IBM APTIVA MASTER RACE!
Reply 60 of 74, by Intel486dx33
My IBM Aptiva socket 7 motherboard has an option for an Intel Pentium or AMD K6 CPU.
What would you say play’s games better in Windows 98se ?
And should I add a PCI voodoo card ?
Reply 61 of 74, by foey
Got exactly the same which I'm just about to get out the loft this evening. It was shipped with the K6-300. At one point I put a 3Dfx Voodoo 3 2000 PCI with a K6-2 400 (You have to set the muti to 2x) but the motherboard can only cache 64mb of RAM so ended up chopping it all around and put an Intel Pentium 200 in it for a while, will add a Voodoo 2.
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 62 of 74, by appiah4
Can it do K6-2 or just K6? If the board allows for Vcore to go as low as 2.1/2.2V then you can probably just use a K6-2 and it will be the best CPU that system can use, but I am doubtful about this. Most likely it can do 2.8-3.3V so you are stuck between K6 and MMX cpus. Between those two, MMX is significantly faster clock for clock but the fastest K6 (300) will beat the fastest MMX (233) in most tasks. This is down to K6's respectable integer operations performance but the MMX's floating point performance is better so it does much better in software rendered 3D games. Thus adding a PCI voodoo card is exceptionally useful if you go for a K6 CPU instead of a Pentium MMX - it levels the playing field. I personally prefer K5/K6/K6-2 to Pentium/MMX/PentiumII but that is just taste. From a sheer performance and compatibility point of view the Intel chips and chipsets are slightly superior.
Reply 63 of 74, by Intel486dx33
Yes, It came with an AMD K6 or K6-2 @ 300 or 333mhz. I don't remember.
But I am partial to Intel CPU's so I put a Pentium 233mmx CPU in it.
I just always had good success with Intel CPU's.
Previously, AMD CPU's always gave me problems.
But I must have been setting them up wrong with jumpers because they work fine now.
I still prefer Intel for an all around CPU.
But AMD CPU's are preferred by many gamers.
Reply 64 of 74, by soviet conscript
oeuvre wrote:
https://i.imgur.com/sEVGlq2m.jpg […]
the rear
What is that power supply connector looking port with the 12v and speaker symbol sticker for?
Reply 65 of 74, by TheMobRules
Probably to connect 12V DC powered speakers, the first ATX case I bought in the late 90's came bundled with a pair of crappy speakers and had a similar connector in the back.
Reply 66 of 74, by jaZz_KCS
Yes, Some Aptivas came with matching speakers and were usually powered vie 12VDC. Aptivas and other cases of that time featured a 12VDC breakout sometimes and DC to DC cables to connect the speakers so you don't need another power connection for the speakers.
Reply 67 of 74, by SpectriaForce
Elpast0r wrote:
1) Is it safe to use this psu?
I have never had any problems with those two IBM power supplies. They have brown Nichicon capacitors inside, which can last many more years. I'm not sure what you have heard.
By the way, that API-3186S PSU should be an excellent replacement, because it's more powerful (on all rails) which means less 'stress' on the components.
RETROGAMEPC.COM
Reply 68 of 74, by SpectriaForce
Elpast0r wrote:
While searching for the psu I also got my hands on a S3 virge(diamond) and a Rage pro Turbo. When browsing through google and yo […]
When browsing through google and youtube it looks like I just have to plug in the cards in the correct slot, install the drivers and maybe disable the onboard graphics? (As the cd-rom wasnt working, I got myself some floppy-disks and an external drive.)
2) Do i just plug in the cards and install the drivers?
3) Are those cards any good for my 'goal'? The info i found online seems to tell me they are.
Yes, you can disable the onboard graphics chip (from SiS or ATI, depends on your board) by setting a jumper. Thereafter you install a graphics card and then the driver (usually it's this sequence).
If you want to play DOS games, then the S3 Virge card is a great choice (maybe not the best, but absolutely fine for most games). The Rage Pro Turbo card is designed for Windows 9x games and the bottleneck in your system with that card will be the slow CPU.
https://en.wikipedia.org/wiki/S3_ViRGE
RETROGAMEPC.COM
Reply 70 of 74, by x0zm_
I've always liked that case design. Something about it is just... right.
Builder of Unique Retro Things
[Dimension95 - Dream 586 Setup] [TOXIC - PIII on Water] [More Coming Soon]
Reply 72 of 74, by buckeye
oeuvre wrote:
S3 ViRGE is also great for modern gaming
It's also great for "deep learning". Who needs the RTX Titan!!!
Foxconn Q45M E8400 Core2 Duo 3GB DDR2 800 BFG Geforce 7950GT 512MB X-Fi Xtreme Music 500W XP SP3
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
Intel DH61CR i3 LGA-1155 8GB DDR3 EVGA 1050ti 4GB 480GB SSD 650W
Reply 73 of 74, by Intel486dx33
This is my favorite computer case.
They look so clean and simple with the front door closed.
IBM Aptiva 2176-C73
I really like the IBM PS/1 486 Essential/Value PC too.
IBM really did succeed in making there windows/dos installations simple and fail proof.
I like to use the IBM disk images in my IBM 486’s
And IBM disk image installations in my Aptiva’s.
    364.26 KiB
    131.05 KiB
    117.49 KiB
    382.62 KiB
    376.21 KiB
Reply 74 of 74, by Elpast0r
SpectriaForce wrote:
Yes, you can disable the onboard graphics chip (from SiS or ATI, depends on your board) by setting a jumper. Thereafter you inst […]
Hi!
Glad to hear the psu is safe to use, and maybe even a bit 'better' then the old one.
I had some trouble with connecting because the cables were rather stiff, but got everything connected in the end.
All seems to be working properly now. At first there were some hardware and sound problems but after finding the correct drivers and switching slots a few times, he finally recognized my vibraC sound card. The looks on your friends faces when they see you transfering those drivers using floppy's is priceless btw 😀
Good to hear that the s3virge is a suitable card for my build. It looks like the Rage Pro has a different slot type than is available on my motherboard. (agp?) So I think maybe for another computer someday.
The next 'assignment', is getting the sound working in dos and installing the s3.
Since I just had to look up what a jumper is, I first have to catch up on some reading. (think there is a Trident chipset onboard)
Thanks for your response,
