Reply 680 of 1380, by feipoa
- l33t++
I thought I would drive in the issue with clearance around the socket a little more. This is just on the same motherboard, I have one near miss that would get hit with a tantalum on the bottom, and another direct hit. You can see a jumper directly hitting the PCB. If that jumper is under the VRM section, it will hit any component. So I think it is a good idea not to even leave solder pads for a bottom cap as a jumper will short on it.
