3,328 (3K) 0 (0K) 3,328 (3K)
POWER 4,672 (5K) 0 (0K) 4,672 (5K
VIDE-CDD 5,056 (5K) 0 (0K) 5,056 (5K)
IFSHLP 3,904 (4K) 0 (0K) 3,904 (4K)
SSCBTI 416 (0K) 0 (0K) 416 (0K)
SHCDX33F 6,352 (6K) 0 (0K) 6,352 (6K)
Free 584,992 (571K) 553,264 (540K) 31,728 (31K)
Memory Summary:
Type of Memory Total = Used + Free
Conventional 653,312 100,048 553,264
Upper 76,624 44,896 31,728
Reserved 0 0 0
Extended (XMS)* 67,031,216 3,450,032 63,581,184
Total memory 67,761,152 3,594,976 64,166,17
Total under 1 MB 729,936 144,944 584,992
Total Expanded (EMS) 33,947,648 (33,152K
Free Expanded (EMS)* 33,538,048 (32,752K
* EMM386 is using XMS memory to simulate EMS memory as needed.
Free EMS memory may change as free XMS memory changes.
Largest executable program size 553,136 (540K)
Largest free upper memory block 25,984 (25K)
MS-DOS is resident in the high memory area.
Reply 2 of 5, by matze79
This is no wonder, you have loaded a whole shitload.
Create a menu and load only drivers needed for different operations.
E.g -> Games -> only Sound, CD-Rom.
Replace EMM386.EXE for non-ems Operation with UMBPCI.SYS.
http://www.uwe-sieber.de/umbpci_e.html
if you want EMS without emm386.exe get EMSMAGIC, its now freeware and works without protect mode.
Can be loaded in High Memory and also in Conventional Memory.
And unloaded on demand.
http://www.emsmagic.com/
EMS Magic also works unter 32bit x86 Windows including Win 8 - NTVDM Box.
Do you really need this ?
LH /L:1,6144 DOSKEY
Smartdrv can be replaced by uide.sys, which also enables DMA under MS-DOS.
(Only 3Kb ? ah this is not MS Mouse.com ?)
Do you run old DOS Stuff that you need to fake Version Numbers ?
if not you can remove that too.
Working battery ? 😀
though i never used this on my T600.
Your Cardservice is pretty hungry, i would only load it if needed.
This will help you too:
http://madsenworld.dk/con_auto/index-uk.htm
Reply 3 of 5, by oeuvre
Deksor wrote:
What does output "mem /f /p" ?
Free Conventional Memory:
Segment Total
00EE2 224 (0K)
00EF0 32 (0K)
017F8 88,992 (87K)
02DB2 466,128 (455K)
Total Free: 555,376 (542K)
Free Upper Memory:
Region Largest Free Total Free Total Size
1 3,456 (3K) 3,632 (4K) 27,456 (27K)
2 2,480 (2K) 2,480 (2K) 16,384 (16K)
3 24,144 (24K) 24,160 (24K) 32,768 (32K)
As for the UMBPCI and other suggestions I'll try those when i have more time after work
Reply 4 of 5, by oeuvre
Alright I just decided to go with having 2 sets of config.sys + autoexec.bat files, one for Windows 3.11 and networking (PCMCIA card) and one for DOS games. 542K vs. 605K. Over 600K should be plenty for the things I play.. even Doom and Wolftenstein 3D work fine in 542K
Reply 5 of 5, by matze79
You just need One Set, you can make a config menu with config.sys and autoexec.bat 😀
Like on Windows Bootdisc (With CD-Rom, Without CD-Rom...)
