First post, by Joseph_Joestar
System specs
  • Intel Pentium MMX 200 MHz
  • QDI P5I430TX Titanium IB+ (Intel 430TX)
  • 64 MB SDRAM
  • Matrox Millennium II 4 MB
  • ESS AudioDrive 1868F
  • Sound Blaster 16 MCD (CT1750)
  • Samsung 3.5" floppy drive
  • CF to IDE adapter + Transcend 2 GB Industrial CF card (CF300)
  • Philips 40x CD-ROM
  • LC Power 550W PSU
  • LG Flatron L1753HR 17" LCD monitor
  • Cambridge SoundWorks Digital 2.1 Speakers
Introduction
Another DOS focused Pentium MMX build, but with a slight twist. Thanks to the QDI Titanium motherboard, this rig has a lot more slowdown options. More details below.
CPU
This Pentium MMX 200 CPU has enough power to comfortably run most DOS games. It does struggle with late 3D SVGA titles like Quake and Tomb Raider when using software rendering, but I have a different, much more powerful system which can properly handle such games. The best thing about this CPU is that it can be slowed down to 386 and 486 levels which is important for a number of speed sensitive games. By using SetMul and optionally disabling the motherboard L2 cache in the BIOS, it's possible to fine tune CPU speed.
For example, with both L1 and L2 caches disabled, along with SetMul BPD VPD, the system runs like a slow 386, which is nice for the original Wing Commander. On the other hand, with just SetMul CCD applied, while leaving both caches enabled, the system behaves like a fast 486. That's great for games like One Must Fall 2097 and WarCraft 1 which run too fast on a Pentium but too slow on a 386. There are other in-between speeds that can be reached using the Pentium test registers as showcased in this video by Phil. Finally, since this CPU tops out at 200 MHz, it isn't affected by the dreaded "Runtime Error 200" issue which plagues many DOS games from this time period (e.g. Jazz Jackrabbit). I know that there are patches and workarounds for that, but it just feels nice not having to worry about it at all.
For DOS games which crash due to too much RAM, I use XMSDSK & EMSDSK which lowers the available memory to 32 MB and that usually solves the issue. If necessary, it's possible to lower the memory even further (e.g. to 8 MB) in case some game needs that. And for games that don't like fast CD-ROM devices, I use the excellent CDBeQuiet! utility which sets the drive speed to 4x, making it blissfully quiet in the process.
Motherboard
The QDI Titanium IB+ motherboard is based on the Intel 430TX chipset, but it has some unique features. Most importantly, it allows you to change the CPU frequency directly from the BIOS, without setting any jumpers. This is very useful if you need to slow down the CPU even further. As an example, I can easily set my Pentium MMX 200 to run at 100 MHz (2x50) straight from the BIOS. The board also has a PS2 mouse header, with its pinout properly documented in the manual, which is helpful in case you need to rewire a generic bracket to fit there. My only nitpick with this motherboard is that the Power LED gets dimmed instead of turned off when using an ATX power supply. Fortunately, this can be worked around by connecting the Power LED to the Sleep LED header, as described here.
Graphics card
The Matrox Millennium II is another highlight of this build. Image quality is exceptional for its time (250 MHz RAMDAC) and the WRAM is an interesting feature as well. Additionally, it can use the proprietary MSI (Matrox Simple Interface) API which some DOS games like Tomb Raider do support. Its DOS compatibility isn't perfect, but some of the issues can be worked around. For example, the choppy scrolling in Jazz Jackrabbit can be eliminated by slowing down the CPU to 100 MHz, as mentioned earlier. And a similar issue in Commander Keen 4 can be resolved by enabling the in-game "Fix Jerky Motion" setting. Anyhow, I think the exceptional image quality that this card brings to the table outweighs these minor compatibility issues.
Sound card #1 - ESS AudioDrive 1868F
I like the SBPro style low-pass filter on this card, as it makes digital audio softer and more pleasant in some older DOS titles. It also has a native AudioDrive mode which can bring 16-bit audio to supported games, but that has some issues which can be partially worked around. The ES1868F also supports ADPCM so Duke Nukem 2 sounds as it should. Best of all, its output is pretty much noise-free, when the jumper is set to the Line Out position. The FM synthesis on this card (ESFM) sounds excellent and gets very close to genuine OPL3. I'd even say that ESFM sounds a bit less "buzzy" and more melodic than true OPL3 which, while different, can produce a more pleasing result on some tracks. Here are some samples:
The enhanced ESFM functionality is also interesting in games which support that. Lastly, the MPU-401 interface on this card is completely bugfree, which makes it a great choice for connecting an external MIDI device. In this build, I have the card configured for A220 I7 D1 P330 T4 which provides excellent compatibility for older DOS games, i.e. its primary use case.
Sound card #2 - Sound Blaster 16 MCD CT1750
This is one of the earlier SB16 models, and it doesn't support Plug and Play, so everything needs to be configured via jumpers. I first moved the OPSL and OPSR jumpers to disable the on-board amp, as per Cloudschatze's instructions here. Doing that and using the optimized the mixer settings from that post pretty much eliminates all self-noise on this classic SB16.
Unfortunately, my particular card uses DSP v4.12, so it has all the relevant hanging note bugs. That's not an issue though, since the ESS 1868F will handle all MPU-401 duties. This SB16 also suffers from DMA clicking in older games, but once again, the ESS AudioDrive will come to the rescue in such cases. This card is also very long, so I could only fit it into the third ISA slot on this motherboard, and just barely. Where the CT1750 will shine are late-era DOS games which benefit from 16-bit audio. Examples include Crusader: No Remorse/No Regret, Privateer 2 and Heroes of Might and Magic 2. The SB16 has been configured to use A240 I5 D3 H7 P300 T6, which isn't a problem for later DOS games, as they often allow you to select these parameters manually in setup. Lastly, this card has a genuine Yamaha YMF262-M chip on board, for that authentic OPL3 sound.
Operating System
On this machine, I currently use a single 2 GB CF card with MS-DOS 6.22. No Windows here, as this build is purely focused on DOS gaming. With all the drivers loaded, I have 610 KB of conventional memory free, which is enough for 99% of the games that I play.
Conclusion
The versatility of this system is really something. The SpeedEasy BIOS settings make it extremely simple to change the CPU speed, giving even more slowdown options when paired with SetMul. In terms of upgrades, I plan on getting a front loading StarTech CF to IDE adapter and putting the system in a better case. The one I'm using right now is old and dingy, but it's what I currently had on hand.
The attachment Matrox_MillenniumII.jpg is no longer available
The attachment ESS_1868F.jpg is no longer available
The attachment SB16_CT1750.jpg is no longer available
The attachment Case_Interior.jpg is no longer available
The attachment Case_Exterior.jpg is no longer available
My retro builds
Reply 1 of 16, by Joseph_Joestar
Some benchmarks. Basically, I get Pentium at full speed, a fast 486 at the next speed level (CCD), a slow 486 after that (L1D) and lastly a 386 at the slowest setting (L1D+L2D+BPD+VPD). Of course, this can be fine tuned even further by applying slower memory timings in the BIOS and downclocking the CPU. Additional notes can be found in this post.
The attachment Bench_MMX200.png is no longer available
My retro builds
Reply 2 of 16, by Joseph_Joestar
Some more pics. For example, here's the SpeedEasy menu in the BIOS:
The attachment SpeedEasy.jpg is no longer available
And here's the Pentium MMX 200 slowed down to 100 MHz:
The attachment MMX_100MHz.jpg is no longer available
My retro builds
Reply 3 of 16, by bloodem
Love the build, what a great motherboard! I think I saw it featured in one of Necroware's videos. // LATER EDIT: Indeed - https://www.youtube.com/watch?v=Y3Ehly6xYz0
I was also in the process of building another retro PC, I initially wanted it to be another Socket A (this time with an ISA slot) + Athlon XP-M in a modern case, however things didn't exactly go according to plan (the Chaintech CT-7AJA2 that I managed to snag for a very good price turned out to be defective - the AGP slot only works with Voodoo cards, all other cards that use AGP features will cause an unrecoverable freeze after installing the nVIDIA/ATI driver, but they do work in PCI mode, without the VIA AGP driver). So far I was unable to find the cause 😞 , will probably create a Vogons thread about it this week.
So, it seems that I will finally go with a Socket 4 build, which will require quite a bit of modding on my modern case in order to do it justice, but i'm up for the challenge.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 4 of 16, by Joseph_Joestar
bloodem wrote on 2025-03-09, 16:29:
Cheers! And yeah, it's that board, thought mine seems to be a slightly newer revision. Here's a clean pic:
The attachment QDI_Titanium.jpg is no longer available
From what I gather, it's supposed to be one of the best (non-super) Socket 7 motherboards. QDI made some cool stuff back in the day.
I still have my Abit KT7A, which is another Socket A board with ISA, but it's not actively used anymore. I've put it in storage for now, since a few of its capacitors have started going bad and need to be replaced.
That sounds like fun! Make sure to post pics, I'm also interested in fitting some of these old boards in modern(ish) cases. Some of my old clunkers from the mid-late 90s have started to rust, and have almost no airflow, so I need to look for replacements.
My retro builds
Reply 5 of 16, by bloodem
Joseph_Joestar wrote on 2025-03-09, 16:56:
The FSB software control is certainly quite unique among 430TX boards, don't think I have any in my collection that are able to do this.
I do remember your KT7A build, that's another great board (that I sadly never had/played with)! Make sure to replace those faulty caps before it's too late! I've seen quite a few boards from the capacitor plague era, where the electrolyte leaked and slowly destroyed the board while in storage (and some of these boards were actually NOS, never powered on).
Will definitely post pics and benchmarks once it's ready! I expect the Pentium 60 to reach Ryzen 7 9800X3D speeds, because of... RGB! 😁
For now I'm still in the 'buying all necessary modding parts' stage (and some of these are from China, so it will be at least a month before I have them). 😄
Reply 6 of 16, by Joseph_Joestar
bloodem wrote on 2025-03-09, 18:03:
It's on my todo list, and I do have a desoldering station now, but I find recapping super tedious.
Maybe it's just my lack of experience, but desoldering big capacitors from multi-layered PCBs with large ground planes takes way too long. I did it a few times, and it turned out ok, but I can't say that I enjoyed the process. Maybe I'll just sell the KT7A instead, as I don't really have a use case for it anymore.
My retro builds
Reply 7 of 16, by Joseph_Joestar
Some more observations regarding the slowdown options with this setup. Approximate speed ratings were based on Phil's chart and SpeedSys.
CPU @ 100 MHz (2x50)
This speed setting is slightly below a classic (non-MMX) Pentium 120. WarCraft 2 map scrolling speed is normal, while it was way too fast at 200 MHz. However, WarCraft 1 water animation still plays too quickly, and the map scrolling speed is too fast at the normal setting.
CPU @ 120 MHz (2x60) + SetMul CCD
This speed setting almost perfectly matches a 486DX2-66. WarCraft 1 water animation now looks correct, and the map scrolling speed is fine at the normal setting.
CPU @ 200 MHz (3x66) + SetMul L1D
This speed setting is slightly below a 486DX2-66. After further testing, it seems to be the best fit for running Jazz Jackrabbit on this system in order to prevent the scrolling issues caused by the Matrox Millennium II. At that speed, the game still runs smoothly with Ultra High Quality sound settings, while the scrolling problem is completely eliminated. And after applying this fix by stargo and keropi, Jazz sounds pretty good on a SB16 at those settings.
CPU @ 120 MHz (2x60) with L1 and L2 caches disabled in the BIOS
This speed setting is slightly slower than a 386DX-33. Should be perfect for Wing Commander and similar games that need slow 386 speeds. The system can be slowed down even further by stacking SetMul BPD VPD on top of disabling the caches, but I don't currently have a use case for that.
My retro builds
Reply 8 of 16, by bloodem
Joseph_Joestar wrote on 2025-03-09, 22:26:
I see. Too bad, I would keep that nice board and do a full recap, but I'm a hoarder, so what do I know? 😁
Yes, it's definitely a matter of experience. I remember, 20 years ago, when I first did a full motherboard recap, it must've taken me at least 3 or 4 hours (and it wasn't exactly the best soldering job). Nowadays it takes me 15 - 20 minutes.
Hint: for the large ground planes, it helps to either have a pre-heater or a hot air station to help your soldering iron. I use the latter (because my pre-heater is too small for motherboards), and this technique has always worked well for me. Oh, and don't forget about good quality flux. 😀
Reply 9 of 16, by Joseph_Joestar
bloodem wrote on 2025-03-10, 14:06:
Cheers!
I do have some interest in recapping a few of my sound cards. Maybe after a bit more practice, I'll get to the motherboards as well.
My retro builds
Reply 10 of 16, by Joseph_Joestar
On the topic of sound cards, if I wanted to use the ESS 1868F for digital sounds in older games (e.g. to avoid DMA clicking) but still needed genuine OPL3 instead of ESFM, there is a way to do it. With both cards initialized, I can connect the Line Out of the SB16 to the Line In of the ESS card. In the SB16 mixer, I would mute everything except for the MIDI slider. At the same time, I would mute the Synth while unmuting Line In on the ESS card. This works fine for older games like Prince of Persia and Mortal Kombat 1, since they seem to send FM synth music directly to port 388 which is used by both cards. This workaround is a bit clunky, and I honestly don't feel the need to do it since I like how ESFM sounds, but I thought I'd mention it for completeness sake. Similarly, this allows me to easily pass CD audio to the ESS card, should I ever need to do that.
On that note, this is my first retro system where I got the floppy version of Mortal Kombat 1 to work reliably. And that was with the ESS 1868F card. Not sure if having IRQ set to 7 helped, or if it has something to do with the CPU running at 100 MHz. On any other retro rig that I tried, this version of MK1 would crash when playing digital sounds (e.g. character voices). For reference, the floppy version of MK1 is different from the CD version which is available on GOG. More info on the various PC releases of MK1 can be found in this thread: Versions of Mortal Kombat (1) (DOS port)
Also, I got the CD version of Gabriel Knight 1 to work with the SB16 configured at A240. For that, I needed to download the official patch from here and also the updated Sound Blaster driver (DACBLAST) from here. I still prefer how the game sounds on the ESS 1868F due to its low-pass filter but I wanted to get it working with both cards so that I could do a comparison. Lastly, there seems to be some DMA clicking on my SB16 in this game.
My retro builds
Reply 11 of 16, by Joseph_Joestar
I wanted to test the slowest setting on this system, so I lowered the CPU frequency to 100 MHz (2x50), turned off both the L1 and L2 caches, and then stacked SetMul BPD VPD on top of that. Though I didn't bother with loosening the memory timings, which would have probably helped a bit as well.
Anyway, the result was a score of 8.7 in 3DBench2, which is slower than a 386-DX25 per Phil's chart. I then fired up Prince of Persia, and for the first time ever, I saw the "Loading..." screen for a couple of seconds. 😁 The game ran fine, with both digital audio and FM synth music playing correctly on the ESS 1868F. I then played a bit of Wing Commander and that ran fine too, though possibly slightly slower than you'd ideally want
As noted earlier, I don't currently have a use case for this, I just wanted to see how far this system could go. Slowing down a 200 MHz Pentium MMX to such an extent is pretty neat.
My retro builds
Reply 12 of 16, by Joseph_Joestar
One thing that I noticed with my Sound Blaster 16 MCD is that its ASP/CSP chip is actually detected by Creative's DIAGNOSE.EXE utility:
The attachment SB16_ASP.jpg is no longer available
From what I gather, this chip isn't super useful for gaming. Apparently, only one game ever used it, and that was TFX, specifically the original 1.0 floppy version. I haven't tested that myself, but there's some info about it in this thread. Also, Cloudschatze made some tests with audio compression, and how this chip can take some load off slower CPUs in certain cases. It's an interesting piece of hardware to be sure, despite its limited uses.
My retro builds
Reply 13 of 16, by JustJulião
Hello,
FYI, there is new, 2024 bios for you mb from Jan Steunebrink! http://www.steunebrink.info/bios/T1BP_J3.zip
Changes are :
- Added detection of the WinChip 2(A)(B) CPU
- Expanded the CPU Type display for showing the correct IDT WinChip 2 string
- Added proper X2.5, X3, X3.33, X3.5 multiplier selections for the WinChip 2A in the SpeedEasy CPU Setup (Jumper Emulation mode)
These additional changes are also done:
- The improved 32GB HDD limit bugfix
- A fix for the second 64GB HDD limit bug
- A fix for the Win98 UDMA bug
The full story being that I was struggling getting consistent results with a Winchip2 : IDT Winchip 2A PR266 a.k.a "Weirdo"
Reply 14 of 16, by Joseph_Joestar
JustJulião wrote on 2025-03-17, 16:34:
Hello,
That's interesting, thanks!
At the moment, I don't have a use case for updating since I'm currently running pure MS-DOS 6.22 on a 2 GB CF card. However, that may change when/if I get a front loading CF to IDE adapter, which would allow me to switch CF cards more easily. I might give that modded BIOS a try then.
My retro builds
Reply 16 of 16, by Joseph_Joestar
Hans Tork wrote on 2025-03-21, 22:07:
Great job. The build looks really nice. How is the availablity of the parts on ebay?
I wouldn't know, as I sourced all of these parts from my local classifieds. 😄 I rarely buy retro hardware on eBay.
That said, this stuff was collected over a period of 2-3 years. I didn't get anything specifically with this build in mind, it just came together eventually.
My retro builds
