Reply 140 of 281, by DustyShinigami
- l33t
Tiido wrote on 2024-12-21, 10:47:For YMF71x the only WDM driver is what comes with Windows itself and you lose it when you install the Yamaha's drivers. There's probably a way to extract it from the CD and make use of it but overall it is a downgrade, especially if you want to use the card for anything DOS.
I see. I did take a look on the 98SE disc for drivers related to the card, but I couldn’t see any. There were no Yamaha folders as I recall.
But I’ll stick to VXD. That seems to be recommended and best for DOS etc.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
