Reply 40 of 125, by sfryers
- Member
DustyShinigami wrote on 2024-11-16, 18:04:sfryers wrote on 2024-11-16, 17:36:MSCDEX doesn't need you to tell it what drive letter your CD-ROM is going to use, it'll just take the next available letter that's not being used by your hard drives. Use MSCDEX /D:OPTICAL to specify the device name. The /E parameter has a different purpose- it tells MSCDEX to use expanded memory.
Oh. I thought I had to specify what my drive letter is, which in my case is E:?
You can specify the drive letter manually, but you don't need to if you're happy with the default setting- ie. following directly after your hard drives. If you did want to specify, for example, that MSCDEX should use drive letter H: for your CD-ROM, you can do this with the command MSCDEX /D:OPTICAL /L:H
MT-32 Editor- a timbre editor and patch librarian for Roland MT-32 compatible devices: https://github.com/sfryers/MT32Editor
