Reply 140 of 186, by DustyShinigami
Tiido wrote on 2024-12-21, 10:47:
For YMF71x the only WDM driver is what comes with Windows itself and you lose it when you install the Yamaha's drivers. There's probably a way to extract it from the CD and make use of it but overall it is a downgrade, especially if you want to use the card for anything DOS.
I see. I did take a look on the 98SE disc for drivers related to the card, but I couldn’t see any. There were no Yamaha folders as I recall.
But I’ll stick to VXD. That seems to be recommended and best for DOS etc.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 141 of 186, by Tiido
The drivers are inside the CAB files in the installation data directory, along with all the other drivers for devices that are natively supported out of box.
Reply 142 of 186, by DustyShinigami
Tiido wrote on 2024-12-21, 15:42:
Thanks for the heads-up. I'll take another look later. I need to do a test to fix a problem anyway, which will involve uninstalling the drivers, the card, and then re-installing them.
OS: Windows 98 SE
Reply 143 of 186, by DustyShinigami
Still not seeing it. Are you referring to the original Windows 98 disc (FE)? Or SE? I have SE installed, but I do have both versions. I checked both, but haven’t been able to locate it.
OS: Windows 98 SE
Reply 144 of 186, by Tiido
It isn't an obviously plain to see stuff. You're gonna have to find the right INF from the thousands of others and then all the driver files referenced in that INF.
I don't know if 98FE has it in it, but 98SE and ME definitely have the WDM drivers for these cards.
In case of 98SE and ME, WDMA_YMH.INF is file of interest. With luck it already is in Windows dir in the hidden INF folder and the driver files referenced in it, scattered in the system dirs.
Reply 145 of 186, by DustyShinigami
I'm considering getting myself an MT-32 at some point. Not sure when yet. But I just wanted to find out - will I need to get any other adapter, cable, or device to hook it up to my sound card with already having my SC-55 hooked up? I mean, I have my SC-55 connected to one of those adapter boards from Serdashop, but would I need to order another one, or something similar, for the MT-32? My Yamaha only has the one game/MIDI port, which is taken, though my SB Live! has one.
OS: Windows 98 SE
Reply 146 of 186, by Shponglefan
DustyShinigami wrote on 2025-12-15, 12:18:
Are you talking about this adapter? https://www.serdashop.com/DB15MIDI
If so, it has dual MIDI out so you could just hook up the MT-32 to the other MIDI out port.
Then you'll just need a way of mixing the audio from the MT-32. If you're already using a dual sound card and planning a dual MIDI module setup, I'd recommend an external audio mixer if you don't already have one.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 147 of 186, by DustyShinigami
Shponglefan wrote on 2025-12-15, 13:44:
Are you talking about this adapter? https://www.serdashop.com/DB15MIDI […]
Yeah, that's the one.
I don't quite follow. Would I still need to get another one though? Both MIDI cables are plugged into the one I have for my SC-55. Or do you mean I'd unplug one from the SC-55 and use that cable for the MT-32...?
And an audio mixer... Someone mentioned one of those before (it might have been you, even :p). I remember them being quite pricey. ^^; Any recommendations? Thanks.
OS: Windows 98 SE
Reply 148 of 186, by Shponglefan
DustyShinigami wrote on 2025-12-15, 14:05:
The adapter has two outputs, not an input/output. You don't need to plug in two cables for the SC-55. You just need to connect the output from the adapter to the input on the SC-55.
You can then use the other output on the adapter to connect the MT-32.
I use Edirol (Roland) M-10MX mixers. They're compact powered mixers that can connect up to 5 stereo devices (10 channels). Looking on Ebay they sell for between $70 to $100 USD.
Reply 149 of 186, by DustyShinigami
Shponglefan wrote on 2025-12-15, 14:45:
The adapter has two outputs, not an input/output. You don't need to plug in two cables for the SC-55. You just need to connect t […]
Ah. And there was me thinking the SC-55 needed the two cables to be plugged in. ^^; The more you know...
Cool, thanks. I'll look into them. They might be a bit more on eBay UK, but I'll check.
EDIT: Okay, so about £85. It will, of course, make getting an MT-32 that extra bit more expensive if I got those together. Although I could always toggle between the two depending on the game.
OS: Windows 98 SE
Reply 150 of 186, by DustyShinigami
There's a model I've been watching on eBay and the seller has offered £50 off. It's an original early model apparently. It's a 15bit as opposed to the later 16bit. Is there any pros or cons to getting 15bit over 16bit?
OS: Windows 98 SE
Reply 151 of 186, by Shponglefan
DustyShinigami wrote on 2025-12-15, 21:44:
There is different audio compatibility with certain games depending on which version of the MT-32 (old vs new).
You can see a list here: https://www.vogonswiki.com/index.php/List_of_ … _computer_games
Personally, I use the 'old' version of the MT-32 with my setups and use CM-series modules for later stuff.
Reply 152 of 186, by DustyShinigami
Shponglefan wrote on 2025-12-16, 00:27:
There is different audio compatibility with certain games depending on which version of the MT-32 (old vs new). […]
Awesome. Thanks for the list. I'll check it over. 😀 I suspect I'll end up getting it. It's the cheapest I've come across so far. Incidentally, what's 'CM-series'?
OS: Windows 98 SE
Reply 153 of 186, by Shponglefan
DustyShinigami wrote on 2025-12-16, 00:45:
CM-series refers to the "Computer Music" series of modules. It includes the CM-32L, CM-64, CM-300, CM-500, among others.
The CM-32L and/or CM-64 are the ones worth having. They are basically an MT-32 "new" with extra sound effects that a handful of games make use of.
Reply 154 of 186, by DustyShinigami
Shponglefan wrote on 2025-12-16, 00:51:
I see. So, are those daughter boards? Or are they a type of sound font you add to the canvas? I noticed in that list a number of the games I own have some distortion/incorrect sounds with the old module over the new.
OS: Windows 98 SE
Reply 155 of 186, by Shponglefan
DustyShinigami wrote on 2025-12-16, 00:59:
No, they are standalone sound modules just like an MT-32 or SC-55.
Reply 156 of 186, by DustyShinigami
Looks like my ISA Yamaha is fried, so I'm in the market for a replacement OPL3 ISA sound card. I've been considering the Sound Blaster AWE 64 or Gold, but read there are problems with that...? I may have had a recommendation or two in the past, but I honestly can't remember. Nor do I know what page. ^^; So any suggestions would be great. I did come across a CT4520 on eBay, but I think I read it doesn't have a real OPL chip.
OS: Windows 98 SE
Reply 157 of 186, by DustyShinigami
Hmm. Not an easy decision to make. Definitely want that real OPL3 chip/FM sound, even if I don't really use it. It's nice to have that option/customisability. But looking at the list of Sound Blasters from best to worst, I would prefer to avoid the hanging note bug. Though getting an earlier card, like a real SB16, means more money. ^^;
OS: Windows 98 SE
Reply 158 of 186, by DustyShinigami
I think I'm just going to play it safe and get the same card again. It was a solid card and the same seller is selling one for the same price. Maybe at a later date I'll get a Sound Blaster Pro 2 as well.
OS: Windows 98 SE
Reply 159 of 186, by Shponglefan
Getting a replacement Yamaha sound card would be my recommendation as well.
Sound Blaster cards can be a mess to sort out with all the different models. Generally I would only look at Sound Blaster cards for Sound Blaster 16 and/or AWE32 support, and possibly Yamaha OPL FM depending on the model. I would not consider any Sound Blaster cards if the intent is to use them for MIDI playback.
It also might be possible to repair your existing Yamaha card. As long as the main IC isn't damage, everything else on the card should be replaceable.
