Reply 60 of 99, by Intel486dx33
My IBM Aptiva socket 7 motherboard has an option for an Intel Pentium or AMD K6 CPU.
What would you say play’s games better in Windows 98se ?
And should I add a PCI voodoo card ?
wrote:My IBM Aptiva socket 7 motherboard has an option for an Intel Pentium or AMD K6 CPU.
Got exactly the same which I'm just about to get out the loft this evening. It was shipped with the K6-300. At one point I put a 3Dfx Voodoo 3 2000 PCI with a K6-2 400 (You have to set the muti to 2x) but the motherboard can only cache 64mb of RAM so ended up chopping it all around and put an Intel Pentium 200 in it for a while, will add a Voodoo 2.
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge  DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Can it do K6-2 or just K6? If the board allows for Vcore to go as low as 2.1/2.2V then you can probably just use a K6-2 and it will be the best CPU that system can use, but I am doubtful about this. Most likely it can do 2.8-3.3V so you are stuck between K6 and MMX cpus. Between those two, MMX is significantly faster clock for clock but the fastest K6 (300) will beat the fastest MMX (233) in most tasks. This is down to K6's respectable integer operations performance but the MMX's floating point performance is better so it does much better in software rendered 3D games. Thus adding a PCI voodoo card is exceptionally useful if you go for a K6 CPU instead of a Pentium MMX - it levels the playing field. I personally prefer K5/K6/K6-2 to Pentium/MMX/PentiumII but that is just taste. From a sheer performance and compatibility point of view the Intel chips and chipsets are slightly superior.
Yes, It came with an AMD K6 or K6-2 @ 300 or 333mhz. I don't remember.
But I am partial to Intel CPU's so I put a Pentium 233mmx CPU in it.
I just always had good success with Intel CPU's.
Previously, AMD CPU's always gave me problems.
But I must have been setting them up wrong with jumpers because they work fine now.
I still prefer Intel for an all around CPU.
But AMD CPU's are preferred by many gamers.
wrote:What is that power supply connector looking port with the 12v and speaker symbol sticker for?
Probably to connect 12V DC powered speakers, the first ATX case I bought in the late 90's came bundled with a pair of crappy speakers and had a similar connector in the back.
Yes, Some Aptivas came with matching speakers and were usually powered vie 12VDC. Aptivas and other cases of that time featured a 12VDC breakout sometimes and DC to DC cables to connect the speakers so you don't need another power connection for the speakers.
wrote:1) Is it safe to use this psu?
I have never had any problems with those two IBM power supplies. They have brown Nichicon capacitors inside, which can last many more years. I'm not sure what you have heard.
By the way, that API-3186S PSU should be an excellent replacement, because it's more powerful (on all rails) which means less 'stress' on the components.
wrote:While searching for the psu I also got my hands on a S3 virge(diamond) and a Rage pro Turbo. When browsing through google and yo […]
When browsing through google and youtube it looks like I just have to plug in the cards in the correct slot, install the drivers and maybe disable the onboard graphics? (As the cd-rom wasnt working, I got myself some floppy-disks and an external drive.)2) Do i just plug in the cards and install the drivers?
3) Are those cards any good for my 'goal'? The info i found online seems to tell me they are.
Yes, you can disable the onboard graphics chip (from SiS or ATI, depends on your board) by setting a jumper. Thereafter you install a graphics card and then the driver (usually it's this sequence).
If you want to play DOS games, then the S3 Virge card is a great choice (maybe not the best, but absolutely fine for most games). The Rage Pro Turbo card is designed for Windows 9x games and the bottleneck in your system with that card will be the slow CPU.
S3 ViRGE is also great for modern gaming
I've always liked that case design. Something about it is just... right.
IBM always had really nice, clean, professional looking designs.
wrote:S3 ViRGE is also great for modern gaming
It's also great for "deep learning". Who needs the RTX Titan!!!
Asus P5N-E Intel Core 2 Duo 3.33ghz.  4GB DDR2  Geforce 470 1GB SB X-Fi Titanium 650W XP SP3
MSI x570 Gaming Pro Carbon Ryzen 3700x 32GB DDR4 Zotac RTX  3070 8GB WD Black 1TB  850W
This is my favorite computer case.
They look so clean and simple with the front door closed.
IBM Aptiva 2176-C73
I really like the IBM PS/1 486 Essential/Value PC too.
IBM really did succeed in making there windows/dos installations simple and fail proof.
I like to use the IBM disk images in my IBM 486’s
And IBM disk image installations in my Aptiva’s.
wrote:Yes, you can disable the onboard graphics chip (from SiS or ATI, depends on your board) by setting a jumper. Thereafter you inst […]
3) Are those cards any good for my 'goal'? The info i found online seems to tell me they are.Yes, you can disable the onboard graphics chip (from SiS or ATI, depends on your board) by setting a jumper. Thereafter you install a graphics card and then the driver (usually it's this sequence).
Hi!
Glad to hear the psu is safe to use, and maybe even a bit 'better' then the old one.
I had some trouble with connecting because the cables were rather stiff, but got everything connected in the end.
All seems to be working properly now. At first there were some hardware and sound problems but after finding the correct drivers and switching slots a few times, he finally recognized my vibraC sound card. The looks on your friends faces when they see you transfering those drivers using floppy's is priceless btw 😀
Good to hear that the s3virge is a suitable card for my build. It looks like the Rage Pro has a different slot type than is available on my motherboard. (agp?) So I think maybe for another computer someday.
The next 'assignment', is getting the sound working in dos and installing the s3.
Since I just had to look up what a jumper is, I first have to catch up on some reading. (think there is a Trident chipset onboard)
Thanks for your response,
Hi I was wondering if someone on here knew the dimensions/measurements of this computer.
oeuvre wrote on 2018-06-03, 01:21:I've not tried the newer Aptivas like those you pictured. They're always out of my price range. Intellistations are really cool and built well...
Hi, did your aptiva already come with Pentium 200 CPU or did you install it later? If so, didn't you have any error with the BIOS not recognizing the CPU?
- IBM Aptiva 2176/P200MMX overdrive/Voodoo 4mb
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Have any of you fine Aptiva owners that have a system with a riser card had issues with ISA cards causing the system to not boot?
I've got a 2176 and post-cleaning and restoration the Mwave card just causes it to not post, no beeps. It boots with a PCI card but only occasionally seems to see it. Power comes through clean, connections are solid. I have a similar issue on an identical motherboard, however that motherboard was on its last legs too. I've tried two different riser cards on both mobos. Original
Apologies for resurrecting an old thread and thank you!
I got an IBM Aptiva 2178 with a P3 600 Coppermine. Then i installed 128Mb RAM PC133, a DVD drive and an HDD and a Voodoo 3 3000 AGP card. As sound card i'm using the embeeded ESS Allegro 1.
But i have a weird problem. the PC do "one long beep and three short" before the first BIOS screen, i can't figure out what could be. I searched into the BIOS, i disabled useless things to me ( Like serial-parallel port, power managment.....etc ) but nothing changes. Except that the PC works like a charm.....i did stabilities tests, 3dmark 2000, games.....everything is fine! But still there is this BEEP code at the boot.
Also, there is nothing for monitoring the hardware, like temperatures, voltages...is that normal ? The BIOS is empty, and SpeedFan, AIDA64, HWInfo says nothing, looks like they can't detect any info hw chips ( if there exist into the motherboard ). I can't believe IBM didn't put anything.
Here's the video:
https://drive.google.com/file/d/1k8pFW6gvFH6t … iew?usp=sharing
_StIwY_ wrote on 2023-05-13, 09:30:I got an IBM Aptiva 2178 with a P3 600 Coppermine. Then i installed 128Mb RAM PC133, a DVD drive and an HDD and a Voodoo 3 3000 […]
But i have a weird problem. the PC do "one long beep and three short" before the first BIOS screen, i can't figure out what could be. I searched into the BIOS, i disabled useless things to me ( Like serial-parallel port, power managment.....etc ) but nothing changes. Except that the PC works like a charm.....i did stabilities tests, 3dmark 200, games.....everything is fine! But still there is this BEEP codes at the boot.
Here's the video:
Have you checked the battery? I also remember having a similar issue on my Aptiva but mine was a 2134 model... iirc it was related to some APM setting on bios... Also, did you try the diagnostics disk for that model, if it has one?
