Reply 60 of 78, by Nemo1985
1976ANDREI wrote on 2022-05-17, 19:25:
Can you upload the firmware file for 771?
I'm heading home right now, I will upload the bios with updated microcodes for 775 and 771 when I have some time.
Reply 61 of 78, by Nemo1985
Nemo1985 wrote on 2019-02-25, 18:12:
That would be interesting, I'm trying to update the microcodes but mmtool claims that they are not valid since the file size is […]
That would be interesting, I'm trying to update the microcodes but mmtool claims that they are not valid since the file size is different... any suggestion?
About the cpu i'm actually undecided between E7600 and E5800, the first supports the sse4.1 but it has a lower speed and according to your suggestion E5800 seems better.
Edit: I̶ ̶u̶p̶d̶a̶t̶e̶d̶ ̶e̶v̶e̶r̶y̶t̶h̶i̶n̶g̶ ̶e̶x̶c̶e̶p̶t̶ ̶t̶h̶e̶ ̶c̶p̶u̶0̶0̶F̶4̶8̶_̶p̶l̶a̶t̶0̶2̶_̶v̶e̶r̶0̶0̶0̶0̶0̶0̶0̶E̶_̶2̶0̶0̶8̶-̶0̶1̶-̶1̶5̶_̶P̶R̶D̶_̶0̶E̶1̶5̶8̶E̶1̶0̶ ̶a̶s̶ ̶a̶ ̶s̶i̶d̶e̶ ̶n̶o̶t̶e̶,̶ ̶I̶ ̶w̶o̶n̶d̶e̶r̶ ̶w̶h̶a̶t̶ ̶m̶i̶c̶r̶o̶c̶o̶d̶e̶s̶ ̶a̶r̶e̶ ̶t̶h̶o̶s̶e̶ ̶s̶i̶n̶c̶e̶ ̶g̶o̶o̶g̶l̶e̶ ̶g̶i̶v̶e̶s̶ ̶n̶o̶ ̶r̶e̶s̶u̶l̶t̶s̶ ̶w̶i̶t̶h̶ ̶i̶t̶.̶
Every microcode has been updated, there is one microcode fewer because intel merged the platforms for CPUID 10676.
CR865PE172MC.7z
There are no microcodes for 771 but apparently they can be added without issues, the total number of microcodes goes up to 33, if anyone is willing to test it I can upload that file too.
Addedd the lastest microcodes for the 771 cpus
Reply 62 of 78, by Legacysystem
I tried some MOBO's in there.
ASUS P5P800 (Not SE version or VM version): After BIOS update, I tried Pentium D 820 and Pentium D 945. With Pentium D 945, there is no life in screen, but interestingly, it works with Pentium D 820 but it detects ONLY single-core. Not 2 core-2 thread CPU in P5P800. Its limited with Pentium 4 HT (1 Core-2 thread P4's.) and Celeron D CPU's.
MSI PM8PM-V (MS-7222 REV 2.0): I updated to latest V5.5 BIOS and I tried Q6600 with both revisions and no work. This mobo doesn't support Core 2 Quad. Also I tried Pentium D 820 and every time I got blue screen crash. Not tried with Core 2 Duo but I'm not sure about its Core 2 Support. I think that mobo is limited by Pentium 4 and Celeron D CPU's. With weak capacitors, too much underperforming MOBO. Also limited with 2 GB DDR2-533 Memory. Not supporting more than 2 GB memory.
ECS P4M800PRO-M2: Also that one not support Core 2 Quad. Not try with Core 2 Duo but almost everyone confirms that one supports Core 2 Duo. I don't want to be against that because.
ASRock 775DUAL-VSTA: Perfectly supports B3 Revision 1066 MHz FSB Core 2 Quad Kentsfield CPU's with unofficial 3.19a BIOS. Succesfully supporting 4 GB DDR2 667 MHz memory with 3.19a unofficial BIOS. Also I'll try G0 Revision Kentsfield CPU's, Yorkfield CPU's and more memory than 4 GB DDR2.
Ancient system: Intel D865GLC + P4-EE (SL7CH Gallatin) + HD 4670 AGP + 4 GB DDR400 RAM + 256 GB Corsair Neutron SSD + 3 * 320 GB IDE PATA WD HDD
Retro system 2: ASRock ConRoe865PE + Q6600 (SL9UM)+ HD 3850 AGP + 4 GB DDR400 RAM + 120 GB Kingston SSD
Reply 63 of 78, by Pypical
Do any of these boards support 3.3v cards? I assume it would be a universal AGP slot if it did, but I don’t really care which slot or if it’s emulated or what processors it supports.
Reply 64 of 78, by The Serpent Rider
No.
Reply 65 of 78, by gregorem
Hi guys.
I searching for full ATX board with Core 2 Duo support for Windows 98/Me and Windows XP build. I have one LGA 1336 setup for late XP/Vista/Windows 7 gaming, but want also something more suitable for slightly older period.
I know that Core 2 is not necessary for Windows 9x gaming, however it working nice with XP and more CPU power was never a bad thing.
I had some luck and bought Geforce 5950 in good condition, so now looking for nice mobo with nice CPU.
Because it should working with both, 9x and XP, it should also be appropriate equipped with both IDE and SATA ports, floppy connector (yes, I like using floppy with my retrosetup), CD in, serial and parallel ports, PS/2, and USB for convince. Preferably full ATX.
It seems the best choice would be some of Gigabyte 8I865GME, but they are extremely hard to track in my country, and also only mixrATX.
Asrock boards are more common, but they had pretty bad reputation.
Could you guys recommend me something similar in specs to GA-8I865GME-775-RH but in full ATX (or at least easier to find)?
Reply 66 of 78, by Karbist
gregorem wrote on 2024-03-03, 11:30:
Gigabyte GA-8I865PE775-G-RH rev 3.0 or 4.9
Only Asrock and Gigabyte have full ATX boards.
Reply 67 of 78, by gregorem
Since Asrock boards are much more common, are they really that bad?
Reply 68 of 78, by vsharun
gregorem wrote on 2024-03-03, 15:39:
I have five rev 2.03/2.04 775i65G's and they do not support agp 8x cards actually while supplying 1.5V on mosfets near AGP slot. Two-notched AGP cards which 8x compatible also DNW.
Only 2x and 4x universal cards are ok (Gf2/GF3). None of my FX5200/5500/5900's, Radeon 9800 pro and Gf4 Ti 8x are even post. Old/new bioses E5800 or Celeron D - doesn't matter also. Memory doesn't matter also.
Reply 69 of 78, by DarthSun
vsharun wrote on 2024-08-05, 14:45:
I also have the run R9800Pro and the HD3850.
https://cdn.rios.hu/dl/upc/2021-09/30/225621_ … m2001_27705.jpg
https://cdn.rios.hu/dl/upc/2021-09/26/225621_ … _xp_3dm2001.jpg
The motherboard - https://cdn.rios.hu/dl/upc/2021-09/17/225621_ … ynj3_titanp.jpg
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 70 of 78, by PcBytes
Strange, my 775i65G Rev2.03 worked perfectly (and even got sold) with a FX5500 AGP8x from Palit.
Karbist wrote on 2024-03-03, 12:15:
ASUS P5P800 is also full ATX.
Reply 72 of 78, by PcBytes
Oh, my bad. I thought it was about full ATX 775+i865 chipsets 😀
Reply 73 of 78, by vsharun
This is for record: not all of the motherboards has this issue, and AGP 8x DNW seems to be related somehow to aged caps. I bought another three, they're $5-7 cheap, and they have no issues at all.
several Asus P5PE-VM has issues with PCI slots for, seems also age related.
PcBytes wrote on 2024-08-05, 17:45:
Strange, my 775i65G Rev2.03 worked perfectly (and even got sold) with a FX5500 AGP8x from Palit. […]
Reply 74 of 78, by Nemo1985
Age related or cap age related? It would be different if with a recap the issue will go away.
Reply 75 of 78, by vsharun
Nemo1985 wrote on 2024-10-16, 17:11:
Dunno actually, do not have enough time to recap plus very tight space/contacts for AGP-related caps. Maybe I'll swap them by soldering pin-to-pin, IBM way - with looong pins front side from factory soldering.
Reply 76 of 78, by shfil
Motherboard that is missing on list: ECS 865G-M8.
https://www.newegg.com/p/N82E16813135018
https://www.ecs.com.tw/en/Product/Motherboard … 0/specification
Also early revisions of MSI PM8PM-V (MS-7222) have worse support for cpus. Mine v1.1 does not support core 2 duo.
https://www.cpu-upgrade.com/mb-MSI/PM8P ... 7222).html
Also third thing, these links may interesting (bios mod that is adding support for wolfdale on gigabyte motherboards with 865g):
https://www.bios-mods.com/forum/showthread.php?tid=39271
https://www.bios-mods.com/forum/showthread.php?tid=37785
Reply 77 of 78, by shfil
Noticed some more with 865g:
DFI ITOX G7S300-B https://theretroweb.com/motherboards/s/dfi-itox-g7s300-b
Proof: https://www.dfi-itox.com/pages/products/mothe … /g7s300-b-g.php
Colorful C.865G-775 Ver2.2 https://theretroweb.com/motherboards/s/colorf … 865g-775-ver2-2
Proof: https://dn790008.ca.archive.org/0/items/manua … 282/2500282.pdf
AOpen i865Gm-7L https://theretroweb.com/motherboards/s/aopen-i865gm-7l
Proof: manual is using name I865Ga-7 IL/IF though https://theretroweb.com/motherboard/manual/i8 … 99854943843.pdf
Reply 78 of 78, by 000557A
Hi, I just tested a P5S800-VM with Pentium D 805. I am running latest bios 1023
It posts / boots to bios, haven't gotten around to testing it in Windows though. (Image attached below)
Daily PC (80 CAD build) : Ryzen 7 3700X | B550M DS3H | 2080TI | 16G Ram
Main Retro System : Athlon X2 4800+ | A8V Deluxe | 8GB DDR ECC | X800GTO/PRO/4670/3850 AGP
