First post, by dormcat
- Oldbie
After seeing PCChips M748LMRT in this thread, as well as the Acer 915P (one of the last batch of 286 in 1991) in this video, I can't help wondering about the prevalence of PS/2 keyboard and mouse ports.
We knew that IBM introduced PS/2 ports in 1987, and PS/2 line of computers were discontinued in 1993. That Acer 915P, as well as my Dell Dimension XPS in 1995, have built-in PS/2 ports. On the other hand, much newer MB like M748LMRT and my Asus TXP4 (designed in 1999 and 1998, respectively), still use DIN-5 AT keyboard connectors with no PS/2 connector; you need a "form card" or extension ribbon cable to occupy an expansion slot.
At least I got my TXP4 with the standard parallel port + PS/2 module but no USB. M748LMRT has sound card and ethernet built-in (a feature even my 2001 Gigabyte GA-6VXC7-4X-P had not included) but required owners to pay extra for just a PS/2 port. 🙄 The official Intel Advanced/EV MB that my Dell Dimension XPS based on had no PS/2 port either.
So what makes motherboards of 1990's to have or have no PS/2 ports? A couple friends of mine guessed it might have something to do with licensing, as OEM MB seem to have higher ratio of having PS/2 ports than retail MB.
Or it might have something to do with the ATX form factor? Asus TXP4-X, an MB with almost identical components of TXP4, was fully ATX compliant with two PS/2, two USB, two serial and one parallel in the back plate.
