Reply 40 of 71, by ux-3
Shponglefan wrote on 2024-06-23, 15:13:AWE64 doesn't have a wavetable header. It's an unfortunate limitation on an otherwise good sound card.
And I'm okay with sound card debate here. I mean, this build is about sticking a whole bunch of sound cards in one PC so it seems topical. 😁
OK then. 😀
I wasn't refering to the AWE64. I was talking about my preference for a SBpro clone with a wavetable header. I know the AWE64 doesn't have one, otherwise things would be much easier.
Shponglefan wrote on 2024-06-23, 16:03:older AWE32 cards used genuine Yamaha chips for FM synthesis whereas later cards used Creative Labs own CQM synthesis, so FM playback will sound different. Different models have different DSP chips (some are noisier than others). Some have the DMA clicking bug. Etc.
My preference is to go with an AWE64 for SB16/AWE32 support, then supplement other sound support (FM / MIDI, etc) with another card.
This is pretty well the conclusion I arrived at too. About 15-20 years ago, when old soundcards mainly costed just postage, I bought several Soundblasters. Most of them turned out to be "useless". I only kept four for later(TM) use. Of these chosen four, just two remained usefull. I still see good use for the Awe64 gold, but I wouldn't buy one at current prices. Got an AWE64 value (512kB) the other day for a good price. I also still see limited use for the AWE32 CT3980, because it has OPL3, wavetable header with only 'legitimate hanging notes bug', and the 1703-A type mixer. I didn't know about the DMA clicking at the time. Glad I didn't, as the thing grew extremely expensive and I have a special "just one ISA" use case.
I also got the AWE32 CT-2760 rev3, which fills the same bill as the CT3980, except for a knockout difference: It has the 1701-T chip, which is very noisy. So I am not using it. Then I have the SB CT-1740 DSP 4.04, which is a dream card on paper. As long as you don't listen to it. Sounds like an old record that was used by kids a lot. For quick, driver free testing, it is OK. But to use it myself? God forbid.
Without a partner, none of the two useful cards will do it. They both need a SBpro partner to do the full job. The AWE32 needs 8 bit voice to avoid DMA clicking and the AWE64 needs some decent FM and a wavetable header. For both, I have settled on ESS SBpro clones. I haven't tried all SBpro clones (daunting task), but these are close enough. I have tried Yamaha-719, but I didn't like the sound/filtering nearly as much as the ESS or genuine AWE32 OPL3.
After conversing with you, I briefly experimented with 3 ISA cards in one machine, but realized that I just have no need or nerve for more than two. With two, I can get all the basics covered that matter to me while keeping it relatively simple.
Retro PC warning: The things you own end up owning you.
